Comptech Supercharger: Official Info thread.
#161
Originally Posted by tzakiel
So if I got them on the phone tomorrow, when might I be able to get the blower installed? I must be out of my mind, this is a major mod but exciting. I know there must be some wait because of the release of the blower being so recent, but maybe dealers got them sooner?
I'm not sure that they are open tomorrow. And I'd be wiling to bet Lenny isn't working.
Also, you'd still have to wait for Comptech to ship a kit to Tischer; they don't keep them in stock.
#162
Originally Posted by mrsteve
There's a ton more plastic trim covers under the hood on the TL than previous cars Comptech has made kits for. These trim covers need to be cut in minor areas. When you go to take the blower off and sell the car you could easily and cheaply replace those panels.
#163
I like to whistle in my
Yeh, If i got one i would most likely make the drive and take it to Tishcer to have it installed. They seem more aware of what goes on in the aftermarket world as far as car modifiying. The fact that I've seen a few cars sponsered by them, a dealership, is pretty cool too.
#164
Cold Racketeer
#165
Iro Ridg .308
one of the perks of living in northern cal........take it directly to the comptech shop! So who's making the trip out of the 25+ that placed their orders already?
#166
Very interesting news about Tischer.... I bought my 06 TL from Rosenthal, and am bringing in for bluetooth issues tomorrow morning.... I'll have to ask them their policy, and may just end up going to Tischer for the S/C in mid-january.
Thanks for the info mrsteve!!!
btw... where in MoCo is everyone from? I'm in the Olney area, if anyone is up for a little meet tonight, couple of us meet up in the Tara Thai garage by Barnes and Nobles up off Rockville Pike. Should be there around 10pm, you'll find the cars parked on the third level. Mostly Accords, but couple TSX, Subaru's, Evo's, etc. And of course my lone TL
-Tom C.
-Tom C.
#167
if anyone is going to have one installed in Dallas/fort Worth I would go to Jotech motosports they know there stuff.... I have had all my work done there
http://www.jotechracing.com/
#168
If anyone knows of any Acura dealer in Houston who would honor the S/C install, then I would jump on it. With a warranty of 100K and car only 2 months old, I have been trying to look the other way.
#169
#170
just a note to all who are ready to jump on the supercharger bandwagon...read the policies of your Comptech supplier VERY carefully...if this thing gets delayed (again) you could have some serious cash tied up in a NON-refundable "special order".
#171
Originally Posted by TeamXRSX
Also, meant to ask...how are you guys going to retard ignition timing more for the advent of added boost pressure(i.e. raising boost pressures higher than 5psi?). The IAT trick will only work to such an extent. Also, say the engine does develop some pre-ignition(from over advanced ignition timing) or detonation(from lean AFRs)? With the knock sensor disabled(or even filtered) how will the ECU know to retard ignition timing to combat the knock?
CJ
CJ
Timing , especially on a forced induction application, is everything.
-JMS
#172
Originally Posted by JMShipp2
Especially considering that this engine tends to knock occasionally N/A at "full Load" or 1 bar anyway.. then you through in some nice hot boosted charcge, and you are certainly going to induce knock.. How are you folks dealing with this issue?
-JMS
-JMS
We use the ACM device to clamp the MAP signal voltage so the ECU doesn't see the rise in manifold pressure. Then, since IAT is measured after the blower, we can rely on the ECU to retard ignition timing automatically based on the significant increase in IAT.
An increase in boost above what is initially offered with the kit would require an increase in static fuel pressure and/or a re-program of the ACM unit.
EDIT: Additionally the ACM unit from Comptech has it's own built in knock sensor to avoid detonation.
#173
2018 TLX A-SPEC
Steve, last I heard if the charger caused damage to the internals Tischer wouldn't be able to cover it under the Acura warranty. At least that is what they told a guy when he wanted to get his JRSC done there on his RSX. Have they changed policy and are they eating the warranty costs themselves when damage occurs? I can't see Acura warranty services footing the bill when a customer of theirs blows a motor that was boosted. I have always heard that Acura and Honda won't warranty damage caused by boost even it it was from Comptech parts.
D.
D.
Rosenthal's policy is that they'll still service and cover non-related warranty claims. But if anything remotely related to the supercharger fails you'll need to open your wallet. I live closer to Rosenthal but I drive to Tischer.
#174
D.
D.
So, thus far there is no SC shipping and no warranty details available. If they were available we would certainly know about it here.
#175
D.
D.
Honestly I think it's a case by case basis and something that each customer would need to ask about prior to making assumptions. Certainly if you purchase the blower from them, have them install it, and continue to service the car there they will be much more likely to help you out if this happens.
