Finally, some front urethane bushings (possibly....I don't know-it's a question)
1. front lower control arm.
are all 3 of our bushings (compliance, rear, and shock mount) compatible with 7G accord?
2. front upper control arm
are the 2 bushings compatible with 7G accord?
if so..... tada~
http://www.superpro.com.au/find-supe...on/25-229-2003
thougth this should be separate from compliance bushing thread
if so..... tada~
dunno about the compliance bushing but i remember checking the other bushing on the lower control arm, the one supporting the shock, that is exact same part # as the 7th gen accord one
never been a fan of urethane bushings. I find they go out of shape just as quickly as rubber if you track the car.
You should look into the PCI Spherical Compliance Bushings for the TL as this is the bushing that goes the easiest. Good luck on your search.
i thought all three cars use 74mm outer diameter bushings..?
do you think it will hold up well against toronto salt??
I am in the market for new bushings as well..
My buddy who has polyurethrane bushings for his Lexus IS300 said it made a huge difference and he loves them.
I am thinking of giving them a try and found that SuperPro might make them for the 3G TL.
Are these the ones I want?
http://www.superpro.com.au/find-supe...rt?id=SPF2947K
