Exhaust question...
Exhaust question...
This is probably the millionth exhaust question but I can't seem to find a straight answer....... So I have an 04 base and I want to get the tsudo quad tip exhaust with j pipe, but will it fit the base models or only the type s? I looked at all the measurements and they are pretty similar when compared to the single tip exhaust setup. Just the outlets measure different 4in for the single and 3.5n for the quad.. This setup sounds pretty good on the TL. Any info is greatly appreciated
You may have to bend the muffler hangers to calibrate through the exhaust outlets. Besides that, I don't see the issue of fitment. From left quad tip to right quad tip measurement is exactly 7". Do you have enough space on your outlet? I have Tsudo exhaust on my 15 wrx at the moment. The measurement should be same.
https://youtu.be/yfsx5DnClM8
leerbgdup (02-06-2016)
it's not going to fit. the outlet needs to be wider than 7 inch. HKS High Power exhausts makes descent sound. This will fit on yours but it's not quad tip though.
