Factory IM Spacer - 17108-RDJ-A00
Old 05-29-2009, 06:14 PM
  #81
beachexotic03's Avatar
Originally Posted by Dave_B
I have the 5/16" MD spacer on my G35 (same as the 350Z) and I know Tony, the engineer/owner that developed the spacer. The intake manifold on the VQ is split in two, right in the middle. When you lift the top cover, there are six air horns that are attached into the intake runners. It's much the design like you'd see if you were take a part a BMW M-series intake manifold, minus the individual throttle bodies. The spacer goes between the two intake manifold halves, essentially increasing the internal volume of the intake manifold and letting the front two air horn/runners breath a bit better. Here's the rub though, the spacer is only 5/16". MD also makes 1/2" spacer, which makes 2hp more, but it neuters low end power a bit. Tony has tried numerous spacer setups, as well as other companies, and the ideal set up is around 5/16". Tony is an ex-aerospace engineer and one of the few aftermarket parts manufactuers that tests his products. He has tested all spacer heights and basically anything over 1/2" kills power.
This is where you guys have to be careful. For one, the spacer you're adding isn't increasing intake manifold volume. You're increasing intake runner length. There is a difference. Longer runners increase low/mid range power, but don't breath well in the high rpms. That's a fact. Secondly, you're adding a decent amount of runner length so you could be hurting topend power by a few hundred rpms.
Now, it is quite possible that this spacer will improve the overall power curve, even though some topend power is lost. The only way to be certain that the mod is benefical is to do a before and after dyno and then do a average hp calculation for the power band. If you've got more average power, you'll be faster.
HUMMMMM! Well lets see. SBC with torker intake manifold gains 34whp. and 30wtq. And that is a 4inch increase over stock. I'm not going to sit here all day and have a pissing match with you but, I'm sure honda puts it on a J35a for a reason. Honda tuning did a J35a swap and lost WHP and TQ in the mid by removing it. Simpley because they couldnt get traction in their civic. here is the link! http://www.hondatuningmagazine.com/t...s_engines.html
Old 05-30-2009, 12:05 AM
  #82
Dave_B's Avatar
Originally Posted by CleanCL
I can tell you the operators were not keeping the numbers low. That's laughable. What reason would they have to keep them low? Their not selling parts, they were modifying their own MDX. Right.
Anyway, I guess you never looked at the RDX and 04+ RL AWD dynos. The SH-AWD gives dynos many headaches as the system is far more complicated than that of the G35X. The TL and MDX dynos are on par with that of the RL. It's just the way these cars dyno. Everyone seems to love to live by the dyno number. A dyno is a TOOL. It's just a number. It's laughable when people walk around saying my car made 300whp on a dyno. Please. All that matters is that it's a tool used for tuning and testing modifications. Dyno queens please exit.
Okay, so the operators weren't keeping the numbers low, so my other proposed theory sounds spot on. The Honda AWD system flakes out when it's on the dyno. How exactly am I wrong again?
You're right, the Honda AWD system is far more complicated than the Nissan ATTESSSA AWD because Honda continues to bandaid the TL to make for the fact they keep making the damn thing FWD. The ATTESSSA AWD is very advanced (remember same one found in the GTR), but at least it doesn't flake out.
Yes, dynos are tools. I preach the same thing, but those TL numbers are retarded low. I'm pretty certain when a few more TL AWDs dyno, the numbers will be higher and more realistic.
Old 05-30-2009, 12:35 AM
  #83
CleanCL's Avatar
If you bothered to read the thread and look up the dyno we used, you would realize this particular dyno is one of the lowest reading ones out there, lower than a mustang. Some more reading material on the 'band aid' SH-AWD system and a dyno.
https://acurazine.com/forums/2g-rl-2005-2012-76/my-rl-dynoed-numbers-pix-movies-499226/
https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/dyno-715286/
The whole point is that I showed dynos side by side, a 3.5L motor w/ a spacer and a 3.7L without a spacer. The numbers and graphs are there for all to read. They can make their own decision about whether the spacer hurts power.
Old 05-30-2009, 09:04 AM
  #84
Former Whyner
RonJonTL757's Avatar
updates anyone??
