Intake Whistle - Got it?
Old Mar 25, 2010 | 09:28 AM
  #81
TheDanger's Avatar
2007 TL
Just something I noticed was a sound that sounded like a belt whine. I checked out the vibra mount on AEM v1 and the nuts on both sides were loose. I tightened them up and now its gone. Just got the faint whistle.
Old Apr 5, 2010 | 09:09 AM
  #82
killersrt's Avatar
Year/Model: 04 6-speed Aspec
Intake: AEM V2
P2R Spacer: Yes
Whistle: Under part throttle
Other than the whistle, you couldn't tell the car was modded, until you give it 1/2 throttle or more. That's when the intake growls
Old Apr 5, 2010 | 02:59 PM
  #83
Xiomaro's Avatar
1st 3g Turbo TL-S
lol, i just saw this thread title.
Q:Intake whistle- got it?
A:you could say that, lol
Old Apr 6, 2010 | 04:15 PM
  #84
tc_terencec's Avatar
I MAKE NO SENSE
Year/Model: 2004, 5AT
Intake: Fujita
P2R Spacer: no
Whistle: yep, more like a "whoosh", whistle when I tap the throttle - sounds like a BOV i've been told
Old May 6, 2010 | 10:07 AM
  #85
jrocka312's Avatar
A-SPEC 6MT
Year/Model: 2004 6MT A-SPEC
Intake: AEM V2
P2R Spacer: no
Whistle: yes, a faint sound can be heard between 2100 - 2600
Old May 6, 2010 | 03:07 PM
  #86
jeowen's Avatar
Year/Model: 2008 TYPE-S
Intake: AEM V1
P2R Spacer: no
Whistle: very low whistle btw 2000-3000
Old May 6, 2010 | 03:09 PM
  #87
maharajamd's Avatar
I'm convinced there is a way to fix the whistle though. There has to be.
On my old prelude, some guy were putting a type of 'fan' blade 'tornado' or whatever inside their intakes. I wonder if there is anything like that we can do.
Old May 6, 2010 | 03:30 PM
  #88
acuraowner4life's Avatar
Year/Model: 2005 AT
Intake: CAI
P2R Spacer: YES
Whistle: Absolutely...Cant stand it. Sounds like a squealing belt.
I had a CAI on my 95 Integra and had the same whistle. I DIDNT have a TBS so it has to be the CAI. Im tired of it so if anyone figures it out, for the love of god please let me know! I love the throaty sound but the whistle can go. I can even hear it at 70mph if I roll down the window. For those that dont hear it but have a CAI, you will need to roll down your drivers side window to hear it. I cant hear it with window rolled up but I know its still there.
Old May 6, 2010 | 03:52 PM
  #89
Yukoncole's Avatar
This is not a bad idea at all!! The "Tornado" was designed to put a vortex into your air as it enters the intake...in theory this was suppose to save fuel but for us this vortex would very possibly eliminate the whistle! In my limited knowledge air will only create a whistling noise when it is in a straight line and passing either through or over something that disrupts it. If we can spin the air in may just work!! The other thing I have read on here is about the threaded Nipple near the TB...this would and could very easily cause the noise for the same listed above reasons! If that is not needed I plan on filling it with a possible fiberglass resin and sanding it smooth.
Old May 6, 2010 | 04:03 PM
  #90
Yukoncole's Avatar
OK....So I called AEM! They said the noise everyone is hearing typically comes from the air passing through/over the throttle plate/butterfly of the Throttle Body! The only advise that was given was to look for any "sharp" edges that you can file down or remove....I would not attempt this on the butterfly because it would most likely mess with the idle I would assume!
I asked about the Threaded nipple as well...the purpose of that is to relocate the Air Temperture Sensor from the Intake to the CAI tube....thus tricking the motor to think it is cooler than it is and providing more fuel...this intrigues me!! Has anyone done this?? I am thinking this is almost worthy of a seperate thread!
Old May 7, 2010 | 08:20 AM
  #91
S PAW 1's Avatar
MAKE/MODEL: '07 TL-S
INTAKE: Fujita F5
P2R SPACER: yes, w/gaskets
WHISTLE: Nope. Quiet as a mouse, until I make it ROAR
Old May 9, 2010 | 02:49 PM
  #92
Jaco's Avatar
My car had it from 1900 to 2700 rpm with the AEM v1
Old May 10, 2010 | 01:12 PM
  #93
chinkwapin's Avatar
.:dedicated:.
kinda off topic but i used to get it on my OEM air box with the intake resonator removed (only on a cold start tho). since then i have the fujita and it whistles all day long in low rpm
Old May 10, 2010 | 03:45 PM
  #94
mglax13's Avatar
New shoes on my
This has been discussed alot in older threads. Looks like it decreases your MPG (maybe 1 MPG...if that) and the HP increase is negligible if even present.
