Dyno Results
Old Oct 17, 2010 | 11:33 AM
  #41
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
What obdII logger are you using?
Old Oct 17, 2010 | 02:21 PM
  #42
AtlM5's Avatar
The only thing I'd be worried about is drivability going down with custom cams. And theres fuel economy, but if your ONLY goal is performance.......i guess you have the wrong car lol. I mean I wanna see someone try it and work out the size specs so go for it... Im sure if you dont go too big it wount be bad.
Originally Posted by Sonnick
^^ See, I'm just not sold on the Type S cams. I understand they will give us some power, but is it worth it? I feel like an aftermarket cam will give us close to double the power of the TL-s cams. I mean, from the base TL to the Type S is 28hp...it's an extra 0.3L...how much more aggressive could the cams be? For an extra 0.3L AND more aggressive cams, only 28hp? Not cuttin' it for me, sorry.
With aftermarket cams and a good tune I wouldn't be surprised to see over 25whp. It may shift the powerband up SLIGHTLY, but we should start to see gains after 3000RPM. From 3000RPM to redline, if we averaged a 10whp increase and peaking @25whp, that's a HUGE difference. It may be just me, but if you're gonna stay NA, I still think aftermarket cams will be the better choice hands down.
Old Oct 17, 2010 | 02:31 PM
  #43
I hate cars's Avatar
I don't see why they can't keep the stock or near stock small intake lobe and go crazy on the vtec lobe. If they ground it on a different LSA and gave the exhaust a little more lift, you would probably have a very nice top end pull with no loss in the low end, drivability, or emissions.
Old Oct 17, 2010 | 04:38 PM
  #44
04_6SPEEDTL's Avatar
I mod my car in
I guess that answers my question...I can't see how each dyno would vary by that much....one of the guys said to do a compression test bc he had a blown head gasket and the car still ran fine. It seems like something is wrong here and I want to figure it out
Old Oct 17, 2010 | 06:18 PM
  #45
Inaccurate's Avatar
When you said “loss of power” and then said “exhaust is quieter”, I immediately thought of crushed J-pipe. Have you looked at your jpipe to see if the front down leg got smacked and collapsed?
I use the Auterra DashDyno (click here)
Please see the link below for additional info on OBDII scanners and OBDII data loggers.
Data Loggers (click here)
Old Oct 17, 2010 | 06:29 PM
  #46
I mod my car in
I literally just took a look after I saw your reply, that doesn't seem to be the case. Thanks for the thoughtful response though
Old Oct 17, 2010 | 07:25 PM
  #47
I doubt the car lost any power. Your numbers were extraordinarily high for a 3.2 with a couple bolt-ons on the first dyno. You used what, 3 different dynos? This is an illustration of the changes from dyno to dyno and why absolute numbers don't mean much but they're ok for comparison purposes on the same dyno under the same conditions.
The only mods that are going to show power on the dyno are the exhaust mods. The pulley, CAI, spacers, etc will show nothing on the dyno in 3rd or 4th gear
Old Oct 17, 2010 | 08:03 PM
  #48
I mod my car in
now i know that you are "the man" on the forum so i do believe what your saying. Only thing i can think of doing at this point would be do go back to my original place where i did the 269 run and see what numbers are put down. I have read in other threads that our cars put down somewhere around 230 - 235 to the wheels so thats what is really throwing me off. Last time i had dyno'ed at no limit before the 269 pull i didn't have the precats in and i made 247... to me this dyno seems to be the most consistant with my car....based on if the "stock 230 - 235" is correct.
Old Oct 17, 2010 | 08:24 PM
  #49
That may be it. Obviously the 200hp (the really low one) was way off, lower than a bone stock 5at. Definately go back to the original dyno and stick with that one for comparing mods.
Weather makes a huge difference. Wait for a cold dry day in the middle of winter and look up air density for that day. You can probably add another 10hp to your dyno by doing nothing. I plan on dynoing my car again. I did around 210hp on a 105 degree day 2 years ago. Once it gets real cool I'm going to wait for a pefect day, preheat the oil and run in on a cool engine to see if I can get some crazy hp numbers for a stock 5at.
