Innovative Mounts Review
Old 09-11-2008, 04:19 PM
  #81
OTSB708's Avatar
Excelerate is right, the mounts will become softer as the bushings break in. The only vibration I have now is when the A/C is on. No vibration with either cold starts/warm starts.
I am pretty constant on checking the torque making sure everything is still buttoned up and the mounts seem to be staying tight. On the center bolt throught the mount, I just hand tightened and then made a quarter turn with the wrench and then I checked it with my torque wrench and it is right at 30 ft-lbs. That seems the way to go.
Old 09-12-2008, 08:11 AM
  #82
ek9hatch's Avatar
As posted Sunday night on the other board:
"Alright, I've done a little testing since I finished the initial install friday night. I determined the air ratchet tightened the through-bolt to about 45 to 50 ft-lbs, and I adjusted down from there. I made sure I stayed in each torque spec for at least three drive cycles, so that I could get an adequate feel for each. I've been doing alot of driving in the last 48 hours or so. My results (keep in mind, this is done by ass-dyno only):
45-50 lb-ft: Heavy vibration, sound magnified significantly through the frame.
40 lb-ft: Only slightly better than 45 lb-ft.
35 lb-ft: noticeably quieter, much less vibration, but still a good deal more of both than stock.
30 lb-ft: very close to stock vibration level, only slightly noticeable magnification of engine noise.
25 lb-ft: no discernible difference over 30 lb-ft.
Traction level stayed about the same across the board.
My conclusion: 30 lb-ft is the ideal torque setting for reduced vibration while maintaining the highest possible clamping value. I would recommend a light application of loc-tite on the bolt ends as extra insurance, but 30 lb-ft should be quite adequate to maintain this torque value.
Hope this helps people."
Old 09-13-2008, 07:33 PM
  #83
13.19@105.48MPH
OMP Prelude's Avatar
So who else is running the 85a mounts? well it has some vibration, long story short it feels normal to me due to my other car has 95a in it, but i guess its not for everyone
Old 09-16-2008, 01:14 AM
  #84
Inaccurate's Avatar
Originally Posted by Inaccurate
... I think that I felt less torque steer. It is hard for me to tell because I am immune to torque steer.
Qouting myself....
According to this source,
http://en.wikipedia.org/wiki/Torque_steering
the IM mounts could be reducing torque steer. According to the cited source, torque steer is caused by (in addidtion to other reasons) :
- Transient movement of the engine
- Tolerances in engine mounts
Thus, the opposite should be true. Less engine movement and stiffer engine mounts should cause less torque steer.
Old 09-16-2008, 08:15 AM
  #85
94 DC4 RS LSV/Turbo
stillhere153's Avatar
^ makes sense... I am also immune to torque steer, I actually use it to corner lol... kinda like how I friggin power slid my car yesterday... friggin crappy mickellins... intentionally mispelled
I dont know what I am waiting for to do this mod, I def got the install down to a t, done it 3+ times already... sigh... ACTROS sell em ur mounts lol
Old 09-19-2008, 11:36 AM
  #86
Green Machine
t0talacuratl's Avatar
Finally got the rear mount installed yesterday. Some love and hate results. It's more responsive than just having 2 mounts, but the vibration is definitely there now. I've even made sure all the mounts were at 30ft/lbs. I will drive on them for a while and hopefully they will break-in. All in all, I'm please performance wish.
Old 09-19-2008, 09:54 PM
  #87
Inaccurate's Avatar
1) From doing research on these IM on the CL and 2G sub-forums, most agree that it is the rear mount that contributes the vast majority of the vibration out of the three mounts.
2) I was wanting to wait a week or so longer before saying anything just to be sure. But, I will open my mouth now in case others can benefit from the tentative info.
My mounts have broken-in after 500 miles.
My stiffer 75A (Black) mounts have become less harsh. The mounts have less intense vibration and less noisy (that roaring when sitting at a red light). I estimate that the vibration and noise is reduced by at least half compared to the first few days after installing them.
Again, I had read others say the same thing about the mounts breaking-in. But honestly, I did not believe that this was possible. Rhetorically, how can a chunk of polyurethane "break-in" ? If anything, I thought the driver became numb to the mounts, not that the mounts broke-in.
But, I can say that I was wrong. I know (I think ???) that I did not become numb to the mounts. I would need a hell a lot longer than just 500 miles to get use to that roaring sound at stop lights that sounded like a jet taking off when you seat next to the plane wing.
Plus, I had not driven my car in 7 days because of hurricane Ike here in Houston. And when I drove my car yesterday for the first time after Ike, I could easily spot the less intense vibration and noise. If it was me that was becoming numb, I think that I would had felt the full wrath of the mounts after not driving the car for 7 days. Instead, they felt about 50% less intense.
