Which J-Pipe????
Old Jan 16, 2009 | 10:37 AM
  #41
Bearcat94's Avatar
AZ Community Team
Originally Posted by aarmd
I put on the ATLP J pipe and got before and after numbers with my G-tech. I only got a gain of 3 HP (changes in temp and humidity factored in) - no other mods. Hope this helps.
AR
No offense, but the conventional wisdom is that the G-Tech is junk.
That said, with exhaust only dyno's show ~10 - 12 WHP gained. Add a J-pipe to that and another ~10 - 12 WHP gained.
No exhaust with J-Pipe, I'd guess ~1/2 the gains. Just a guess.
For maximum impact you need both. And I don't think it matters which one; choose what you like for finish, cost, design, etc.
Old Jan 16, 2009 | 10:59 AM
  #42
aarmd's Avatar
My understanding is that the G-tech may not be accurate compared to numbers generated by an actual dyno, but is fairly accurate in demonstrating changes run to run with the same device in the same vehicle. That being said:
1/4 mile stock 15.21 @
Old Jan 16, 2009 | 11:03 AM
  #43
aarmd's Avatar
Sorry for the too-quick reply above.
1/4 mile stock 15.21 @ 94.68 mph 0-60: 6.71
ATLP J-pipe 15.12 @ 95.06 mph 0-60: 6.60
Old Jan 16, 2009 | 12:43 PM
  #44
ssmtl2nv's Avatar
2009 g37s 6mt
I scraped up my atlp, bent it a little and it is still fine, no leakage or anything....
Old Jan 16, 2009 | 05:23 PM
  #45
AcuraStyle's Avatar
Defrosting
it seems like everyone has several different answers, since the rv6 is tucked in, and probably produces the same hp, I think that would be the most ideal.
Old Jan 16, 2009 | 05:48 PM
  #46
way-acura's Avatar
Interesting results. I assume the 0.10 s difference is reproducible with different jumps and all that. All in all, I think all three are almost the same. The xlr8 and atlp have the y design. It should be more efficient that the rv6 version (similar to stock). I suspect that they are very close though.
For me, it will come down to how cheap do I feel like being on that day, if I buy it.
Old Jan 16, 2009 | 10:14 PM
  #47
Excelerate's Avatar
Former Sponsor
Originally Posted by AcuraStyle
if all the jpipes produce the same gains, but the rv6 is cheaper and doesn't sit as low, no offense to other companies but why purchase anything else? That is an actual question not being a ass...
According to RV6's site their j-pipe produced 5 whp and 7 ft lbs of tq. According to ATLP's website their j-pipe produced 7 whp and 14 ft lbs of tq. The XLR8 J-pipe produced 8 whp and 16 ft lbs of tq.
The j-pipes are not the same. I can't speak for anyone else b/c I'm not sure on the specs but the XLR8 j-pipe is made with T304 stainless steel and it is 100% stainless steel. It is an equal length j-pipe with a 2.5" collector to provide maximum flow. Yes, it sits lower but we did that in order not to sacrifice hp. The XLR8 j-pipe is also manufactured in the USA and we used the highest quality components.
Old Jan 17, 2009 | 12:04 AM
  #48
tihomirbg's Avatar
Does XLR8 j pipe sit the same level as stock? Or it is tucked in a bit than the stock?
Old Jan 17, 2009 | 12:05 AM
  #49
tihomirbg's Avatar
Originally Posted by Spiritman
OK, here is a thought. Look at the place where the two pipes are welded together. If you will.
This is where the hot gasses from the engine meet and are mixed. One of these manufacturers pipes is a long tapered affair. That (to me) is the only way to get MAX hp. Also you will get the best mixing of the exhaust and scavenging from the other cylinder bank. All else being equal. I think and bought the only best made/engineered pipe on the market! And it's the least expensive. Look at all of the pipes and see for yourself. OK?
I think you are talking about RV6 j pipe, correct?