Old Oct 17, 2010 | 08:34 PM
  #50
I mod my car in
Will do, i will try to get it done soon. I'm still going to do the compression test for the hell of it, i wanna check my plugs anyway. To think the only reason i went to the dyno was because it was dyno day and wanted to have some fun with a few buddies and also see if the throttle body spacer robs us of power or adds power or nothing at all. Instead i had a very stressful day. Once i re-dyno at the original place i will post on here the numbers for everyone to see...i hope the day i do it the weather is similar to the day i did the 269...since i'm on long island i might have a shot at that happening. Thanks for the posts
Old Oct 17, 2010 | 08:40 PM
  #51
I mod my car in
oh and just an FYI when i got the 269 number it was about 80 degrees out and when i just got those low numbers which was yesterday its been in about the 60's....we will see when i re-dyno
Old Oct 17, 2010 | 08:44 PM
  #52
It doesn't hurt to check but I'm sure your compression is fine. For a loss of compression to make a 30hp difference the car would barely idle and you would have misfire codes all over the place.
I'm curious how it's going to do on the original dyno. I have a feeling the numbers are going to be very close.
Old Oct 18, 2010 | 09:13 AM
  #53
Sonnick's Avatar
All motor
I wouldn't say 269whp is abnormally high for what his car has. For arguments sake, let's say stock the 6MT TL makes 225whp. With I/E/PC Deletes/Jpipe I'd say it's possible to gain 40whp. After E/Jpipe (which add about 15-20whp when combined), the PCDs add another 10-15 alone as seen from a few dynos.
I would definitely still do the pressure test just to make sure. I mean, 205 on that dyno seems very low. That's the same dyno I got 255 on. Maybe it was calibrated differently? I mean, I can't see that much of a swing from the calibration alone though.
What gear did they dyno in Ant? That can also play a factor.
Old Oct 18, 2010 | 10:47 AM
  #54
I mod my car in
I believe it was fourth gear, you wanna come with me when I go to no limit again?
Old Oct 18, 2010 | 01:58 PM
  #55
Like I said, it won't hurt to test but there's no way low compression will make that kind of difference without the car running like crap at idle or not idling at all.
The only mods he has that would show up on a dyno are the exhaust mods. Whether it can or can't make that kind of difference, I don't know. But it's on the high end of normal for sure.
The pulley and CAI will make no difference on the dyno. The hood is already up, CAI is ineffective, and the dyno is done in 4th gear so the pulley is ineffective. Spacers don't make a difference anyway.
If he dynos almost 270whp again on the same dyno, I'm ordering a complete exhaust from the precats back.
Old Oct 18, 2010 | 03:36 PM
  #56
Sonnick's Avatar
All motor
Where is no limit? If I can go I will. Idk if I want to get dyno'd there tho only because I want to see my gains from the 3in exhaust on the same dyno.
Do it!!
Old Oct 18, 2010 | 05:31 PM
  #57
I mod my car in
No limit is near me, like 10 minutes away
Old Oct 19, 2010 | 10:02 AM
  #58
fpgreenwrx's Avatar
I always determined dyno whp by Trap speeds at the track. For example I knew that my Wrx with 320whp on a dynojet would trap around 111-113. Exactly what I got. obviously when I dyno'd on a mustang it went down to 296whp with the same trap times. It was a bit more tricky as i got to 400+whp because of tire spin and boost issues.
Old Oct 21, 2010 | 09:07 AM
  #59
I mod my car in
I did the compression test last night and the numbers were good. 4 of the cylinders were 150 psi and the other two were 125 & 135 which are still in the range of being good. My spark plugs were in good shape however the three in front seemed to be loose. When I put everything back together and tightened the plugs how they should be the car seems to run smoother. I will probably dyno next weekend.....results will be posted.
Old Oct 21, 2010 | 09:22 AM
  #60
Sonnick's Avatar
All motor
You know what we should do? Since I have the RV6 V1 Jpipe and you have the ATLP V2, we should see what the diff is on the dyno between the 2 pipes on a full bolt on J series. Since we both have full bolt ons, it doesn't really matter which car we use it on either.
Oh dude, sorry about last night. When you called I was on the phone with my GF and I forgot to call you back. Hit me up later.