Old 09-19-2008, 11:27 PM
  #88
Green Machine
.......My mounts have broken-in after 500 miles.........
Thanks Inaccurate! I feel better, because I don't think I could stand the vibration.
Old 09-20-2008, 01:20 AM
  #89
Inaccurate's Avatar
Originally Posted by t0talacuratl
...I don't think I could stand the vibration.
My exact words when I first drove my car immediately after the install.
Old 09-20-2008, 02:30 AM
  #90
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
So what's the stiffness of our stock motor mounts?
Old 09-20-2008, 04:54 AM
  #91
94 DC4 RS LSV/Turbo
^ stock mount stiffness is not at all their softies hahaaha
Old 09-20-2008, 11:57 AM
  #92
312 HP 271 TQ Dynapack
mrlunecy's Avatar
Alright guys...My mounts are in hand........since so many heads have installed this already; ANY CHANCE OF DOING THIS WITHOUT PULLING OFF THE BLOWER?
Thanks in advance.
Old 09-21-2008, 09:28 AM
  #93
dan.....k's Avatar
^ I don't think so.
Old 09-21-2008, 12:27 PM
  #94
94 DC4 RS LSV/Turbo
Well for the front you might be able to get at the front mount from underneath, for the side 50/50 chance youcan get at it, for the rear that's no problem at all
For the front if you can see the center bolt just see itn you can do it without removing the blower
Since I haven't seen a blower in a while I'd say it is definitely possible
Them swivel tip extensions ftw
Old 09-21-2008, 01:22 PM
  #95
347hp/300tq @ 4psi
04accordcpe's Avatar
Thanks in advance.
no problem at all
Old 09-21-2008, 05:33 PM
  #96
mrlunecy's Avatar
thanks guys, I'll check it out and see if I can wing-it!
Old 09-23-2008, 09:47 PM
  #97
OMGWTF4THGENTL
Kennedy's Avatar
I'm back bitches...
Lunecy, what's the verdict?
Been carting these mounts around for weeks... Wanna know if I'm gonna be able to get them in/
Old 09-30-2008, 05:43 PM
  #98
I have car ADD
BLACKURA_NY's Avatar
ugh... FINALLY installed mine today.. big difference in shift, wheel hop and acceleration.... shifts are smooth... vibrations are DEFINITELY there... but it may break in
Anyways.. heres a piece of info for some of the others on here
The Vacumm lines... they are designed to release the tension in the mounts when the engine is idle.... you wont get that function with the Innov. mounts... so, thats why we all state "alot of vibration at idle or at red light"
i wanna go rip my car apart and do some nasty 0-60 pulls, but i just installed new brakes today, and i wanna break them in.. also, they dont feel 100% right (big UH-OH for me !!! )
Old 09-30-2008, 05:44 PM
  #99
I have car ADD
Originally Posted by Kennedy
I'm back bitches...
Sean (04accrdcpe) said he didnt need to pull the blower.... i dunno how though...
Old 09-30-2008, 11:00 PM
  #100
94 DC4 RS LSV/Turbo
if he didn't pull the blower he must be running custom fans, cuz I couldn't get the fan out without removing the blower and without twisting the bracket on the fan, possible likely but not without modifying stock parts
as for allon + brakes, I thought you said you were not going to be doing brake mods
ps. oem pads are dusty as fuck but they are real good
Old 09-30-2008, 11:50 PM
  #101
I have car ADD
^ just went for stoptechs.. no biggie... much cheaper than OEM.. but they dont feel to be as "grippy" .. only got about 3 miles on them
as for the mount install... wasnt that hard, but after a few days... my mechanic was telling me, its good to unbolt the mounts... start the car, put it in reverse, then drive, then neutral, and re-tighten...
im getting some serious vibrations. i tq'ed the middle bolt (through the mount) to about high 30's lb/ft.... when i put the ac on... (which thank god i dont need until june) the car goes into like a `69 Chevy SS 454 mode... everything shakes
im gonna be building a custom cup holder/ash try soon... all my change and drinks rattle like fck with the ATLP/Rv6 setup.. these mounts didnt help
im hearing from others, that they break in though?
Old 09-30-2008, 11:57 PM
  #102
'10 Shelby
TheWanderer316's Avatar
^ yea, mine had serious vibrations for about the first week, now i barely notice it all.
Old 10-01-2008, 05:23 AM
  #103
347hp/300tq @ 4psi
i didnt have to remove the blower, but then again i have a custom radiator and i have an accord, not a TL. i believe the front end clearance is a little different between the two.
give them a good month until they soften up really nice.
Old 10-01-2008, 11:16 AM
  #104
94 DC4 RS LSV/Turbo
figured you had a custom rad something up there in the front cuz the tl has 2 fans infront gives you enough space to do nothing
Old 10-01-2008, 12:48 PM
  #105
Former Sponsor
Excelerate's Avatar
The Accord V6 03-07 guys running the CT S/C kit have to have a custom radiator in order to fit the blower or the rad hose outlet would make contact with the blower. I believe he had Griffin make him one.