Old Jan 17, 2009 | 12:59 AM
  #50
Excelerate's Avatar
Former Sponsor
No it sits slightly lower.
Old Jan 17, 2009 | 01:06 AM
  #51
tihomirbg's Avatar
But not more than the ATLP? Or about the same.
Old Jan 17, 2009 | 09:02 AM
  #52
TL|GTX's Avatar
A Black TL
Hmm i like XLR8, and ALTP most. The RV-6 ppl had problems with exhuast leaking, that caused the hissing. If ur car is lowerd go for XLR8, if it isn't lowerd go for ALTP//
Old Jan 17, 2009 | 10:22 AM
  #53
Bearcat94's Avatar
AZ Community Team
Which one do you have?
Or is you only mod still "All Weather Floor Mats"?
Old Jan 17, 2009 | 11:29 AM
  #54
tihomirbg's Avatar
I'm sitting on Eibach Pro kit, so its a little more than 1" drop.
RV6 j pipe is the one that I need more info with hissing problems and sh!t.
Old Jan 17, 2009 | 11:32 AM
  #55
tihomirbg's Avatar
Last night I took the car for some fun, otherwise it just sits in the garage till the winter is over.
I was on second gear boosting up to 6500rpm and I heard "boom"sound from the rear mufflers. Could that be indication of an exhaust restriction? The only mode I have is the mid muffler delete.
Old Jan 17, 2009 | 11:52 AM
  #56
jweb12's Avatar
The hissing problem was a small batch of faulty flex pipes from what I've read. Richie has since taken care of this and done right with the people that were affected. I don't have the RV6 pipe so I'm not biased towards it. Just don't feel it's right for people to read your post and get the wrong impression. Hope this clears things up a little.
Old Jan 17, 2009 | 02:20 PM
  #57
Excelerate's Avatar
Former Sponsor
It will sit about the same. It's right about the level of the subframe.
Old Jan 17, 2009 | 02:32 PM
  #58
ifirahse's Avatar
SlammedOnKonis
+1. It was just a small batch. Everything has now been rectified.
Old Jan 17, 2009 | 04:26 PM
  #59
tihomirbg's Avatar
Did I read correct that XLR8 has the most power in terms of HP?
Old Jan 17, 2009 | 06:54 PM
  #60
milk man's Avatar
haha
+1
yeah all are a get product cant go wrong .. but if you dnt wanna mess up the j pipe bc your car is lowered good with rv6 j pipe or if you want the most power go with excel?
Old Jan 17, 2009 | 07:22 PM
  #61
AcuraStyle's Avatar
Defrosting
Originally Posted by milk man
haha
+1
I WANT BOTH, most power and I dont want my jpipe messed up....I think the more power outweighs the scratched jpipe.... xlr8 it is hahaha
Old Jan 17, 2009 | 10:37 PM
  #62
FiveLiterCheater's Avatar
Does the Rv6 j-pipe really produce almost half the torque as the others?
Old Jan 17, 2009 | 10:55 PM
  #63
tihomirbg's Avatar
Well not really less less but yes, it does produce less torque.
Old Jan 18, 2009 | 07:08 AM
  #64
milk man's Avatar
Originally Posted by Richie v6
look how sexy
Old Jan 19, 2009 | 04:37 PM
  #65
fiore8072's Avatar
in the summer time i scrape my j pipe every day. its so bad im gona have to replace it soon. i got an ATLP
Old Jan 19, 2009 | 05:26 PM
  #66
milk man's Avatar
^go with richie v6 j pipe
Old Jan 19, 2009 | 06:01 PM
  #67
ssmtl2nv's Avatar
2009 g37s 6mt
+1, fu*k it, when it has to be replced so be it.
