Excelerate Performance Announces STOPTECH 2-Piece Discs!!!!
Excelerate Performance is proud to announced that StopTech has manufactured Two-Piece Rotor Upgrades for Front StopTech® Two-Piece Rotor Upgrades for Acura TSX, TL, MDX, CL, Honda Accord, Pilot, Odyssey.
StopTech®, the championship-winning performance and racing brand from Centric Parts®, has today introduced a range of two-piece AeroRotor® Replacement Kits (ARK) for the Acura TSX,, TL, CL and MDX models as well as certain Honda Accord, Pilot and Odyssey models.
The new direct replacement 300 X 28 mm rotors are available for front axles and include pre-assembled StopTech two-piece, floating, directional AeroRotors with iron friction rings and aluminum AeroHats®.
Available in drilled or slotted form, with or without a protective zinc coating, these new StopTech rotor upgrades expand Centric’s offerings for these Honda and Acura models, which already include lines, pads, calipers and more.
With lessons learned through more than a decade of racing and testing, StopTech high performance brake components are engineered to provide shorter stopping distances, better brake modulation, firmer pedal feel and less brake fade for stronger, more reliable performance on and off the track.
Weight Difference:
Excelerate Performance is offering a special introductory sale price!!!! See below.
Slotted Fronts (Req's purchase of 1 of each below):
http://store.excelerateperformance.c...i-1761125.aspx
http://store.excelerateperformance.c...i-1761126.aspx
Drilled Fronts (Req's purchase of 1 of each below):
http://store.excelerateperformance.c...i-1761129.aspx
http://store.excelerateperformance.c...i-1761130.aspx
^Yet still the cheapest 2 piece set available. Correct me if I'm wrong.
Gotta pay to play with the best.
Received 3,824 Likes
I will never use Brakemotive again
Looking at pads and rotors now...what happened that makes you say this?
Meh, found it.
https://acurazine.com/forums/showthr...s#post14424641
Meh, found it.
Can we please keep this thread on topic? This is a sales thread for STOPTECH parts, not a comparison thread and review thread for other brands.
You get what you pay for. If you want cheap brakes made overseas that may fit and look nice but don't perform and don't last buy their stuff. I'm not saying they aren't a good solution for some people but just always keep in mind that you're getting what you pay for.
Unfortunately people are drawn in by the low price. There's a great saying:
“The bitterness of poor quality remains long after the sweetness of low price is forgotten” – Benjamin Franklin
takin care of Business in
Received 4,732 Likes
Joey the RB 2 piece weigh around 12.8 lbs and you can definitely buy them from XLR8....
However, i might be getting this deal from Josh in the next few weeks. I will write a review and hope that will give a good perspective in this break rotor...
I have installed Brakemotive's on 3 cars and they squeak and squeal....something that i do not like....and i dont think these even compare to BM's....
Josh, imma send you an email when i get back in town...
brakemotive is priced very low but as Josh said you get what you paid for... if you drive very casual and do not do a lot of hard brakes or go from 80 to 40 as quickly as possible then i understand brakemotive.. but if you do drive agresively they squeal.. its driving me bonkers
Anil, looking forward to reviews!
Josh, I am going to guess it is curved vanes but wanted to confirm?
Feji....from what I have seen, they peeps are not happy with the rotors but just customer service from BM and price....I would not install them on my car weather i track it or not....
I would highly recommend spending a little bit more and getting quality brakes...
I installed Powerslot slotted rotors and here is the log
New rotors + hawk HPS pads @ ~76,000 miles
New hawk HPS pads front ONLY @ ~125,000 miles (so a total for 50K miles on them)
New RB ET500 rear pads (damn seized caliper) @150K miles
I have 175K miles on the clock, which means the rotors are still going strong @ 99,000 miles !!! and the front pads have ~50K miles and still good...!!!
I would seriously suggest people to go to the XLR8 website and check out the deals on QUALITY rotors and pads....
^^^ I understand....
a lot of people think that brakes are very expensive....a decent 1 piece rotors set (all around with pads) is usually around 400-450 which will last you a long time....
check out this link:
http://hoa.excelerateperformance.com...s/g-63863.aspx
not bad at all for 4 performance slotted or drilled slotted rotors and pads
The patented 2-piece AeroRotor assembly uses uniquely designed and patented AeroVanes® inside the disc to optimize airflow through the rotor. This improved directional design minimizes turbulence and flows up to 61 percent more air than any other rotor tested. The result is up to 80 percent better airflow over original equipment rotors and 10-30 percent better airflow than other directional vane racing rotors currently available. Better airflow equals better cooling, and better cooling means less fade and better overall brake system performance.
StopTech AeroRotors also feature a proprietary alloy chemistry. By adding molybdenum to the gray iron, carefully targeting a narrow range of hardness and tensile strength values, and controlling the cooling rate of the rotor after casting, StopTech produces a friction ring with added crack resistance as well as improved functionality.
Que?!
thisaznboi88 (07-11-2013)
The Master Doctor
Dang I paid (the dealer) $450 for just the stock 6MT brake pads (don't even think he put brembo's!!) or was it for both...rotors and pads?? dang will have to look at bill!!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
