Got J-Pipe?
AZ Community Team
Received 7,770 Likes
Got J-Pipe?
Just got mine in yesterday. With the help & hospitality of mmade22 ( ).
Great fit, great design: Props to Mike at ATLP. Bolts in super smooth. And you can see where the gains come from: much less flow restriciton.
Great sound even on a modded stock exhaust. It's a nice low/deep growl that starts at lower RPMs and carries on through VTEC to the redline. The intake noise doesn't overwhelm the stock exhaust anymore; more of a 50/50 split. Awesome!!.
Between this and the UR Pulley (also installed yesterday) definite gains in the low and mid RPMs.
Installed:
Installed:
v 4910shp/19,600ft-lb v
tehLEGOman
Received 1,982 Likes
ROFL at your signature!!! hahaha.
I'm glad the install went smooth for you guys.
AZ Community Team
Oderint dum metuant.
I wondered if you'd be doing this this past weekend. Nice. You painted it (can't see the pics)? Huh...interested in seeing that. How was the crank pully install?
Oh, love the signature!
zaino'd
I think that no matter what type of "protection" method you use against rust/corrosion, the smallest scratch (rom a speed bump or a small pebble) thru the protective layer and you're toast. Plus, bolting down the flanges will break thru the layer too, I think.
Obviously its MUCH better than leaving the pipe bare to the elements.
Did you use a spray?
AZ Community Team
Absolutely right about the nuts/flanges. I figured it couldn't hurt. Whether it lasts or not .... hope so , but, meh, whatever .... worth a few bucks and an hour or so to fool with it.
Yes, spray:
- Cleaned with Brake Parts Cleaner.
- Scuffed with a ScotchBrite Pad (green).
- Cleaned again with Brake Parts Cleaner.
- Taped off flex pipe & mating surfaces.
- Primed with VHT Header Primer (gray).
- Painted with VHT Header Paint (flat black).
AZ Community Team
I agree, the polish on the RV6 parts is hella nice.
Turd Polisher
Good to see you around Bearcat! And more importantly .. good to see you installing more performance mods!
AZ Community Team
200,000 mile club
Nice write up Bearcat. Had a lot of fun with the mods and even more fun driving your car crazy to get the pizza. Love the new Signature. You forgot to put the Lambo doors that we installed this weekend.
AZ Community Team
Basically, we did what you suggested: Got the hanger on the J-Pipe, loosely connected it to the car, then got the J-Pipe ports in place, loosely, then tightened everything down.
mmade22 - signature fixed. Thanks.
Received 6,470 Likes
Bearcat,
You and mmade are an awesome pair. You guys should go into the performance parts installation business on the side.
I want to see the Lambo Doors, the custom "Porshe Style" Rear Wing a the dual racing stripes!!!
BoricuaTL
04-08-2016 01:08 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
ExcelerateRep
10-14-2015 08:20 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
