J-pipe
J-pipe
if i only change my j pipe on my tock exhaust system will it make a big sound difference? i tried looking for videos with just the j pipe but couldn't find any..
also were can a find a site that sells used tl parts?
thanks
thanks
BANNED
it may sound slightly louder when you step on it...but no, no real sound change if you upgrade to an aftermarket jpipe.
you are on a site that sells used tl parts. check out the black market section of the forum.
https://acurazine.com/forums/black-market-8/
The following 2 users liked this post by SharksBreath:
justnspace (08-27-2011),
typeS219 (08-27-2011)
^^^ just what he said. I installed a RV6 V3 jpipe a couple weeks ago on my stock 07 Type S 6mt. Keep in mind the new V3 also eliminates the 3rd cat as well. For the most part exhaust sound is unchanged. I did notice a little more growl in the mid RPM ranges like 2500rpm and up during acceleration but thats about it. During normal driving and cruise you will not notice a difference.
James
James
The following 2 users liked this post by JTS97Z28:
Radical Member
I just took my first test drive with the new j pipe.
Its a little bit deeper, but no louder. I was scared that I would hate the extra noise, but it is in no way baf
The following 2 users liked this post by 9632tl:
AZ Community Team
Received 7,771 Likes
AZ Community Team
I think he said he did it for noise reduction. I can't think of a performance benefit on the exhaust.
My and not even worth that much.
takin care of Business in
Received 4,732 Likes
^^^ I dont think it will damage the pipe....couple pros:
1> keeps the jpipe hotter and hence makes the exhaust pulses move quicker
2> protects the jpipe from stratches
3> reduces drone and quite"s" down the exhaust....i see that as a pro....
cons:
if you scrape...you gotta redo the full thing as light scraping may mess the wrapping and tear it open....
cons:
Radical Member
I think it might help the u derhood temps a little bit. Not sure though. I still have a lot if wrap left, and I think i might do the rest of the exhaust.
WEAR GLOVES AND LONG SLEEVES IF YOU DO THIS. I am still itching
^^^ did u dip the wrap in hot water before you put it on ?
Radical Member
That would have been the better way to go. I wrapped it, then hosed it down, then put it on the car wet and started it. Seems to be fine. I don't hear it flapping around yet, ha
I know it's stainless steel but I worry that over time moisture will gather in there and somehow rust lol. Now did you have that j-pipe on originally, then take it off and put the wrap on to measure the difference in sound? Also how does the butt dyno feel gain wise? Thanks.
justnspace (09-13-2011)
BoricuaTL
04-08-2016 01:08 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
ExcelerateRep
10-14-2015 08:20 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
