help plz
Most likely, the bar you bought is not going to fit, probably for a honda civic or itr. Go open you hood, take the strut tower bar w/ you and size it up. Theres a whole bunch of plastic covers under the hood. They all lift straight off, just pull straight towards the sky. The main cover has three plastic screws, twist them 90 degrees and pull that offTake em' all off to see your strut tower hats, and try and line up the mounting holes. If they fit, good, if not, wasted money. And leave all the plastic covers off, they are like a jacket on top of you motor= HEATSOAK. Not to mention weight and sound. They do nothing for you except make your engine bay look cosmectically enhanced. Good luck, bro.
I think it will fit but it might hold on to one bolt instead of two(I think) on the strut tower.....if you want to put it on correctly, you will need to swap the top hats from the Accord to you car and then it will fit correcty
Originally Posted by ayethetiense
it wont nec. fit for sure, what year accord did you buy it for?
and if its the right one, then you should def swap out the top hats so its not just holding on via one bolt.
LeonCL
Feb 2, 2005 01:27 PM
