Factory IM Spacer - 17108-RDJ-A00
Old 05-22-2009, 01:15 AM
94 DC4 RS LSV/Turbo
stillhere153's Avatar
Yes... thats correct... an Intake Manifold Spacer from the factory for pretty friggin cheap
sandwich this in between 2 x p2r IM gaskets FTW
It comes standard on the MDX/ODYSSEY/PILOT so why not rock the higher tq IM spacer on the TL
yes I might have left, but I've been doing some v6 research for whatever reason
here's the diagram... speaking of part # 3... looks like you will need to get longer IM bolts {part #24, need 7 of them 95701-08105-08}... which are like $2 a piece... you will also need to get hood spacer bushings to raise the hood a little to clear it (theorized by Richie v6)
ps. will also require 92900-08060-1B (2 of them) which is the long stud on the intake runners
Old 05-22-2009, 01:34 AM
Rev High; Drive Happy
o4Komodo's Avatar
Interesting. Nice find.
Old 05-22-2009, 03:16 AM
Being an Acha Bacha in
Elegant TYPE S's Avatar
Fogive my laziness but what is this do again? Because most people adding the TB spacer said they noticed nothing.
Old 05-22-2009, 03:32 AM
94 DC4 RS LSV/Turbo
the people who said they noticed nothing have never pushed their car pre and post
this will yield a massive tq increase
Old 05-22-2009, 03:43 AM
o4Komodo's Avatar
If the intake manifold is raised due to the spacer, wouldn't that cause fitment issues with a cold air intake?
Old 05-22-2009, 05:57 AM
beachexotic03's Avatar
Nice!
Old 05-22-2009, 06:40 AM
Green Machine
t0talacuratl's Avatar
Wow Al! Great fine! Why would Acura have this available for the MDX, but not the rest of the ac's (namely TL's)?
Old 05-22-2009, 07:45 AM
CleanCL's Avatar
I looked into this a couple years ago... I think you might have hood clearance issues or at least we did in the 2G CL side. I actually have this exact spacer for 04+ TL sitting in my closet if anyone is interested in trying it out on a 3g TL?
Old 05-22-2009, 07:49 AM
Full of water...
blkaspec's Avatar
how much $ does the spacer run?
Old 05-22-2009, 08:14 AM
Bender's Avatar
bump
Old 05-22-2009, 08:36 AM
Oderint dum metuant.
chill_dog's Avatar
Originally Posted by Bender
bump
And the point of bumping this thread twenty minutes after the last post was???
Pick up the one CleanCL has; it'll probably be less than at the dealer.
CleanCL's Avatar
It's about $20+s/h, but don't forget you need the longer bolts as well.
I'll sell mine for $20 shipped... I thought I had the bolts too, I'll check. PM me if anyone is interested.
Old 05-22-2009, 10:57 AM
94 DC4 RS LSV/Turbo
yeah I think there will be some hood clearance issues, richie v6 mentioned this, and I pointed out you can do what everyone else with itb does.... and get a set of hood spacer bushings which raise the hood about another 10mm and also you remove the rug under the hood and replace it with some heat reflective gold film or spray it with some heat coating
as for cai fitment, you just get a bracket from like radioshack.. and just keep the vibramount in the same place... its not that big of a difference honestly...
can someone test out and see how much clearance there is under their hood... get a coke can place it on top of the IM and close the hood..... depending how crushed the can is, thats how much clearance we got
Old 05-22-2009, 11:06 AM
o4Komodo's Avatar
Hmn, off topic but is Radio Shack still called Radio Shack in the States? It's called "The Source - By Circuit City" here in Canada.
Anyway, awesome. I thought there may have been an issue with CAI fitment as the throttle body would probably be raised as well. I can go do the can thing in a bit hahaha.
Old 05-22-2009, 11:18 AM
2009 g37s 6mt
ssmtl2nv's Avatar
thanks Al gotta c if it's worth it, now that i got a new motor.
Old 05-22-2009, 11:40 AM
o4Komodo's Avatar
So.... I just went to go crush a can with my hood.
It was crushed practically all the way, I don't think it can be crushed any further.
I put the can in 3 different spots.
Will be measuring and posting some pics shortly.
Old 05-22-2009, 11:58 AM
o4Komodo's Avatar
Don't mind the dirty engine bay =]
Before can placement.
Can placement ontop of VTEC
Crushed.
Relocated slightly towards driver and recrushed.
IM Gasket from P2R purchased from ATLP back in Jan [never installed].
Measurement of can.
I also placed it to the highest point of the engine cover---but it did not crush any further. Once the can was crushed it pretty much closed fine when paced anywhere on top of the IM.
Old 05-22-2009, 12:14 PM
Full of water...
blkaspec's Avatar
so what does this mean? how much extra space is needed with this mod? will a hood mod still be needed?
