Greddy 03 Accord Strut Bar Installed
#41
2007 NBP TL
Originally Posted by Meek32v6
its a sock.lol....
that catches your cars ball sweat
"The Spoon Sports Reservoir Tank Covers help keep your engine clean by absorbing master cylinder and clutch reservoir tank leaks. The high quality plush covers feature an embroidered Spoon insignia for durability. Made by Spoon Sports Japan."
![HaHa](https://acurazine.com/forums/images/smilies/haha.gif)
#42
I like to whistle in my
haha...but for real they are cool and a cheap mod if you wanna call it that. Looks nice in the engine bay if you have one with the shrouds removed. More effective if you really drive long term and hard where the pressure might acutally build up to the point where they might overflow
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#43
.43g at 900+fps
so my uncle is a machinist and i drew a template using cardboard for a strut bar plate. we're using 1/4" steel and the three studs from the strut mount plate. hopefully i'll have the plate later today. then i'll see how it fits. after i fit it, i'll post the template online. i'm using a tanabe rsx strut bar and i'm making my own mounting plate. i'm sure it would be a lot more convenient using the greddy, but for some reason i have an issue with just the two bolts that greddy uses. tanabe uses three, and it allows for an adjustable preload on the bar. the design looks better and feels better. that's just me. i'll let you guys know how it goes. i'm not trying to make an enterprise, so i'll post the template up for the rest of you guys to share. you just gotta know a good welder and metalworker to help fabricate these things. i'll be in touch.
#44
.43g at 900+fps
btw, i need the measurements of how high the edfc is from the body of the car, and the width of the edfc. i don't have the edfc, but i'm planning on purchasing it. my wife is complaining that she is pissing blood.
#45
tehLEGOman
Received 1,982 Likes
If you use the greddy bar it will be possible to use four or five studs if you weld a circle to the bottom of the endplates.
#47
OMGWTF4THGENTL
Is it just me?...
After i installed the Greddy bar I couldn't reinstall my Carbon Fiber engine plenum cover. You can see Accuratein's engine cover clearly touching/rubbing the Greddy bar in the picture.
Are you guys trimming these things back to keep them from rubbing?
![](http://img217.imageshack.us/img217/8572/dsc018101zh.jpg)
#49
OMGWTF4THGENTL
Dude... what do you want to know?
If you're OK with only using 1 mounting point per side, then it's a 10 minute install. Just unbolt the 6 nuts and the 2 screws holding all the plastic shit to the stock bar, and bolt this one on.
If you want to use BOTH mounting holes as designed, you have to remove the front struts, drill 1 hole on each strut tower, replace the front stut top hat from that of a 7th Gen Accord and bolt it back togther.
There's absolutley no reason to do this mod though... I think it's probably a bit "weaker" in design than the stock bar. Almost anyone running the Greddy bar does so because it's the only bar out there that will allow you to install Tein's EDFC motors. The alternative is to cur the stock bar to allow for the motors to fit, but that weakens the stock bar greatly.
I no of NOONE here running a DC Sports upper bar.
Use a little searching on this topic, especially before you order stuff.
#50
tehLEGOman
Originally Posted by bcbtony
Can Some 1 Help Me Out Tell Me If The Dc Sport Will Fit Because I Just Ordered It
Let us know how the install goes once you receive the bar.
#51
tehLEGOman
Originally Posted by Kennedy
Is it just me?...
...but when it was one the engine that strut bar would sit flush on top of the cover so i'm not sure why its not working with your CF one.
#52
Received 3,763 Likes
did you get new top hats yet man. attach that bar with two bolts already man.
#53
tehLEGOman
...Guess what type of Cusco product i'm about to install? You'll never guess but it's inside the cabin.
#54
Originally Posted by ACCURATEin
haha you know i'm way to lazy to take the struts out just to install some accord hats. The car handles like a Ferrari Enzo FXX son. (not really but i can pretend.)
#55
tehLEGOman
it cant be a roll cage cause they dont make one for your car.
It's something that cusco makes for a DC-5.
#57
tehLEGOman
Originally Posted by lookinco
OOoOooOoOoOo.........wat is it wat is it?
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
#58
07 WDP TL
1 Post
If you ordered the DC Sports strut bar intended for an 03 Accord then yes it will fit. Any other application not so much.
#59
1 Post
Correct and Correct.
#60
tehLEGOman
yes i boght the 1 for the 03 accord so you sayin it will fit thnaks man
#61
tehLEGOman
Originally Posted by shayan
soooo, what is it? what is it? I really want to seee.....oh man im soo excited
#62
tehLEGOman
For those concerned with the lack of mounting points, there is more to be had with this greddy strut bar. Simply find two metal rings that will fit around the strut hole, and then drill the respective holes for the studs in the rings. Next, have the rings welded to the bottom of the greddy strut base. Paint the new base, and voila!
#63
tehLEGOman
Attn Greddy Performance:
This could be done easily: Add some endplates to the current Accord strut bar that look like this...
If you make it, they will buy. (If you build it, they will come)
![](http://img252.imageshack.us/img252/254/greddystrutbardw2.jpg)
cycdaniel
12-17-2019 10:58 AM
acurajj
02-14-2016 02:28 PM
