HDS Honda/Acura GNA600 Diagnostic Scanner
Does this system give you the ability to monitor and record every aspect of real time data and advanced parameters? Especially monitoring knock?
http://cgi.ebay.com/ebaymotors/HDS-H...motiveQ5fTools
See reply #184 in link below.
http://www.8thcivic.com/forums/civic...ml#post8342129
Below is the orginal manf of the unit. The link shows a toll free Phone 800-210-8699. Q&A time![Bounce](https://acurazine.com/forums/images/smilies/bounce.gif)
http://www.teradyne-ds.com/GNA600Sal...3/Default.aspx
More interesting stuff.
http://www.helminc.com/helm/honda_di...9C00WVT38M0G06
http://www.kseries-tech.com/forums/v...php?f=19&t=189
Communications with the vehicle's onboard systems can be established when the HDS is used with an approved hardware device (ex., HIM or GNA600). Once communications have been established with the vehicle, the HDS can report and datalog the following real time data:
ENGINE SPEED
VSS
ECT SENSOR 1
ECT SENSOR 2
IAT SENSOR 2
MAP SENSOR
MAF SENSOR
CLV
TP SENSOR
REL TP SENSOR
APP SENSOR
APP SENSOR A
APP SENSOR B
TARGET TH VLV
IDLE TARGET TH
TP SENSOR A
TP SENSOR B
MOTOR DUTY
CRUS REQ TH
TACH RELAY
THROTTLE ACTUATOR SUPPLY VOLTAGE
AF SENSOR
AF LAMBDA
AF FB (ST FUEL TRIM)
AF FB AVE (LT FUEL TRIM)
FSS
H02S (AF) S1 HEATER
IDLING
FUEL CUT
FUEL CUT DECEL
BATTERY
IG1 LEVEL
ELD
ALTERNATOR
ALT CTRL
GEAR POSITION
C SHAFT SPD
REVERSE LOCK SOL
BRAKE SWITCH
A/C SWITCH
A/C PRESSURE SENSOR
A/C CLUTCH
SCS
OIL PRESSURE SWITCH
VTEC PRES SW
VTEC SOL
SELENOID RETURN SIGNAL
F INJECTOR
SPARK ADVANCE
VTC STATUS
CMP CTRL
CMP CTRL CMD
VTC SOL DUTY
KNOCK RETARD
KNOCK SENSOR
KNOCK CTRL
FUEL LEVEL (AVERAGE)
FUEL LEVEL
EVAP CVS VALUE
RE CVS VALUE
MIL
MIL STATUS
MIL DIST
MAIN RELAY (FP)
FAN HIGH CTRL
FAN LOW CTRL
ENGINE OIL LIFE
IDLE LEARN
CKP PULSER F/B LEARN
MAX ENG SPD
OVER ENF TM
START ECT
START IAT
CAT MONITOR CONDITION B1
MISFIRE
MISFIRED CYL
CYL1 MISFIRE_B
CYL1 MISFIRE
CYL2 MISFIRE_B
CYL2 MISFIRE
CYL3 MISFIRE_B
CYL3 MISFIRE
CYL4 MISFIRE_B
CYL4 MISFIRE
MISFIRE CYCLE
SHIFT/CLUTCH SW
MISFIRE CYCLE_B
CMP A NO PULSE
CMP B NO PULSE
CKP NO PULSE
CMP A NOISE
CMP B NOISE
CKP NOISE
CRUISE BRAKE SW
CRUISE MASTER (MAIN) SW
CRUISE SET SW
CRUISE RESUME SW
CRUISE CANCEL SW
CRUISE INDICATOR
Readiness codes (either Complete (could also mean not applicable) or Not Complete) include the following:
CATALYST
Heated Catalyst
EVAP
Secondary Air
A/C system refrigerant
O2 Sensor
O2 Sensor Heater
EGR
ENGINE SPEED
VSS
ECT SENSOR 1
ECT SENSOR 2
IAT SENSOR 2
MAP SENSOR
MAF SENSOR
CLV
TP SENSOR
REL TP SENSOR
APP SENSOR
APP SENSOR A
APP SENSOR B
TARGET TH VLV
IDLE TARGET TH
TP SENSOR A
TP SENSOR B
MOTOR DUTY
CRUS REQ TH
TACH RELAY
AF SENSOR
AF LAMBDA
FSS
H02S (AF) S1 HEATER
IDLING
FUEL CUT
FUEL CUT DECEL
BATTERY
IG1 LEVEL
ELD
ALTERNATOR
ALT CTRL
GEAR POSITION
C SHAFT SPD
REVERSE LOCK SOL
BRAKE SWITCH
A/C SWITCH
A/C PRESSURE SENSOR
A/C CLUTCH
SCS
OIL PRESSURE SWITCH
VTEC PRES SW
VTEC SOL
F INJECTOR
SPARK ADVANCE
VTC STATUS
CMP CTRL
CMP CTRL CMD
VTC SOL DUTY
KNOCK RETARD
KNOCK SENSOR
KNOCK CTRL
FUEL LEVEL
EVAP CVS VALUE
RE CVS VALUE
MIL
MIL STATUS
MIL DIST
MAIN RELAY (FP)
FAN HIGH CTRL
FAN LOW CTRL
ENGINE OIL LIFE
IDLE LEARN
MAX ENG SPD
OVER ENF TM
START ECT
START IAT
MISFIRE
MISFIRED CYL
CYL1 MISFIRE_B
CYL1 MISFIRE
CYL2 MISFIRE_B
CYL2 MISFIRE
CYL3 MISFIRE_B
CYL3 MISFIRE
CYL4 MISFIRE_B
CYL4 MISFIRE
MISFIRE CYCLE
SHIFT/CLUTCH SW
MISFIRE CYCLE_B
CMP A NO PULSE
CMP B NO PULSE
CKP NO PULSE
CMP A NOISE
CMP B NOISE
CKP NOISE
CRUISE BRAKE SW
CRUISE SET SW
CRUISE RESUME SW
CRUISE CANCEL SW
CRUISE INDICATOR
CATALYST
Heated Catalyst
EVAP
Secondary Air
O2 Sensor
O2 Sensor Heater
EGR
Nice googling ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
It seems that the HIM can be used to monitor all these same items as well. Only differences I can find right now are that the HIM is the older version and its a bit slower then the new GNA600. Plus the HIM as opposed to the GNA600, can be bought new on ebay from china for around 200$.