Old 05-22-2009, 12:36 PM
94 DC4 RS LSV/Turbo
well he clearly proved there is nearly 2" of hood clearance, now CLEANCL... can you measure the thickness of the spacer
Old 05-22-2009, 01:01 PM
Timeless's Avatar
LOL!! That is some crazy precise hood clearance measuring technique! Awesome.
Old 05-22-2009, 01:13 PM
Bender's Avatar
hmm now someone go measure that with a bottle I hear it's more accurate than the can method.
Old 05-22-2009, 01:22 PM
o4Komodo's Avatar
Yepp. About 1.75 inches.
Hahah, thank stillhere.
hmn maybe I'll go try once I'm at home again.... I have an empty water bottle in my room too.. hahah.
I don't think it'd work that well but hey if you want I can go try
Old 05-22-2009, 02:39 PM
Wow.. Komodo... very clever!
Old 05-22-2009, 03:29 PM
94 DC4 RS LSV/Turbo
good shit... here is where the can method came into play
My current cars
96 honda civic with an LS motor
97 acura integra with an LS motor
So I see a guy online who swapped in a v6 into the ek civic (96-00)... and he didn't require a hood modification
so I never actually got to try the method... but figured this would be a great op for it ... and looks like the method is fully functional
so cleancl did you measure yet?
Old 05-22-2009, 09:32 PM
minkl81's Avatar
seems like this will be cheap oem upgrade like what accord guys are doing with rear sway bars
Old 05-22-2009, 09:45 PM
A J35A8 EG civic is in
sunny201's Avatar
Good shit Al.. Wonder why your still researching V6s
Old 05-22-2009, 10:10 PM
Dave_B's Avatar
But most likely will kill topend HP. If I'm following you right, you're essentially lengthing the intake runners. Adding length to the runners improves low and midrange power, but as the air flow increases, the air flow becomes very turbulent and essentially chokes the motor in the upper rpms. This is why many cars use either two sets of intake runners (short and long) or a tuned variable design.
I'd definitely dyno before and after to make sure the gains truely will improve overall performance before claiming "massive" tq gains.
Old 05-23-2009, 04:48 AM
I orderd the parts yesterday should be here tuesday!
Old 05-23-2009, 03:23 PM
94 DC4 RS LSV/Turbo
I understand the concern about chocking the block topend... but this is not a mod for a stock car... this is a mod for someone's car that already has a hiflowing exhaust... I am trying to get some of that low end torque back
beachexotic... I take it you will me maching these to your intake runners and intake manis opening correct? are you machining it then?
Old 05-23-2009, 08:17 PM
CleanCL's Avatar
It is about 1.6" without the 2nd gasket. I have everything you would need, the spacer, extended bolts, extended studs, and 2 gaskets.
PM me if you are interested.
Old 05-23-2009, 08:21 PM
CleanCL's Avatar
Outlaw Engineering showed gains throughout with no power loss with a .25" spacer on a J32A2. Someone should dyno this and see, at such an extreme height could cause loss in top end power but also curiously may show huge torque down low.
Old 05-23-2009, 09:39 PM
94 DC4 RS LSV/Turbo
you pretty much would have everything 1 would need, and as shown it will def clear the hood... but I'd still run the hood latch bushings to account for engine movement
corsport has them... believe they are the same for the rsx and tl
http://www.corsportusa.com/store/cat...oducts_id=1979
Old 05-23-2009, 09:45 PM
94 DC4 RS LSV/Turbo
confirmed 90108-S0A-003 (hood hinge bolt) is same for rsx and tl
Old 05-24-2009, 11:16 AM
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
this is hot AL, something new!! i would love to see the numbers first so beach... we are waiting on you.
yo al, hit me up when you get a chance dont know when your awake so dont want to disturb ya.
Old 05-24-2009, 12:16 PM
94 DC4 RS LSV/Turbo
dude text mmeee... I work 4x12 now always awake
Old 05-24-2009, 10:28 PM
Yes i plan to have the shop port match this tuesday. As soon as Fedex drops it off. I'll post dyno numbers with all my mods including this mod before and after! I have all the parts and started the write on diy install im going to finsh tomarrow and post it later on this week with the dyno sheet.
Old 05-24-2009, 10:40 PM
Bored at work
tl2slow's Avatar
am going to try it was well...who's the guy with the parts....hit me up...
Old 05-25-2009, 08:52 PM
Majofo's Avatar
Received 11,842 Likes on 8,573 Posts
.. but will this be the end to your project? FI? Looking forward to your write-up.
Old 05-26-2009, 02:08 AM
gshotpapi's Avatar
nice!
Old 05-26-2009, 12:42 PM
E55>>>TLS
dr_brains510's Avatar
anxiously waiting...
Quick Reply: Factory IM Spacer - 17108-RDJ-A00
