First Mod You would do on a 2008 TL-S?
ive had my TL-S for over 6 months and have wanted to mod it, but havent had the time with college, work, etc... now its almost over and i have the entire summer to mod my TL-S. i would post pics but its basically a black factory TL-S
. i want to improve its performance (not saying its bad, its actually real good but theres always room for improvement) but i hardly know much about cars when it comes to mechanics (engine). audio i can do, but mechanics i never learned (unfortunately since i love cars). so i need some advice from experienced modders. what do you think should be the first performance mod? im mainly aiming for better traction (cuz its garbage) and higher speeds. appreciate all your help. oh but the only problem is, its automatic
so its more limited to mods.
Side note: im not one of those kids with rich parents that buy them anything they want. i had to work my ass offfffff to buy get this car. and still am working just to pay off its bills (financed). only because this has been my dream car since 2004.
so its more limited to mods. Side note: im not one of those kids with rich parents that buy them anything they want. i had to work my ass offfffff to buy get this car. and still am working just to pay off its bills (financed). only because this has been my dream car since 2004.
This isnt more towards engine performance, but rather handling.. How bout a Progress Rear Sway Bar? Many have stated the install is easier than counting beans and the handling is noticeably improved.
Another one, is probably some outlaw thermoblock spacers? costs like 100 dollars, and it is fairly easy. There are some threads on the how to of it, and it appears to be easy enuff.
Um, the other is probably a P2R throttle body spacer...that one has a diy video!
I think those are like $120.
Oh yea, and CAI, that one has a lot of diys! Hopefully some of this helps, and happy modding and welcome!!
I think those are like $120.Oh yea, and CAI, that one has a lot of diys! Hopefully some of this helps, and happy modding and welcome!!
ankur914 pretty much summed up the usual 'first mods'.
Other options may include getting a spoiler, type-s tails with side markers, roof spoiler, tints... the list can go on.
Originally Posted by paliknight
oh and is the TL-S turbocharged, supercharged, or neither?
you have a type-s correct? then why are people tell you to get type-s tails and deck lid ifyour car comes with it?
is your TL-S a 5AT or 6MT?
if MT then short throw
and HID fogs if you need some more light
let me clarify for the OP:
The Type-S cannot be supercharged at this moment, there is no current tuning available for it, but it will be in a few months.
These are the mods that would good for you:
progress Sway Bar - this will reduce the body roll when making turns.
A-Spec suspension - Factory Accessory, this will lower the car about .5 inch and will make the ride firmer and sportier.
Tein Suspension - will lower the car UP TO 2.25 inches (you can adjust it) and the ride can be adjusted to feel like factory or brick hard.
P2R spacer - reduces heat transfered to the air so air is cooler, which means a little more power.
Outlaw spacer, does the same as above, different location though.
UR Underdrive pulley - this is good for increasing the Pep that the car has when you punch it, this will not work if you are getting an aftermarket audio system in excess of 1000 watts
Cold air intake - allows the car to breathe in colder air easily
Also some free mod's you can do:
Weight reduction: remove the covers in the engine bay, the spare tire and jack, some of the trim in the trunk and so forth.
navi hacks: you can have the start-up image changed.
Here are the best ones for you at the moment:
Weight reduction
Cold air intake
Later on, you should add:
Progress Sway Bar
Spacers
UR Pulley
After that, if yo have money, go for the suspension set-ups.
Sometime when you have the money, upgrade the rims and tires to a stickier, lighter setup.
Weight reduction
Cold air intake
Progress Sway Bar
Spacers
UR Pulley
Hey, my young freind, I am/was in the SAME boat you are.
No real mechanical experience, but an itch (thanks the AcuraZine Disease) to mod the TL-S.
I started off real simple: Navi Startup Screen Hack and Interior/Reverse/License Plate LED's.
Did the P2R Throttle Body Spacer next.
Then "Stage 3" Exhaust (more for sound, no gains to speak of) - that was "outsourced" to a muffler shop.
Then Progress RSB plus H&R Sport Springs (with some local help).
The TB Spacer and RSB are good places to start. Pretty easy.
The Springs aren't hard, you just need some help with the seats and spring compression, etc.
Unless you plan on driving in a straight line all the time the RSB, Springs and Shocks (or a Coil-Overs) ARE Performance Improvements. My traction is better and understeer is reduced.
Next up CAI.
Exhaust is pretty easy since they generally bolt to the stock locations, but relatively expensive (say $800+). Tires/Wheels are easy too, but again pricey.
Next up CAI.
Next up CAI.
Next up CAI.
you must know how i feel then. i hate being oblivious when it comes to something i love. i will be taking a course in the summer though about car engines, hopefully it will help. back to topic, i dont really care much about how it sounds, more about its actual performance. but i will look into your suggestions, thanks for your help. after testing the traction again on the car tonight, im still frustrated. how can acura create the car with so much acceleration with insufficient traction to support it.
and especially when i increase the performance, the traction will worsen unless i make it better. i dont really want to lower the car much because in my area there are a lot of hills, and it will scratch the bumpers if the car is too low
oh and any suggestions for tires with the best traction? also, can you provide links to the parts you named?
1 more thing, since ive never done any work on cars (performance wise), ill have to have professionals do it
Weight reduction
Cold air intake
Progress Sway Bar
Spacers
UR Pulley
Weight reduction
Cold air intake
Progress Sway Bar
Spacers
UR Pulley
thanks for your your advice and everyone else too. and im installing an aftermarket system with 2000 watts so i guess no underdrive pulley.
dude you can still get a UR pulley, they make a stock size diameter version which is still much lighter than stock pulley and almost make the same difference as the unuderdrive one.....you can run a aftermarket system with it....dont understand why the post above didnt state that.
To the OP, I have the exact same car as you and am contemplating the same mods. I'm currently wrestling with tire/wheel choices but I would definitely recommend upgrading the OEM Michelins...even if you stay with the stock TL-S wheels...which I really like. A mild drop is also a relatively small investment/big payoff mod in terms of looks and performance.
anyone have any advice on how to go about this? for example, where is the best place to buy the parts from, where should i get them installed (acura dealership service center), etc...
Originally Posted by Tripnbeats
dude u know.....since ur still bustin ur ass to afford this car and doin ok at it, id leave it or go with something simple... intake, pulley, HIDs...IMO
Excelerate in the group buy section should have most of this. Try installing them yourself, the installs are pretty easy and there are a bunch of DIY's on here. If not, go to a local place that does work on cars, labor will be much cheaper there.
I am not sure if you would even consider this a mod but before I even took the car home from the dealership I had them remove/mod the car by taking off the ugly side body moldings and some ugly pin stripes.
what can i say I love cars with clean lines. thats one reason i may never go with the 07 tl type-s lip kit.
D
D
damn i need to get my knowledge of cars up there. i need to take some classes. oh and did you guys buy the UR pulley, Progress RSB plus H&R Sport Springs, etc... from local shops or online?
Originally Posted by ballinfizzle89
lol....
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