Old Oct 28, 2010 | 11:37 AM
  #61
greco9885's Avatar
Originally Posted by greco9885
auto is 3rd gear. manual is 4th gear
i made a mistake
correct dyno gears:
04-08(all) automatic is 3rd gear with a 1.07:1 ratio
04-08(all) manual is 5th gear with a 0.98:1 ratio
auto:
First Gear Ratio (:1) 2.70
Second Gear Ratio (:1) 1.61
Third Gear Ratio (:1) 1.07
Fourth Gear Ratio (:1) 0.69
Fifth Gear Ratio (:1) 0.49
manual:
First Gear Ratio (:1) 3.93
Second Gear Ratio (:1) 2.48
Third Gear Ratio (:1) 1.70
Fourth Gear Ratio (:1) 1.25
Fifth Gear Ratio (:1) 0.98
Sixth Gear Ratio (:1) 0.77
OP i think you have been dyno'ing in the wrong gear leading to false numbers
Old Sep 28, 2011 | 12:12 PM
  #62
bouncer07's Avatar
^ After reading this post, I don't think people should give our false information to the community. Even though it's a year old thread, it can still throw off new members who think they should dyno in 5th gear. Your wikipedia find is what it should be, but 4th gear is the power band you want to dyno your car on.
Just think about tracking the car, your car will not hit 5th gear in the 1/4 mile, so the power to tune the car would be 4th. 3rd gear would be reasonable for part-throttle tunes, Wot's on 4th and maybe 5th gear to see what you'll make in that gear. I don't see much MODs correcting many misleading posts which in turns leads to other's ruining their car. BUT.. I'm sure your tech/tuner will also correct you on this as well.
Old Sep 28, 2011 | 02:02 PM
  #63
Sonnick's Avatar
All motor
Good post. But, the only reason we don't/shouldn't dyno in 5th is because of the limiter. Being set at 135, it prevents us from exceeding say, 5800RPM in 5th, which is before peak power. If there were no limiter, based on what I've heard/read, you should do dyno pulls in the gear closest to 1.0, which would be 5th.
Old Sep 28, 2011 | 05:50 PM
  #64
anx1300c's Avatar
LOL, no one is going to "ruin" their car by making a dyno run in a "less than ideal" gear.
Old Sep 28, 2011 | 06:35 PM
  #65
ProbyOne's Avatar
I assumed that they used a correction factor for the gear ratios... but I dont know much about the actual dyno setup.
To get relevant numbers you would always have to correct the torque numbers for a 1:1 ratio.
Old Sep 28, 2011 | 08:27 PM
  #66
ProbyOne's Avatar
i made a mistake
correct dyno gears:
auto:
manual:
Are you accounting for the final drive ratio?
As long as the gear ratio, final drive ratio, and tire size are taken into account, it really shouldn't matter what gear you are in, to a point. Due to the time sensitive nature of a dyno it would make sense to run in the highest gear (6th being the highest in this case) possible so that you get more accurate and consistant numbers.
For clarification: highest gear possible means that you are able to reach redline in that gear.
See above.
Old Sep 29, 2011 | 03:39 PM
  #67
Yonkers914's Avatar
04Tl
BUt isnt the limiter of 135 only on auto's? i know manual goes up to 150ish i know my car does lol
Old Sep 29, 2011 | 03:46 PM
  #68
TL-08's Avatar
7th Gear
Nice!
Old Sep 29, 2011 | 03:54 PM
  #69
Sonnick's Avatar
All motor
Oh I'm not sure lol. I know I've hit 135 before on my car and didn't feel any sort of limiter, but I'd rather not test it again...
Old Sep 30, 2011 | 03:33 PM
  #70
JDECON's Avatar
What's the mileage on your car? Nice dyno by the way.
Old Oct 11, 2011 | 08:25 AM
  #71
I mod my car in
Thanks i have about 125k
Old Oct 14, 2011 | 12:33 PM
  #72
mdrolet77's Avatar
i made a mistake
correct dyno gears:
auto:
manual:
This doesn't make any sense if it accounts for final drive ratio since the at's 3rd gear would be roughly equivalent to the mt's 6th... When typically the mt's 6th should be about the same ast the at's 5th.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
Tribalheads
Sep 29, 2015 03:24 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
