Clutch?
#41
it was only an example.... and btw, some ppl like me put too much work into their cars...therefore i will not babysit it. I will drive it hard, and shift it hard till the dash pops outta place
so i will say again... slave cylinder and dual-mass flywheel on the TL are completely disgusting....
if anyone wants the soft side of a car, they should just buy an auto. .. there's no "i want a very fast car, with loads of power, but quiet as it can be. best handling, but soft suspension. soft engaging clutch for smooth shifts . max performance tires but quiet" <<<thats what a bitch wants...
if you wanna feel connected to ur machine...everything's gotta be HARD.... there's no ifs ands or buts
#42
enough said...we know what the tl is and isnt, man.....so then this is for anyone...dont mess with it, if you can't face the fact that performance with luxury and smoothness do not fit together...so pick and choose.
i got the car because of whole bunch of reasons combined, and turned it into something that its not supposed to be...and thats the fun in that....the stiffest suspension, noisiest stiffest tires, hardest grabbing-dash shattering-clutch along with 370 whp (on the way to over 400 ) and so on...
cheers:::
cheers:::
#43
cheers:::
cheers:::
I'm still feeling guilty for the slightly stiffer ride from the a-spec springs and swaybars and the roadnoise and sharp impacts from the larger high performance tires. I enjoy *trying* to make a no compromise ride which is nearly impossible. That was my reasoning in going with larger swaybars and softer springs. It's a compromise over going with stiff springs but IMO worth it to keep most of the comfort.
In my other car I have made the same power for many years ago yet went through tons of turbo/head/cam/ combos making it extremely streetable and stock appearing. That's just what I'm into I guess.
#45
I think we actually agree. My only point was why the engineering compromises were made that you pointed out.
#46
4drs just wanna have fun!
So what is this slave cylinder valve removal that your talking about? I thought we only had that check valve in the line to worry about?
#48
Bored at work
well my clutch finally shitted on me today. i got the car back from the dealer on friday after the clutch master cylinder broke. when i drove off the clutch was slipping more than ever and i told the service adviser and he offered to help me out. acura is going to pick up the tab for labor but they will only put in the stock clutch. you guys think i should let them do it. i am kinda iffy on this because i just bought a brand new clutch disk replacement from clutch masters and i was going to put it in on wednesday. what should i do .... will any of you guy be interested in a clutch masters stage 3 set up???
#49
I (don't) whine.
#51
runnin a little boost
Make SURE you swap ring gears before you even attempt to put this in unless you want to install it twice.
Again?? I finally got my ring gears swapped and the clutch is good to go for now. The startup is just how it used to be - quiet. My slave cylinder did lock up so I swapped that out. How much is labor on the master cylinder that you're thinking putting the stock setup back?
#52
Bored at work
if i get the work done at the dealer i have to pay for the stock clutch and the labor is free. but i just got the replacement clutch disk and was about to take off the stock ring gear off the clutch. the dealer will not put on the cm clutch only the stock one. what should i do??
#53
I (don't) whine.
#55
2005 Acura TL 6 Speed
No, but if you get one from them you can have them (or have your local shop) swap ring gears and you should be good to go. I've had mine in for a week, let me break it in and let you know.
Oh well if you're going to have to pay for a new stock clutch i would say No, might as well spend the $$ and put the CM kit in and get the ring gears swapped at the same time. I mean I love the grab of the CM kit, I don't know how I got by with the stock clutch...
I need to do something about my clutch.
SidhuSaaB
05-30-2020 12:40 AM