Sure it seems like a bulky item and since you need a laptop to view everything I can see how it may be obnoxious to use while driving. But it looks like this would work perfectly with a small netbook sitting where the cup holders are and the HIM unit tucked neatly under the dash.
Any info on the HIM unit Inaccurate? I messaged a few of these sellers on ebay regarding the HIM unit. Do you see anything wrong with purchasing the HIM unit I listed below, connecting to a laptop and starting to data log?
I do see it uses a rs232 port but a simple rs232 to usb adapter should do the trick
http://cgi.ebay.com/ebaymotors/OBD2-...motiveQ5fTools
I was planning on buying the HIM (honda interface module) to work with the hds.
However, the HIM can only be used while the vehicle is stationary. It does not record live data so I dont think I want it anymore. The gna600 is too expensive also
Right now Im looking at AutoEnginuity with their pc based scan tool. If I do buy this, I will be buying the enhanced honda expansion so I can have access to the advanced parameters such as knock. Not a bad price if you consider what a regular data logger costs and an aftermarket knock monitor.
What do you think?
What do you think?
Who told you the HIM only works while the vehicle is stationary?? I am constantly using my HIM/HDS to monitor all types of things...EGR lift v command, STFT, knock, etc etc etc.
I've use the Chinese knockoffs and they work identical to the Factory HIM units...jujst get a small laptop that's Windows based to run the HDS software on.
One of the merchants on ebay told me that. Damn. I wanted the HIM to data log and monitor knock. Too bad I already bought the autoenginuity scan tool. Now I have to buy the honda enhanced parameters also
I guess you have the HIM wired into a 12v source? Or maybe into the cigarette lighter?
experience with cable only HDS?
I've seen the HIM and GNA600, and FLY100 but for a lower price I've also seen a cable only version that connects your car directly to a laptop which runs the HDS.
Does anyone have any experience with this?
I'd like to find out if it has the same functions as the HIM since it costs about $125 less.
I'm glad the HIM will gather and show real-time data - thats what I need
This is a picture of the cable only version I mentioned:
![](http://i.ebayimg.com/24/!Bzgd+egB2k~$(KGrHqMOKnQEw9MocTSVBMW(v7Zv4w~~_12.JPG)
Obviously it's not the same thing as the HIM but does anyone know if it will function like an HIM when plugged into a laptop with HDS?
Hey just wondering how you got the chinese HIM scanner to work ? Do you have plug into a 12v? Are you running XP operating system ?
Thanks for your help! I got a HIM laying here which I cant seem to get it to work!
No need for 12v power, it’s powered via the diagnostic socket. Led’s should light when you plug it in. I have run this on XP- Vista-64 and Win7-64.
ECU Flash Updates/Programming
I know this thread has been dead for a while however I've recently become very interested in getting either an HIM/GNA600/MVCI...I know the MVCI is the latest but also pricey...seeing as how I'll only use it occasionally seems like a lot. ANYWAY my question is...if I buy one of these can I update my 05' TL ECU...or are there even any updates to the ECU available? Is there any benefits? Can I tune anything?
Seeing as how I can update/(occassionally mod) the software on my iphone/router/tivo...why not the car??? lol
I checked out the serviceexpress.honda.com website and they want $155 to rent the HIM for 3 days (when you can buy it on ebay for $200....
) and seems like there are a lot of features the tools offer. My car is at 120k...never had a check engine light - so not doing it out of necessity. However doing a timing belt this weekend and looking to follow the HDS steps in the service manual regarding relearning CKP patterns/etc.
I am very proficient with computers/electronics to mechanical...however very much a n00b to tuning/updating any ECU. Thoughts anyone?
Thanks.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Thanks.
This is how you fix the idle problem
before you make any changes on you car to any sensors that has to send a fedback to the ecu take note so you can adjust like the tb position sensor has 2 sensor tb position sensor b and tb position sensor b the ecu use ther minimum value from this sensor to control the idle so before you take you factory tb out note the value from this sensor with the ignition on but don't start the engine then put you zdx or tl shaw tb and look at the value to tb position sensor a and b and you will notice it come set from factory to a higher value then your factory and that what make the bad idle in this mod. Just adjust the screw in the back of the new tb and make the bombers the same as before when it has the factory tb.
Jamus22
06-11-2023 10:08 AM
4drviper
09-23-2015 09:00 PM
