DYNO Charts Thread
DYNO Charts Thread
Hey guy's
I thought it would be great to make a thread just for Dyno's. I personally don't have any dyno sheets, but I am tired of looking for performance documents for different parts, so i thought this thread should help. if this is a repost (I don't think so, cuz I have searched) then just forget about it, and post the link up for the dyno thread.
SO, if you have been on a dyno, please post up you chart's. et us know what dyno you were on , and what mod's were on the TL. This is for TL's only, please. It would also be great if you have dyno charts for specific parts like dyno chart with base TL with only a AEM CAI, or type-s with Comptech exhuast only. Thanks
Thanks,
Here are some dyno's I've found;
Member: ussi
TL model:
mods: S/C w/ HBP|Hondata ECU|CT Catback w/ HKS TI| Custom J-Pipe|CT Short Shifter|Custom CAI-
-Head/Intake Port&Polish|Performance Valves|Type-S Cams|E-Procats|SP Boost Cooler|
Member: Richie V6
TL model: 05 auto
Mods: RV6 V3 jpipe
Dyno: AWD mustang Dyno
13 WHP peak gained
7 WTQ peak gained
15 WHP average gained
12 WTQ average gained
Member:REDLINERAV
TL model: 2007 TL-S 6MT
Mods: 1. Injen CAI
2. P2R Throttle body spacer with gaskets
3. P2R Ported Runners
4. RV6 V1 Precat deletes
5. ATLP V2 J-pipe
6. Random Tech High Flow Cat
7. Mid muffler delete with dynomax resonator on a stock exhaust.
Thanks,
Member: ussi
TL model:
Member: Richie V6
TL model: 05 auto
Mods: RV6 V3 jpipe
13 WHP peak gained
7 WTQ peak gained
Member:REDLINERAV
Mods: 1. Injen CAI
5. ATLP V2 J-pipe
member: 04_6speedtl
TL model: 04 6 speed TL
Mods: Progress RSB UR S Crank PulleyK&N CAI CT SS P2R TB Spacer, IM Gasket Greddy Evo II Catback ATLP J Pipe & Race Pipe RV6 Pre-Cat Deletes
Grand_hustle17 (12-05-2013)
member: TLdream
TL model: 2006 TL 3.2 6mt
mods: fujita cai only
BASELINE:
HP = 230.54
TQ = 209.2
conditions 45 degrees 34% humidity
mods: precat deletes, atlp v1 jpipe, rv6 resonated test pipe, atlp type s quads, fujita cai, p2r tb spacer.
HP = 256.06
TQ = 225.48
conditions 57 degrees 23% humidity
BASELINE:
HP = 230.54
TQ = 209.2
HP = 256.06
TQ = 225.48
Dynapack
303/254
Attachment 108943
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP 3.7L Intake manifold
PNP Runners
3.7 ZDX Throttle Body
Cold Air Intake
Brand new Dynocom 5000 Roller Dyno
294/277
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP Runners
Cold Air Intake
Spec Stage 3+ Clutch
Spec 14lb Aluminum Lightweight Flywheel
303/254
Attachment 108943
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP Runners
Cold Air Intake
294/277
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP Runners
Cold Air Intake
wilspainar (06-20-2017)
All these were done in Denver, CO
CS&C (Colorado Speed and chassis, Dyno Jet)
Dyno Pro (Dyno Jet)
DT&DE(DSpeed Tuning & Diesel Emissions, Mustang Dyno)
Here is a break down of all my dyno's- 2004 MT TL
210 WHP Dead stock (cant find) CS&C
255 WHP CT Supercharger (cant find) CS&C
267WHP CT Supercharger with Megasquirt 3 (JnR) CS&C
256 WHP (3.5 bottom end with 9:5:1 compression, 3.7L IM, ZDX TB, PnP Heads & Runners, P2R Gaskets, Bisimoto Custom Type S cams, Supertech retainers and springs) Dyno Pro
264 WHP parts in the 256 column Plus Maxbore ZDX TB with machined shaft & screws, port matched the lower intake manifold to the ported runners, removed 4 casting studs from manifold, removed lots of other imperfections in the manifold (nearly the whole manifold) DT&DE
227 WHP Dead Stock 2010 MT SH-AWD TL DT&DE
Dyno Pro (Dyno Jet)
On a base 6spd um doubt that. Not a few bolts would bring it to that. He would have to be at almost fully bolted. That seems accurate enough with just a SC and tune.
And you can't "easily" get 267 whp with "a few" bolt on parts on a J32 A3.
EvilVirus (12-01-2013)
My freaky '06 J32A3 M/T
At Tuner Nation Dynojet (Hollywood, FL)
_002 = Base Stock + DIB K&N air filter.
_004 = After RV6 V3 JPipe.
_006 = After P2R TB spacer.
At Twilight Dyno Shop (Opa Locka, FL)
_003 = Base Run (RV6 V3 JP + P2R TBS)
_024 = Final Run after RV6 PCD + JnR MS3 + Intake resonator delete
Scottwax (12-03-2013)
Dynapack
303/254
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP Runners
Cold Air Intake
294/277
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP Runners
Cold Air Intake
303/254
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP Runners
Cold Air Intake
294/277
Mods
Jpipe
Pre Cat Deletes
Dual Exhaust
PNP Runners
Cold Air Intake
def not a noob to dyno... I know numbers can be a tad different based on differebt models... 20+/-whp or tq.. not so much between those dynos... And in all actuality his 1st dyno is the highest reading dyno out.... Plus i do have a friend with similar mods and JJH still dynoed a significant difference in tq... Not so much hp but he was still about 19wtq more.. im gonna have to assume that there is a significant wtq increase unless u can show me otherwise
That is a wrong speculation doing maths from a factory average crank power.
To calculate drivetrain loss you need the actual engine dyno of the specific motor. Do you have mine? Because I don't.
Just in case, I am 41 year old and I don't need to lie. I do not play the game some kids plays at forums.
I'm showing two real dyno plots, from two real dyno shops near Miami, before and after each modification. That is all.
It was a question so please enlighten me. Never said you were a lair and I am not going to sit here and think I know about dyno sheets. I have only read and seen what others have posted before. I only go the numbers from what others have dyno their 6spd stock which is about 225-230 whp.
I have to recognize the numbers freaks me out on the beginning on the first dyno shop, but them almost the same numbers was confirmed at the second dyno shop.
Please watch this video from the night we install the JnR MS3 witn Rodney (03/21/12):
EvilVirus (12-07-2013)
They were really only 258 at the crank in '04/05. The 270 was an inflated number that was deflated by the SAE's stricter guidelines for 2006. 208 is what actually made it to the ground after the parasitic loss from flywheel, transmission, half shafts, axles, rotors, wheels, tires. All that rotating mass consumes power. 208 is about right for a 5AT.
Meacura86 (12-13-2013)
So a full-bolt on base model 6MT is good for roughly 265-270whp without a tune? Hmm.. Looking at picking up my 2nd TL this weekend and I'm wondering if that will be enough for me. Seems good enough for the street, wish we were at least as quick as E46 M3's now with all the new mods available. Oh well, the car's gorgeous anyways.
