Cold Air Intake?
Cold Air Intake?
So I've been thinking about putting in a cold air intake on my 05 TL, but the problem is that I live in Boston and there's constant rain and snow. A few mechanics told me to just go with a short ram intake, but I don't wanna lose power, I wanna gain power. Any advice? Anything in the market that'll protect the intake from rain/snow?
I understand how people want to squeze in as much power as possible, but the CAI will probably gain you as much as 9 horsepower. On a heavy car like the TL, you will not notice that 9hp gain.
If u decide to get CAI, as long as you dont drive through big puddle of water, you should be okay. Regular rain or snow wont harm, big puddles of water are which can hydrolock your engine.
Former Sponsor
In order to suck up water you will have to submerge the filter in water. Driving through puddles or in the rain won't cause any issues.
I would recommend either the regular AEM CAI or TAKEDA CAI or the AEM V2 for maximum hp but also more noise.
http://store.excelerateperformance.com
No, the K&N Complete Cold Air Typhoon.
They are all almost the same design.
Same process. Let me see if there is already a DIY in the garage. But honestly the instructions sent with the intake are spot on. I followed that and everything was gravy.
Put the intake on yourself it's very easy. I did my AEM v2 without removing the bumper, wheel, or anything else. My intake was used though, so i didn't mind scratching it up lol. either way easy install.
SRI will give you better trottle response than stock but it will not give you more than 5 hp, plus you will be sucking hot air from the engine. The stock intake is a semi cold air intake so i preferd it if compared to a SRI. IMO
It sounds like most of us would be more happy with that low end power increase unless one lives in terrain that would benefit from the extra HP.
Here are two videos on youtube that should help you out. They are what I used...
http://www.youtube.com/watch?v=U1C5VJtetN8
http://www.youtube.com/watch?v=Wdg4lxpjlRM
I have a custom SRI that me and a friend made.
Honestly, im going to have to get new tires every 6 months because the tires chirp from the slightest bit of throttle.
I definitely have no problem with sucking hot air because it it still just as jumpy after a 45 minute drive.
There is no reason to have the filter down low like all the kits come with. The air is warmer at the asphalt anyway. Tuck it up higher or behind the grill and you're set.
Do it custom. Take out your resonator from the OEM intake, get rid of the flex tubing between the filter and TB, and add a straight pipe. I'm in the process of doing this. Why pay +$250 for the same performance you can do at home?
rcs86
08-02-2016 06:52 PM