Old 05-30-2009, 10:18 PM
  #85
Dave_B's Avatar
https://acurazine.com/forums/showthread.php?t=499226
https://acurazine.com/forums/showthread.php?t=715286
Yeah, I know, they're Mustang dynos. They do read a bit lower. The RL is making more in line with what it should on a Mustang. You TL is way too low. I can't believe the guys at DG Motors blatently state they don't "correct" the numbers. Correcting numbers isn't for bragging rights. It's an SAE standard which corrects the numbers to atmospheric conditions. This ending number allows to compare your runs (on the same dyno) between different days when conditions might be different (ie temp, humidity, baro pressure). They all play a HUGE roll in how a car performs.
Old 05-30-2009, 10:30 PM
  #86
94 DC4 RS LSV/Turbo
stillhere153's Avatar
mmmh I guess I had overlooked the honda-tunning article mentioning the spacer... so it turns out my theory is correct
for those w/ full flowing exhausts... this is the perfect upgrade to force the tq curve to recover some lost low end tq
Old 05-30-2009, 10:52 PM
  #87
E55>>>TLS
dr_brains510's Avatar
When are the before and after dyno's being done?
Old 05-31-2009, 10:10 AM
  #88
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
IIRC, Nueronbob's AWD RL had 30% DT loss. 45% is , no matter what dyno you're on. A "tool" is no good if it won't do the job right; IOW - I wouldn't trust these runs, they are way out in left feild. (MHO)
The longer running length could harm power, but I'm skeptical. I understand the reasoning behind this, but let's take a look at some information.
2009 MDX Bone Stock showed 159whp and 144torque
2009 MDX with K&N Filter and Full Catback Exhaust (stock primary cats) showed 191whp and 170torque
2009 TL-SHAWD bone stock showed 165whp and 145torque
So with the big spacer, the 3.5L made slightly less horsepower than the 3.7L, while both made close to the same torque. ....
I don't see where the MDX numbers show whether the spacer helps, hurts or is neutral. None of the cars above have a 3.5L or the fat IM Spacer.
2009 MDX is running a 3.7L with 11:1 compression and no "big" spacer.
You need to look at 3.5L v 3.5L with and without - 2006 MDX v 2007 TL-S for example. Even then, you've got issues as the '07 was tweaked.
Best is a new dyno TL with the spacer and without.
Old 05-31-2009, 06:41 PM
  #89
CleanCL's Avatar
I confused myself in that both are 3.7L. The dyno on the TL was brought up to 6100 rpm, where peak HP is at 6300... so the number would have been higher. There was nothing wrong with the dyno, you guys need to look up the differences between Dyno Dynamics, Mustang Dyno, Dyno jet, Dynapack, etc.
When I checked with Acura parts the latest generation of MDX was using the spacer, if not then I apologize for that mistake.
Old 05-31-2009, 08:47 PM
  #90
94 DC4 RS LSV/Turbo
just to note the 09 mdx is running the same intake manifold as the tl-s
Old 05-31-2009, 09:54 PM
  #91
AZ Community Team
Bearcat94's Avatar
Part# 17108-RDJ-A00 is only on the '03 - '06 MDX according to http://www.acuraautomotiveparts.org/...1=&inputstate=
They do not have up-to-date parts info for some of the '09's.
17105-RCJ-A01, the IM Gasket for the '07 TL-S is also used in:
MDX '07 - '09
RL '09
TL '07 - '08
Old 05-31-2009, 10:03 PM
  #92
94 DC4 RS LSV/Turbo
refer to estore.honda.com
the im gasket is the same for all of them... if there are 3 cats on the v6 motor the im gasket is the same
Old 05-31-2009, 10:38 PM
  #93
CleanCL's Avatar
MDX '07 - '09
RL '09
TL '07 - '08
Interesting... also a quick check it looks like they did away with the spacer on the 3.5L Odyssey too. Well hopefully someone will follow through with some dyno tests on the 3G TL to see what it actually does.
Old 06-01-2009, 02:15 AM
  #94
Exclamation
Originally Posted by RonJonTL757
If I was to do this would I need those oem gaskets and ditch my P2R gasket? Reason why i ask is post 1 AL mentioned sandwiching between 2 P2R gaskets
I measured both thermals can work.
Old 06-01-2009, 04:44 AM
  #95
94 DC4 RS LSV/Turbo
I figure you really don't need the thermal spacer since this spacer is sooo thick... but running 1 on the motor side wouldn't hurt I guess
Old 06-01-2009, 09:05 AM
  #96
Dave_B's Avatar
I did a quick scan and it looks like the camshafts are different between the TL and MDX which may or may not influence how the motor behaves with/without the larger spacer. Just another thing to keep in mind.
