J Pipe and Ground Clearance
Old May 29, 2009 | 03:01 PM
STANGMMX's Avatar
Hey AZ
Got an 04 AT TL with an AEM CAI and mid muffler delete.
Since I changed the fuel to air ratios, every now and then I get a check engine light. Every mechanic says its just because of the CAI. Anyways, I was thinking of installing the J-Pipe, though I'm concerned about my car passing the emissions test (Texas). I already have to beg whomever is running the test to let my car pass despite the engine light.
Also, if I do the modification, do I need anything else other than just the j-pipe kit? I keep reading about the racing pipe, and I'm not too sure how it factors into the j-pipe installation.
Also, I live in Dallas. Some of the roads here can get pretty flood-like during a bad storm. I'm worried about the ground clearance issues I keep reading about. I'm guessing if I drove through a deep puddle, would it ruin not only the j-pipe but the car itself....? I'm fairly new to car mods so, go easy on me, and be as detailed as you can. Thanks.
Old May 29, 2009 | 03:52 PM
ssmtl2nv's Avatar
2009 g37s 6mt
j pipe rill not get ruined and the exhaust will flow better
Old May 29, 2009 | 08:39 PM
TLAdvanced's Avatar
The Kinetics of Bleu
Originally Posted by STANGMMX
Hey AZ
The TL has no business going through deep puddles. You will not affect your j-pipe but do run a risk of hydro-lock if the puddle is deep enough. Just don't drive through rivers or large puddles and you will be fine...
Old May 29, 2009 | 09:42 PM
STANGMMX's Avatar
Alrighty. How does the racing pipe factor into the J-Pipe? It seems a lot of people are using the two together.
Also, what about the emissions test?
Old May 29, 2009 | 09:54 PM
TLAdvanced's Avatar
Well the race pipe goes right behind the j-pipe and replaces the factory third cat. It "should" still pass the emmissions test but will fail the visual inspection if they notice and are strict.
Old May 29, 2009 | 10:17 PM
NAiL05's Avatar
I would make sure what code your check engine light is throwing before a mechanic tells you whats going on. I have a Injen CAI with a Comptech Cat back and I pass just fine in Dallas. Find out what your code is...A CAI should not throw a code unless improperly installed which is really rare.
Old May 29, 2009 | 11:25 PM
STANGMMX's Avatar
Ah, you're in Dallas? I had my CAI installed by "Jotech Motorsports". Been there? Also, how do I find what code? Sry... I'm a noob. I pay people to do car shit for me cause I'm so inept.
Old May 29, 2009 | 11:44 PM
NAiL05's Avatar
Autozone and so on should rea your code for free. I know who Jotech is and I am not a fan of them. I have heard some stories from them so I tend to avoid them. Plus they charge a lot.
Old May 30, 2009 | 03:26 PM
STANGMMX's Avatar
Alright ill swing by autozone and have them do so. Have any recommendations for installing the j-pipe other than jotech?
Old May 30, 2009 | 05:01 PM
NAiL05's Avatar
You can do it in the driveway if you really wanted too. its ilke 6 or 7 bolts as I recall when I was under the car last time. Hardest part is breaking the old bolts loose.
Old May 30, 2009 | 09:58 PM
TL|GTX's Avatar
A Black TL
Use this stuff called PB blaster.
Old Jun 1, 2009 | 02:00 PM
05TLRIDER's Avatar
Totally agree with PB Blaster!!! Best bet is to spray it pretty heavy about a week ahead of time and then a good spray every day for a week before the install. Bolts come right off then! Trust me, I just installed my XLR8 j-pipe about a week ago now.
ExcelerateRep
Oct 14, 2015 08:20 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
johnpancakes014
Sep 27, 2015 12:58 PM
kingbharj
Sep 25, 2015 07:25 PM
Rcelestino93
Sep 23, 2015 10:01 PM
