Exhaust tips for Magnaflows
Hey all, been searching for a while but haven't seen any answer for this.
I'm looking into buying some Magnaflows to replace my stock exhausts and I'm wondering how long the tips can be? I don't want them sticking out from the bumper, or not too much.
The model of Magnaflows I'm looking at is 11365 and I have a Type-S (if that makes a difference).
I've found a couple of them that I'm interested in, and the total length is 9.5" and 9.75" I think.
Pretty sure any exhaust shop should be able to cut and weld on your stock tips on your new mufflers. At least that's my plan when I upgrade, also helps that a family friend owns a shop
The magnaflows only have one outlet each, the stock Type-S have two, so that doesn't work. I need tips that have one inlet going to two oultets to keep the quad exhaust setup.
Right I know what you mean Ive also researched this because Im not paying $1200 for a catback when I can make my own for 600. You can weld 2 single tips to your new mufflers is what I was saying and they can be welded in a staggered way so you would never know unless under the car
Yeah, that was my plan from the start.
I still need to know what size in length would be best though, as first stated. This is more aimed at those who actually have swapped their mufflers: what's the length of your tips?
I would say that's it more than likely that you'll be able to use them since most exhaust tubing and parts are the same whether it's a base or S.
Just bend down and measure, pretty sure it's going to be 2.25.
RyanCHICL (06-10-2019)
Ok so still have no answer to my original question. Could someone who actually has installed Magnaflows on their car with the same kind of twin outlets on each chime in?
Don't want to buy tips that will stick out way too much. Or would the #12138 or #14223 be better options than the #11365 since they already have dual outlets? Is the sound the same, even though the size is a bit different?
The inconvenient truth
Aretardedorange
17
05-05-2012 09:27 PM
VanyDotK
12-11-2008 08:09 AM
jwaters943
06-27-2004 12:20 AM
