Engine mount bolts - Replace or not
Old Jul 11, 2015 | 08:18 AM
KN_TL's Avatar
I'm installing my mount brackets to the block and I just noticed that every bracket that goes to an engine mount says to replace the bolts.
Just curious what you all do if you have to remove the mounts from the block. Reuse or new?
Old Jul 11, 2015 | 11:19 AM
UTAH TSX's Avatar
NO Honda says that on everything no need put a little locktite on it if anything
Old Jul 16, 2015 | 05:06 AM
csmeance's Avatar
Since you have a new turbo setup, its a few extra dollars for some new bolts. I put new ones in my TL with 200K just for piece of mind. Same for the timing belt tensioner and crank bolt.
Old Jul 17, 2015 | 07:26 AM
KN_TL's Avatar
I was delayed enough trying to figure out how to cover the tension brace that I am going to be getting the rest of the hardware today.
When I bought everything on the list for the 3rd gear TSB, I found I had everything except for the engine mount bolts.
I had already gotten the idler bolt with the previous orders I've placed.
Thanks!
cycdaniel
Dec 17, 2019 10:58 AM
james357
Feb 13, 2016 02:37 PM
drone619
Jan 26, 2016 07:09 PM
wilztlxs
Dec 1, 2015 09:16 AM
darksky
Sep 5, 2015 03:11 AM
