ecu
Old Aug 29, 2006 | 07:52 PM
acuratl732's Avatar
ecu
does anyone have the wiring diagram for the 2004 automatic im trying to put in my vtec controller and no one has the diagram can anyone help me out
Old Aug 29, 2006 | 08:32 PM
RYAN97812's Avatar
8 second & 150 mph member
I have a wiring diagram for it. I am in the 732 area also. Cant use the vtec controller though wont work
Old Aug 29, 2006 | 11:29 PM
ubnpast's Avatar
Is there any way to control vtec?
Old Aug 29, 2006 | 11:55 PM
Phesto's Avatar
http://www.apexi-usa.com/news_article.asp?id=15
Old Aug 30, 2006 | 12:37 AM
ubnpast's Avatar
affordably?
Old Aug 30, 2006 | 12:54 AM
acuratl732's Avatar
ecu
is there anyway i can get it from you
Old Aug 30, 2006 | 10:36 AM
Excelerate's Avatar
Former Sponsor
He just told you you can't use it. If I remember correctly, although Ryan can chime in to confirm, the adjustments won't stay. The ECU will relearn its original settings.
Old Aug 30, 2006 | 09:26 PM
acuratl732's Avatar
ok thats fine all i asked was for the wiring diagram and was there anyway i could get the diagram
Old Aug 30, 2006 | 11:11 PM
RYAN97812's Avatar
Sure i will make a copy and you can come pick them up. Josh you are correct. It will not work especially with the drivve by wire throttle as it is driven by a seperate controller and has no functons from the ecu. All changes made by the safc, vafc, vtec controller will all be returned to stock from the ecu. Any ignition or fuel system changes will trigger a code. Good luck if you would like to try and by all means hopefully you can prove us all wrong. Patience HONDATA is coming
Old Sep 1, 2006 | 03:01 AM
acuratl732's Avatar
ok this guy at eshift said he did a 6 speed tl and hasnt had a complaint yet but ill take your word i guess you tried it already
TypeS860
Jan 10, 2026 11:11 AM
cycdaniel
Dec 17, 2019 10:58 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