Old May 13, 2010 | 12:16 PM
  #95
Usalinh's Avatar
Year/Model: 05 AT Base
Intake: AEM
P2R Spacer: Yes
UR lightweight sc pulley: Yes
Whistle: 2000-3000 rpm
I've had the mods on my car for about 2 years now. At first it was a slight whistle like a blow off valve on a turbo setup. However, lately it's getting more noticeable. Anyone else notice this also? Don't get me wrong I like the sound but, it's making me worry something might be wrong because it's making a louder whistle sound then before.
Old May 14, 2010 | 01:02 PM
  #96
Vigor66's Avatar
Intake: AEM
P2R Spacer: Yes
You might want to check that everything is tight if you already haven't. I can barely hear the whistle of my V2 and that's only with the windows down and me paying close attention to the noise.
Old May 14, 2010 | 06:48 PM
  #97
Usalinh's Avatar
I'll check my hoses again for any loose ends or cracks... Thank you...
Old May 16, 2010 | 08:24 PM
  #98
Yukoncole's Avatar
Installed my AEM V2 today with a Thermo-Tec Wrap and I have very very little noise/whistle! I did though modify the threaded nipple by shorting it up so the bolt was flush with the inside of the tube! This hole is very likely the producing factor for a fair amount of the noise as I read one other post on here saying that after they installed a longer bolt the noise also went away!!!
Old May 16, 2010 | 08:31 PM
  #99
Yukoncole's Avatar
Originally Posted by BLKURA
Since you seem so concerned Jeff, be our guest!
I put a longer screw in the nipple and wrapped it with teflon tape, most of the whine has gone away!
This seemed to have worked for me as well, I just grinded down the nipple and used the provided bolt though...in the end it is the same result. The noise is very very faint!
Old May 17, 2010 | 01:40 AM
  #100
NAiL05's Avatar
MAKE/MODEL: 2004 Acura TL Six Speed
INTAKE: Injen CAI with modified Velocity stack/ 6 ID filter.
P2R SPACER: No
WHISTLE: Yes
Old Dec 1, 2013 | 01:08 AM
  #101
Frosty's Avatar
MAKE/MODEL: 2004 Acura TL 5AT
INTAKE: "Poor Man's CAI": Stock Airbox/Tubing + AEM conical filter
P2R SPACER: No
WHISTLE: YES, 2000-3000 RPM
Thread Resurrection FTW!
So I made my own CAI using Jeremy's DIY Thread . Overall, I love it, except for this annoying whistle! I'm slightly relieved to hear that I'm not the only one experiencing this. This started happening right after I finished installing the intake, but I honestly thought it was my serpentine belt creating the noise. It sounds EXACTLY like that (not a pleasant sound). After reading this thread, and also removing my serpentine belt, I'm 99% sure it's my intake creating the noise.
Since I don't have that much invested into it, I'm seriously thinking about removing the AEM filter and just leaving the factory intake/filter + resonator delete. I ran that setup for a long time before adding the conical filter and never heard a whistle. I will, however, miss the fart sound when I shut the car off
I have a question for those of you who do have the whistle though: Do you hear it when the car is in Park and Neutral, or ONLY when it is in Drive? For me the whistle/whine is only present in Drive. I hear nothing when I rev the engine in Park or Neutral. So I'm just wanting to make sure that this is a common symptom among you fellow whistlers
Old Dec 4, 2013 | 02:01 PM
  #102
maharajamd's Avatar
Old Dec 4, 2013 | 02:26 PM
  #103
Nick216's Avatar
The Boss
wana know the fix to it? aftermarket catback.
Old Dec 7, 2013 | 01:40 AM
  #104
grod1321's Avatar
People be asking me what I got in my car cuz it sounds so beast, between the whistle and the exhaust.
08 TLs
AEM V2
P2R spacer
Quad magnaflows rv6 v3 and cutout
BUT...I had the whistle with a short ram K&N as well, just wasn't as loud
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
Jimmy_D
Oct 7, 2015 11:52 PM
