Does anyone run a k& n short ram?
I am wondering if anyone has installed a K&N typhoon SHORT RAM intake as I DO NOT want a cold air intake, and I am wondering what they think of the performance of it?
horsepower gains?
Better gas mileage?
horsepower gains?
Better gas mileage?
Mileage gain from a filter, shortram, or CAI is a myth. Intake mods can't effect milege.
Power will likely be lower than stock. The factory intake is a semi cold air induction. You're raising the temp of the inlet air for a slight decrease in restriction. Since a stock TL engine can't outflow a stock air intake tract, there's no gain from less restriction.
Do it if you want more noise and worse filtration.
I don't know if that is true, why would they make a short ram peformance intake from a well known company that makes worse performance? don't you think they would test them before manufacturing them and selling thousands...?
The oem intake on the TL is a semi cold air intake as well....
Some buy them for the sound alone and some don't know any better.
It's just like K&N claiming a mpg increase. It's impossible on a fuel injected car. All they have to do is test an old carbureted car with a severely plugged air filter for both power and mpg and they're legally free to claim it.
As airflow requirements go up with mods, a short ram becomes more of an advantage but it's not likely that anything short of a turbo would require it.
Because people buy them.
i bought a k&n drop in filter a few of months ago and man does the mpg on it suck! As of now i get about 27 mpg on highway miles. Before I would get 32 to 33 with the oem drop in intake, what kind of crap is that? To me I think K&n filters are crap!
I don't care if they have lifetime warranty on them or whatever. Maybe i should just stick with the oem intake or buy a fujita cai
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
boost owns
The OEM intake works because it's not really a short ram, it's a filter in an enclosed box which is fed cold air through an intake tube.
A short ram intake just sits the filter out in the open amongst all of the hot engine bay air. It's really no good, and I don't see why you're so intent on the SRI being a good solution when there are cold air intakes available for the TL which are proven to be effective.
boost owns
In order for hydrolock to be a valid concern, you would need to, on a regular basis, drive through bodies of water in your car. We're talking 12" or more of standing water. Just drive carefully and you won't have anything to worry about.
Not exactly true .. unless the ambient temperature outside is hotter than the air under the hood ... the cooler the air the denser the air .. thus more O2 per CFM.
Many of the domestic CAI makers put the filter in the engine bay with a plastic shroud around it that's fed cold air. It has a drain hole on the bottom so that if any water gets up there it will just drain out. Too bad nothing like that is made for the TL.
boost owns
Comptech's Icebox for the TSX sounds like what you're describing. They never made an Icebox for the TL? That surprises me. It's a good product, and is what I would run if not for my Injen CAI.
this post was to see if anyone HAS A SHORT RAM in their TL. I still don't want a cai. I live in canada, we get ALOT of snow, I mean alot, and slush ans everything else. I need to speak with someone who actually has a SRI on their TL to see what they think. Of course if you have a CAI your going to say a SRI is bad. I had a SRI on my accord and had it dynoed and it did make more horsepower.
If you're looking for a justification, you're not going to get one unless you like it for the sound. You're trying to spend money on something that at best will cause you to break even on power and likely lose power. I'm not sure what the point here is.
Understandably you want insight from SRI owners but take into consideration what these guys are trying to say...Unlike opinions, which are based on relative observations, these guys are actually justifying their claims through the basics of physics and logic.
Like I Hate Cars said...You're hood was more likely than not open in the dyno bay when you had the SRI on your accord...I wonder if they had a big industrial fan blowing as well...
Search for "Weapon R" or something like that. I believe that was an sRI system that a few AZine souls installed on their cars. To start you off.
https://acurazine.com/forums/showthr...light=weapon+r
One more for you.
heres a good point..the new mustang and mustang bullitt uses a oem short ram intake....now why would they use that if it didnt do anything?
![](http://image.musclemustangfastfords.com/f/8915042+w750+st0/mmfp_0802_05_z+2008_ford_mustang_bullitt+cold_air_intake.jpg)
why do ppl ask for advice, and then they dont even consider it? it appears that they've already made up their minds, and wont give up untill they hear what they wanna hear...and once they do, theyll say..."see, i knew it"
come on man.....get a real aftermarket intake, either injen or aem.... dont worry about hydrolocking...when ya wanna float, get a boat, dont use ur car...
everyone's claiming the noticeable differences with this short ram stuff.... the only thing they're noticing different is the simple expectation of a difference....everyone expects a differense, thus "a gain" each time they mod smth on the car...even if it makes no real difference...ull still feel as if u did, only for the simple reason because in ur head, you expected it, you believed it, and thats all it is.
ill give you an example.... an aftermarket cold air intake was installed in an S2000, base dyno vs CAI dyno...the car lost power.
Talk about weird looks as people watch you emptying out an entire 20lb bottle of nitrous into the grill.
thats not a joke...i believe that!!!! id still stuff a bag of ice in there if i was lining up.
speaking of which...i was just getting on the way to the track yesterday. while driving i got cut off and had to swerve hard...ended up bottoming out, snapped the weld on the exhaust pipe as a resonator got caught up... dragged the exhaust on the street for a mile lol....fucking luck
regardsless of what is surrounding the intake on the mustang it is still a short ram and it is still in the engine bay which will still suck in heat if CAI were so good they would install them on every oem car
YOUR CAR HAS A COLD AIR INTAKE!!!! the one ur speaking of, you wont see on any cars...why? because they dont want ppl to drive through a river and have to be responsible for it for one, second...when it rains, ur filter will get a bit clogged from the moisture, makes the car feel a bit weird...the filter is exposed to a lot more crap than the OEM filter that sits pretty in the pastic box... so honestly, u wont see an aftermarket-like CAI installed on any cars...now high end cars, have big air vents dedicated specifically for CAI, tubing attached right on the vents, that run straight to the TB... this setup is completely unbeatable.
Now you ask us, Why does ford do what they did...Using an SRI
Lets flip that question. Why did honda use a two-level induction system, where part of it is directly intaking cold air?
No no no no no.
Call it a short ram or whatever. The length of the pipe means nothing whatsoever as long as it outflows the needs of the engine.
See the rubber on top of the box? That seals it to the hood when it's closed. Air gets rammed in near the grill. There's a huge volume of air getting rammed in there and the filter is sealed off from the rest of the engine bay. It is a cold air intake in the best location, behind the grill
Dave,
that picture....thats not even a short ram...thats almost just like every other oem induction system, with a filter inside an enclosed box, which in this case, it becomes enclosed once the hood is down....filter's sitting on top of the bottom opening, where the air makes its way through from below... also on the engine side its completely sealed once the hood shuts, leaving the front of it kinda open that would enable it to breath the air that gets through between the hood and the bumper..(when ur moving air gets through the front everywhere).. it looks like it gets air from underneath, and straight through between the hood and bumper.
usually aftermarket short rams are just a piece of pipe with a filter attached to the end, and some kind of heat shield behind the filter, supposedly keeping heat away, but never completely seal the filter away from the rest of the bay. but this one...its completely BOXED when the hood is down
boost owns
Flat filter, Comptech supplies a foam one, but most guys swap in a K&N.
boost owns
The OP seems to already be convinced that he wants an SRI and that an SRI is the way to go, and posted this thread solely as a trolling mechanism.
davewhodavedunn, between this and your "interesting" thread about taillight eyebrows, you appear to simply enjoy arguing. Good luck with your hot air intake. This thread is a lost cause.
