Do I need to use High octane fuel?
The car will run, as its still gasonline which is combustable and not water being added.
However it will run horribly, with less power, and possible detonation issues, which over time could cause piston failure.
As mentioned, this J32 engine is 11:1 compression. It is equipped with knock sensor and will retard ignition timing with lower octane gasoline. However, it can only retard timing so much and may not be adequate. Otherwise, Honda would mention it in the owners manual and advertise it as such.
I knew this engine required premium fuel when I purchased it, but the great V6 gas mileage compensated and option for MT. That combo is not easy to find in sports oriented sedans.
You should have known this before purchasing if that is a deal breaker for you.
really, why is this such a thing that needs to be decided?
Is there a lot of money to be saved on the difference between 87-91?
and if that's the reason...how about 2 less sodas a day that do nothing but poison you, and maybe skip on that useless junk snack and you can easily compensate for the price of 91 octane.
your neighbor is as dumb as they come.
(ive never used anything below 92-93, ever),
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