I do know this; one local boosted CL blew his motor because the guy that did the install (not Tischer) left the stock spark plugs in the car. He melted the piston rings on the rear bank. He needed a new complete shortblock. Tischer, who had nothing to do with the install of the blower, but had serviced the car in the past, did the swap VERY cheap in comparision to what it should have cost. I believe he was out the door for around $2,000 parts and labor.
However, how many cars (RSX, CL, TL) have had damaged internals on base-kit boost levels? None to my knowledge.
#176
Originally Posted by 2_FastTLs
It's very interesting to see some folks are forking up serious $$ to pre-order the SC without even knowing what the warranty details are. I would be really interested in knowing who forked up the cash that find out about the crappy warranty will not install the SC.
Continuing to hate? You really have no idea what you're talking about and it's getting old.
What crappy warranty are you speaking of? Want an example of the crappy warranty? Here's a first hand story of the "crappy warranty."
A local guy here in MD named Brian purchased a brand new Comptech S/C'er for his 2003 CL-S from a Comptech vendor who used to sell on Acurazine. The kit was shipped to him and installed at Tischer Acura in Maryland. Well after taking it easy on the kit for a day or two to make sure everything was okay, he pushed the car to redline. Once he reached 5500 rpm a vibration occured that could be felt in the gas pedal.
Back to Tischer he went. Had the belts replaced and both supercharger pulleys replaced. After this he still had the problem. So they removed the blower, adjusted the mounting brackets and reinstalled it. Still, the same problem occured. Since Tischer had exhausted every option they knew of they called Comptech. Brandon at Tischer told me that a Comptech technician, Shad I believe, flew out from California to Maryland to take a look at the car and the problems it was having. They tinkered with a few things and ended up the best option was to replace the blower with another unit they had instock back in California. Comptech shipped the kit to Tischer at their cost and the new blower was installed. The problem went away.
This was the first instance where this problem had occured. All of this diagnostic work was performed at no cost to the owner of the car and he didn't even purchase the blower from Tischer Acura.
I say this is a first hand experience because I went on to purchase that car in June of this year.
Yeah that's a real crappy warranty.
Each individual dealership can decide how the Comptech kit will affect the FACTORY warranty but the Comptech warranty is readily available to anyone (even people like you who have no desire to purchase their products and just like to spread ) on their webiste. I believe it is a 2 year/unlimited mileage non-transferable warranty that covers every part of the kit.
Please you have nothing constructive to add to this thread. Find another one.
#177
I have personally been involved with 500+whp K20A2 engines w/bone stock bottom ends and with no headwork. One of these engines produced this output for a good amount of miles and is still running hard today. There have even been some k-series people that were trying their hardest to blow they're engines up. One guy had a extra built K20A2 engine sitting in the garage waiting to be swapped in and was not worried about his stock engine...this particular person ran ungodly amounts of boost on this poor little bottom end, but could not grenade the engine....the engine just kept making more and more power. Of course, a stock bottom end can only take so much for so long, but this was amazing but is only one example. The b-series engines were alot of the same as well, this was a series of engines that had been awhile for a long time and people knew in and out. It was easy to make good power with the correct combination yet still using stock internals. But due to factory tolerances and differences during manufacturing, no two engines are exactly the same and one engine will be able to take more abuse than the other.
To sum it all up, i would not loose any sleep over 4-5psi on this engine at all, again, as long as everything else is taken care of.
CJ
#178
2018 TLX A-SPEC
Cool I'll refer them to talk to Lenny when they ask me. I have guys in his area that want installs but weren't sure if he would warranty EVERYTHING. I usually tell them he will warranty most thing when not caused by stupidity
D.
D.
#179
D.
D.
Cool but again it's doubtful they will warranty anything unless it's purchased from them. The example posted above is the reason why. For a ~$700 install they had a hell of a lot of time into the diagnosis of the problem.
#180
Bottom line is, as of right there is no SC kit available. Nothing but facts.
#181
Yeah, its STOCK!!!
Originally Posted by datplayaz
I wonder what the dyno sheet looks like, and where the powerband is.
#182
any word on the install of the SC. I spoke with a local dealership and they said they would install but any damage from the SC would for sure not be covered under the Acura factory warranty. He also states that Comptech is legit in performance. The down side is that if I need to chage the spark plugs or do anything blocke by the SC that it is $300 on top of the service, because they would need to move the unit...
#184
The only thing of concern that it blocks is the exhaust manifolds and some of the transmission bolts. If you need a new transmission or clutch the blower needs to come off. $300 is a rip off though. You can remove the blower to access those areas in about 30 minutes.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
3rd, acm, acura, comptech, driveability, esm, excelerate, fuel, gen, performance, pressure, rate, regulator, rising, rl, supercharger, tl
