Can my 04 be tuned
Can my 04 be tuned
Does anybody know of an OBD2 tuner availible to tune the computer in these cars. I have the AEM intake, and the under drive pulley. Got 227.2 SAE net horsepower to the wheels last summer. I installed the P2R throttlebody spacer this week with the gaskets, and now I'm at 222.67 SAE net horsepower. The place that did the dyno run does not have the equipment to tune these cars and that is his recommendation. Is there any way to get more fuel to the motor without reflashing the computer. Sorry if the post is redundant, and any help or suggestions would be appreciated.
you gotta search bro plenty of threads on this. quick and short answer NO!!!! One of many threads> https://acurazine.com/forums/showthr...&highlight=ecu
BUt if u do crack it let me know!
That shocked me too after he got done with the dyno. I think my issue is that 3 of the 4 mods I've done to the engine are flow dynamic mods that either add air or help to cool the air going into the engine. It only makes sense though that after doing those types of mods that eventually more fuel will be needed. I'm not spending 5K on a supercharger just to be able to reflash. I'm going to research the AEM FIC and the harness extender for the computer. There has to be a way to get more fuel to the engine. I think honda needs to learn that people that drive TL's like to mod their cars too. Not just people that drive civics and RSX's. I'm going to figure this out before I spend another dollar on engine mods.
Yes, And whats really got me aggrivated is that the first dyno runs on my car were done last summer when it was 86 degrees out and 50% humidity. And I lived further away from the dyno facility the first time too. 66% today and 41% humidity. I'm a little frustrated, but I'll figure it out. If I can hit 240- 245 hp to the wheels, that would figure to around 300 hp at the crank which is enough to have fun with some stock auto Type S cars. Maybe some auto G35 sedans. It would be a fun street car for sure. It's almost there.
That sounds like a good idea as long as it doesnt require deleting any of the emissions devices. Maybe take the spacer off and hang on to it till a reflash becomes availible for naturally aspirated TL's seens how I didn't pick up any power with it. I'll check with Josh at excellerate and see what one costs.
Definately looks like I found the limitations of the good Old dreaded speed density system used on these cars. What I'm thinking about doing is removing the spacer, and doing the J pipe. Couple of questions though. Can the Jpipe be used with the stock exhaust system, and I don't have to delete any emission equipment with the j pipe right. I don't want to delete anything emissions related. And I don't want a CEL.
I have no idea why Honda still uses a speed density setup. Even with our race cars we do a MAF setup for anything that sees the street and speed density for the track cars. I tried speed density on my GN many years ago and every time the weather changed I was retuning it, not fun.
The J-pipe will bolt right in with the stock exhaust in place and won't cause a CEL.
I'm sure your right on that, and thats why the next car I buy is going to be a project car and not an Acura. It's BS in my oppinion when you can just see the potential in an engine and not achieve it because of speed density air metering and no reflash being availible without boost. I can't stand electronic nannies.
I agree. And even if you didn't care about emissions and being legal, you still could not do stand alone engine management because the stock ecm is so tied into every system in the car even things like the climate control would not work right without it.
One thing I will say, these things are tuned for max power in stock form. They actually have a bit of knock retard, too much in my opinion on 91 octane. Throw some mods that increase airflow and it gets worse. However, it will adapt slowly via the 02 sensors and LT fuel trim. Add more air and you'll start seeing the values of the ST and then LT fuel trims changing to bring it back to the optimum AF ratio. The primary 02s are factory wideband sensors so that's a plus.
Just out of curiosity, where are the ST fuel trims suppose to be at because the guy had an ODB2 scanner hooked up to my car and was watching them. Air/Fuel was at 13.26 at 6624 rpm according to the dyno sheet. I have to agree with you on the tuning of these cars for max power in stock form. I just wish they gave a little more room to work with for mods rather than making all the parameters so tight. I'm going to take the spacer off when I get the j pipe. Then probably have my friend that has a speed shop and does exhaust work make me a custom catback system. I've looked at most all of the catback systems availible for the TL, and a lot of them are raspy and noisy. That tanabe system looks decent but I don't want the huge exhaust tips.
I ran low 13's:1 AF ratios on my cam'd RSX-s and would only assume the same general numbers would be good on the TL so your AF ratio number sound pretty good to me. I spent a ton of time tuning my KPRO and can really see where the TL would just spring to life with some good tuning. But what we got is what we got i guess.
What do you mean they couldnt do it? They didnt know how to install it, or they didnt have the software to tune it? The FIC is the best solution for tuning the TL right. If you follow the turbo threads, thats what all of the turbo TL's are running.
There's still just not a whole lot a tune can do NA.
Once you hit the optimium AF for power and the maximum timing for a given octane, you're done. No more power to be had.
If you did a NA tune for 100 unleaded, you can throw a little more timing in there but still, I would be surprised at more than 20hp.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