Old 06-01-2009, 03:00 PM
  #97
av6t's Avatar
i dont think it was mention if this work on a 04 TL or not? if not, what can i do to get it to work. thanks
Old 06-01-2009, 03:36 PM
  #98
OMGWTF4THGENTL
Kennedy's Avatar
Ugh...
Old 06-01-2009, 08:49 PM
  #99
Wink
he
Bolts up for a 3.2 runners. I'm not sure if it will bolt up to older style. I have pictures of everything together. I'm making a nice DIY for all the people with questions. I'm including dyno numbers as well. Please wait to find out. Everything is bolted on the car starts pulls really flipping hard. I loose traction in 3rd gear with auto mode. About 2,900 the car breaks free.
I'm also most postive i'll be in the 280whp on a mustang dyno only time will tell. I couldn't get to pure tuning last week or the week before really busy with school work. I'm going this weekend hopefuly to get the pictures of me on the dyno and the dyno numbers! I'm going to be before and after install of the spacer.
Old 06-01-2009, 09:53 PM
  #100
AZ Community Team
Bearcat94's Avatar
Excellent!!
Looking forward to your numbers.
Old 06-01-2009, 11:00 PM
  #101
Bored at work
tl2slow's Avatar
i cant wait neither..i get my car back from the paint shop tomorrow ...and i got the spacer in today....thanks CleanCL ...wheres the nearest dyno by me????
Old 06-02-2009, 01:40 PM
  #102
jsacuratls's Avatar
hey everyone how about putting two off the spacers under the plentom that would probably give you a big .i went to acura today and the spacers are 43 each so guess what i bought two off them hahahahahahahaha. every thought about putting an 09 mdx intake plentom on the tl it will probably work and their not that expensive to. i think like under 200
Old 06-02-2009, 01:48 PM
  #103
Mjakaz09TL's Avatar
WOW 2!?!? Good luck shutting your hood and finding bolts long enough
Old 06-02-2009, 01:52 PM
  #104
jsacuratls's Avatar
you ever heards off home depo or lowes im sure they have lots off bolts that would work and i think i figure something out with the hood
tech 575 hendrick honda
Old 06-02-2009, 02:04 PM
  #105
practicing nihilist
NedShneebly's Avatar
-27 for spelling and grammar
Old 06-02-2009, 02:08 PM
  #106
Full of water...
blkaspec's Avatar
Old 06-02-2009, 02:42 PM
  #107
jsacuratls's Avatar
Originally Posted by blkaspec
yeah yeah i no i cant spell sry.
more like a -50 right
tech 545 hendrick honda
Old 06-02-2009, 02:50 PM
  #108
CleanCL's Avatar
He has a point, sort of... anyone ever thought about stacking 2 Outlaw spacers? You can get any length/thread bolt you want from boltdepot.com... just saying.
Old 06-02-2009, 02:52 PM
  #109
practicing nihilist
I thought it was kinda a joke at first! I mean, how many are you going to stack up? I'm sure it's diminishing returns at some point and who wants a 1" gap between their hood a front 1/4 panels?
Old 06-02-2009, 02:57 PM
  #110
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
lol thats what i thought...
Old 06-02-2009, 03:02 PM
  #111
erick3's Avatar
so what's going on here? lol
Old 06-02-2009, 03:06 PM
  #112
jsacuratls's Avatar
im not going to put 1 but 2 off these spacer on my tl thats wats going on lol
Old 06-02-2009, 03:07 PM
  #113
jsacuratls's Avatar
what about putting 2 throttle body spacers on to is that an option
  #114
erick3's Avatar
i thought the clearance issue made this a no go?
Old 06-02-2009, 03:33 PM
  #115
jsacuratls's Avatar
screw clearance issues if theirs a will theirs a way man
Old 06-02-2009, 03:35 PM
  #116
Clearance is good. I used 8 washers it clears fine.
Old 06-02-2009, 03:36 PM
  #117
Fulani has a TL's Avatar
Al was sayin you could use some spacers to space the hood up more, but dont know how it would look
Old 06-02-2009, 04:21 PM
  #118
practicing nihilist
can you post some pics of the hood spacers and clearance mod you did?
Old 06-02-2009, 06:24 PM
  #119
jsacuratls's Avatar
i guess two spacers it is lol hahahahahahaha who will be the firstg to do two
Old 06-02-2009, 06:59 PM
  #120
94 DC4 RS LSV/Turbo
here's an extreme pop
Quick Reply: Factory IM Spacer - 17108-RDJ-A00
