Fujita CAI Question
Old Jan 26, 2008 | 10:38 PM
CBPType-S08's Avatar
Fujita CAI Question
I am interested in putting a CAI on my 08 TL-S. I also plan on installing the P2R Spacer. I have read in a few posts that the Fujita has problems with clearance...with the fog light. Is this limited to Fujita. Is there a fix to this problem? I know that there are numerous threads about CAI's, but I couldn't find much guidance on this particular situation. If the clearance issue is really that big of a deal, I will just spend a couple of extra bucks for the AEM. Any help would be appreciated.
Old Jan 27, 2008 | 12:44 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I'm not trying to sway you either way, but I have a P2R TB Spacer and an AEM CAI, and I got them both to fit, with some minor wiggling. The vibration mount isn't fully on (meaning tight), but I've had the spacer for a couple months now and the vibration mount hasn't budged. Just use this as a reference, since you now know for sure that the AEM CAI and the P2R TB Spacer do in fact fit, with some minor fitting!
Old Jan 27, 2008 | 01:19 AM
You're the man!!! What type of performance gains have you noticed?
I am going to PM Excelerate right now to buy that setup...sounds like the only way to go. What are your feelings?
Old Jan 27, 2008 | 07:25 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
if you go with fujita you will be ok, I found this out after I cut the tube, you have to relocate a ground wire and use the vibra mount there, the intake will be about 10mm away from the fog light
Old Jan 28, 2008 | 01:47 AM
I noticed, between the two, the most gains from the TB Spacer. It definitely gives you more low-end torque. The intake is great, and it sounds great, but I think I noticed a difference in sound the most, to be honest, lol, but I'm not complaining! . Regarding the intake, though, you immediately notice the difference in the gas pedal.
Just a suggestion, but it will benefit you to reset your ECU as soon as you get your mods done. I recommend that this be done after every performance mod. You can find instructions on it by doing a search!
Old Jan 28, 2008 | 01:49 AM
Yeah stillhere153, all of the intakes will work (Fujita, Injen, AEM) with the P2R TB Spacer, but there are no extra modifications necessary with the AEM.
Old Jan 29, 2008 | 08:31 AM
Thank you guys for the responses. I think I will probably just go with the AEM, since it sounds the simplest...and most popular choice among members of this forum. I am going to get both from Excelerate. Does anyone have experience with the TB thermal gaskets? I think I am going to go ahead and get the whole package, but I was curious what other members thought about them.
Old Jan 29, 2008 | 11:18 AM
Excelerate's Avatar
Former Sponsor
The Throttle Body thermal gaskets are necessary to make a seal. If you don't use them then you need OE gaskets. However, the P2R gaskets are made out of a proprietary heat-resistant material which reduces heat transfer from the intake system to the plenum or vice versa.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
lanechanger
Oct 13, 2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