Old 10-01-2008, 04:09 PM
  #106
erick3's Avatar
by "vibration" are you guys talking about in the STEERING wheel? mine couldn't be any worse with my already BEND center hub/axle. or could it possibly get worse? I haven't ordered a set of these yet, but I'm planning on it.
Josh (excelerate), do you sell these bad boys? lol
Old 10-01-2008, 04:13 PM
  #107
'10 Shelby
The vibration im talking about was mostly the dash rattled really bad, once in a while it still does unless i throw it in neutral then it just quiets up completely.
Old 10-01-2008, 05:01 PM
  #108
Former Sponsor
Excelerate's Avatar
Yes we sell them. $325 shipped to the cont US
Old 10-01-2008, 08:35 PM
  #109
Inaccurate's Avatar
Agree. Two week ago, I posted that my black mounts had broken-in very well. They have broken-in even more since my last post.
Old 10-02-2008, 06:15 AM
  #110
HQTL6SPD's Avatar
So when you guys say 'break-in,' the only thing I can imagine happening to cause this is the urethane material conforming smoothly around the bolt.. Anyone agree?
Old 10-02-2008, 02:04 PM
  #111
Nobody knows?
Old 10-02-2008, 02:21 PM
  #112
I have car ADD
stock mounts have actuators in them, and use vacuum lines.. when the car is idle, the mounts have almost NO stiffness to them, as you increase engine RPM in gear, the mounts tighten up... this design is also VERY critical in front end collisions
The TL's engine is designed to drop and buckle when invovled in a serious front end crash... these mounts will stop that front happening as smoothly as the OEM ones would.
Most Acura dealers, will probably give you sh*t over them, and tell you, you've now voided the warranty and the entire cars "frame or chassis" because of these mounts... the increased vibration may lead to new noise rattles or squeaks.. so i hope most of us, who installed these, arent going to the dealer and complain about any type of warrnaty claim related to something that can be affected by these mounts
FYI, i think the ONLY thing on my car thats left under warranty is my side-view mirrors.. which ironically enough, are breaking (they stick & click when moving).. and maybe my power windows
Old 10-02-2008, 05:30 PM
  #113
HQTL6SPD's Avatar
whoa, that's pretty cool..
my mirror was like that too for a while, all you need to do is remove it and white lithium grease the hell out of the 'plastic ball' thingy... make sure u rotate it so you can get all angles..
Old 10-02-2008, 07:28 PM
  #114
94 DC4 RS LSV/Turbo
Yea am having problems with my actuators also click click click when they tilt. When I go to park
Old 10-02-2008, 09:26 PM
  #115
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
Whoa, did they go up $10 in 5 days? They were $315 shipped in the other thread.https://acurazine.com/forums/showpos...3&postcount=73
Old 10-02-2008, 10:09 PM
  #116
Former Sponsor
Excelerate's Avatar
I did the GB at $315 shipped but I'm going to keep them at $315 shipped for now so don't worry they're still good at that price.
Old 10-02-2008, 11:05 PM
  #117
Inaccurate's Avatar
Your theory is as good as mine. My theory is that the urethane becomes more pliable from repeated stretching (that is, stretching at the vibration magnitude level). Another of my theories is that WOT helps to give it a good stretch to help hasten the break-in process.
One thing is for sure... they DO break-in !!! My mounts were MONSTERS when I first started the car after the install (NASCAR type vibration and noise). I thought to myself, "oh HELL, I made a big ass mistake ".
But now with the break-in thus far, they have turned into pussycat.
Old 10-03-2008, 12:06 AM
  #118
mrlunecy's Avatar
I'm back bitches...
Sorry...I'm lagging it; mounts still sitting in my living room. Havent had any "TL Bonding Weekends" lately...i think she's mad at me.
But if any fans have to come out, the blower has to come with it.
Old 10-11-2008, 12:55 PM
  #119
pinina's Avatar
Did every one cap the vacuum line at the same place that Inaccurate stated? I see that it is connected to something else and it has a wire that goes who knows where. Is this correct?
Old 10-11-2008, 07:00 PM
  #120
Inaccurate's Avatar
pinina,
That thing that the wire and the hose are connected to is the solenoid. The ECU uses this solenoid (via a 12v signal) to control the softness of the oem mounts.
You can see the hose running from the manifold to the solenoid. There are hoses running from the solenoid going to the mounts (front and rear, but not the side mount).
I plugged the nipple at the manifold and removed everything (all hoses and solenoid). I used a nylon tie-wrap to secure the electrical connector that had went to the solenoid.
Quick Reply: Innovative Mounts Review
