Definitive Primary Catalytic [PreCat] Delete Kit Thread
#41
tehLEGOman
Received 1,983 Likes
How are you guys getting the rear oem cat out of the car? From the top or bottom?
#43
If you were to get these with a jpipe and high flow third cat to an atlp exhaust, will the gas smell be gone if not barely noticeable cause of the cat or no? Has anyone tried it?
#44
practicing nihilist
It can't be any worse than my old '90 4Runner with 240K miles warming up in my garage...and that girl needed a while to get up to operating temp. I never paused before I got in and almost blew chunks from the fumes.
Seriously, didn't anyone drive beaters growing up?
#45
94 DC4 RS LSV/Turbo
there is a halfshaft heatshield held on by 2 or 3 12mm bolts
you need to get at those first
4 x 10mm hold the heatshield on to the rear cat
once you get the above off you should be able to wiggle off the heatshields, it takes a little play but they pop right out (thru the bottom)
some cars I've done them to odly require you to remove a little headshield bellow the injectors... also may even have to pull off 2 injectors the passenger side 2 to get that waffle looking cat out
e-money if you have any questions you know damn well to aim me
cycdaniel
12-17-2019 10:58 AM
Joseph Stansbury
34
12-04-2015 01:57 PM
