Is J-Pipe a DIY Install?
Over Caffeinated
Is installing a J-Pipe a reasonable DIY project?
Put car on jackstands, undo the factory nuts/bolts, remove original and slip the new one right in?
Impact wrench needed to undo original bolts??? Or will a breaker bar suffice?
Thanks!
Steve
Thanks!
Steve
Over Caffeinated
Awesome, thanks for the info! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
This will go on my list of pending mods.
One final question: Installation of the J-Pipe would have only a minor impact - if any - on exhaust volume - True??
Thanks again,
Steve
Thanks again,
Steve
A-spec steering wheel ftw
the difficulty of installation really is based on how old the car is and how much gunk has caked over all the bolts.
other than that, it is a very fast install.
as far as tone is concerned, if you're really picky you will notice a deeper/throatier tone. but if everything else is stock it's barely noticeable.
Over Caffeinated
94 DC4 RS LSV/Turbo
no no it is perfectly possible to do on jackstands I just think to properly line up the flanges as to not get an air leak you will have to losen the precats because it will in no way allow you to move down there
Over Caffeinated
if you haven't gotten the recall done yet, you can slip the tech 20 bux and have him/her install it because it needs to be removed to do the recall work.
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