Old Jan 19, 2009 | 06:02 PM
  #68
ssmtl2nv's Avatar
2009 g37s 6mt
atlp is good a well, but rv6 offers better combo prices
Old Jan 19, 2009 | 06:03 PM
  #69
ssmtl2nv's Avatar
2009 g37s 6mt
look how sexy
looks like the J pipe made babies
Old Jan 19, 2009 | 06:18 PM
  #70
milk man's Avatar
^haha so funny peed in my pants
Old Jan 20, 2009 | 02:46 AM
  #71
Richie v6's Avatar
Former Sponsor
Just to let you know those numbers you are quoting dyno are from automatic Accord dynos. The Accord has a smaller 3.0 engine and a transmission with more drivetrain loss. I am pretty sure the ATLP and XLR8 dynos were done on TLs with manual transmissions. Quoting those numbers is simply misleading. I have yet to do any testing on the TL but I plan on having dynos done when it gets a little warmer.
See above ^
Old Jan 20, 2009 | 02:52 AM
  #72
Richie v6's Avatar
Former Sponsor
As jweb12 said the hissing with only on a small batch of jpipes. The problem was solved ASAP at my expense.
Old Jan 20, 2009 | 02:58 AM
  #73
Sal's Type S's Avatar
Yeah the hissing sound i had it on my ATLP also almost right from the start, when I finally got the rest of the exhaust in(did J-pipe first) I saw this inside my flex tube WTF! But mike is taking care of it is exchanging it for me.... More pics in my album section.
Old Jan 20, 2009 | 05:06 AM
  #74
JD TL-S's Avatar
I was told by a person at work that a J-Pipe is illegal in IL. ??? WTF. Is this true?
I have no idea.
Old Jan 20, 2009 | 06:58 AM
  #75
powerflow's Avatar
Wiggy Wiggy Wiggy
I have no idea.
There is probably some vague law that states any aftermarket exhaust modifications is illegal. But, Midas, ect is considered aftermarket, and they operate just fine. Nothing to worry about. There isn't even a cat in the J-pipe.
Old Jan 20, 2009 | 08:21 AM
  #76
BLKURA's Avatar
I caught the mod flu
Are those #'s your quoting strictly from the J-pipe? Or were there other mods installed on the test cars? That is very mis-leading. I planned to purchase either the XLR8 or the ALTP soon. However, my choice could be swayed toward the ALTP because of inaccurate #'s I feel are to sway people to buy your products. You have been very good to me in the past, just want a clarification on those #'s... thanks Josh
You have a drop, correct?
Old Jan 20, 2009 | 08:58 AM
  #77
Meek32v6's Avatar
I like to whistle in my
See above ^
That will DEFinitely make a difference - ALL in all I think its great what you guys have done. A to all of your for bringing us new mods for the J series.
Old Jan 20, 2009 | 09:23 AM
  #78
Bearcat94's Avatar
AZ Community Team
I have no idea.
The car ships with a J-Pipe (Acura calls it an "A-Pipe" or "Pipe A"), so how can having one be illegal?
It's either the "all exahaust modifications are illegal" or a misunderstanding thinking you are messing with the Catalytic Converters (which I *think* is a Federal Offense).
1 WHP and 2 Ft-Lbs is not enough to matter. It's noise/clutter; Repeat the dyno's and the numbers could swap they are so close. A dyno is not repeatable enough to differentiate 1WHP.
Make your decision based on other factors: Credibility, Build Style and Quality, Cost, Personal Preference, etc.
Old Jan 20, 2009 | 11:59 AM
  #79
Excelerate's Avatar
Former Sponsor
The dyno we posted was on an A/T TL-S but the base TL dyno showed similar numbers. I simply quoted the numbers off your website; there was no intention of misleading ppl.
Yes those are the dyno gains from the XLR8 j-pipe only.
Old Jan 20, 2009 | 12:41 PM
  #80
Richie v6's Avatar
Former Sponsor
So you quoted numbers from 3 different cars with 3 different engines..........
RV6 3.0L Automatic Accord
ATLP 3.2L Manual TL Base
XLR8 3.5L Automatic TL Type-s
