Brake Replacement for 07 TL-S AT5??
Old 11-07-2008 | 01:06 PM
SFloyd's Avatar
9th Gear
Hello all,
The time has come to replace the front brake pads on my 07 TL-S. I was curious to see if any has used anything other than OEM replacement pads? I searched the subject and didn't find much.
Any help is appreciated! Links to the product would be even better!
Steve
Old 11-07-2008 | 01:26 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
i tried hawk hps, and got a rather school bus like squeek but only when i am parking
so try hawk ceramic... or go back to stock... but stock has 2 flaws, extremely dusty, and they wear way to fast thus why you have an 07 and already needs new pads
Old 11-07-2008 | 01:29 PM
SFloyd's Avatar
9th Gear
My stock brakes have squeaked forever! I have kinda grown tired of my brakes squealing on a $38K car. It's pathetic, let alone embarrasing!
Anyone have any Hawk ceramic pads that can share any input?
Old 11-07-2008 | 02:05 PM
Bearcat94's Avatar
AZ Community Team
Acura replaced the "old" Brembo spec at some point with the following changes:
- Included Shims
- Replaced Molycote M77 Grease with Brembo Grease.
I've got an '07 TL-S as well and have never had a squeak or groaning issue.
I recently replaced the 1st set of pads with a new set of OE pads and used the new shims and Brembo grease. No problems. I chose to accept the dust and faster wear.
Reason I stayed with OE pads is because I was not changing or turning the rotors and did not want to risk noise from Pad/Rotor material incompatibility.
When I replace the rotors, I am currently planning on Racing Brake Slotted with RB ET300 or ET500 pads. I have the RB combo on my '02 TL-S and dust is better than the '07 and stopping power is fantastic. Also, no noise (used M77 grease).
Old 11-07-2008 | 02:16 PM
SFloyd's Avatar
9th Gear
Thanks for the input. Keep it coming!
I plan to have the rotors turned. I shouldn't need to do anything else with the Hawk Ceramic pads, correct?
Old 11-13-2008 | 01:47 PM
saw1's Avatar
SFloyd, did you get a quote from the dealer for new front pads. i have an 07 TL-S with 24K miles and they told me i need new pads, i was quoted approx. $450.
Old 11-13-2008 | 02:00 PM
TheWanderer316's Avatar
'10 Shelby
^ i think the new pads only cost like $100 -$150, so $300 labor?
Old 11-13-2008 | 02:05 PM
korrupted's Avatar
J35A8
I had to get them done recently to pass inspection, but the only ones available were Wagner's.
They aren't actually half bad, just a little softer than OEM.
I would have preferred Hawks though.
Old 11-13-2008 | 02:39 PM
saw1's Avatar
Kauffman Tire in Atlanta quoted me $199 OEM front pads installed.
Old 11-13-2008 | 02:40 PM
bumski667's Avatar
NBP
i got my OE brembo pads from local dealer $150, then had it installed at another shop for 60 bucks. So 210...450 imo is a ripoff...
Have replaced mine twice already, and i have 37k on an 07 type-s
Old 11-13-2008 | 10:06 PM
JsL138's Avatar
Check out Racingbrake ET500. They dust way less and you can feel the improved braking.
Old 11-14-2008 | 10:10 AM
Bearcat94's Avatar
AZ Community Team
Dude why would you pay *anyone* to change these pads. It's the easiest pad change ever - designed for quick change.
Save the $60 and take your wife/gf out for dinner.
BTW - dealer rates are high. Full $210-ish retail on the pads, $100/hr labor. If they turn the rotors, and they will want to, add another $100 or so. $400 - $500 quote for new pads and old rotors.
Old 11-15-2008 | 12:16 AM
Crysophylos's Avatar
Originally Posted by Bearcat94
... If they turn the rotors...
Shouldn't you always turn the rotors when you change pads?
Old 11-15-2008 | 12:21 AM
Bearcat94's Avatar
AZ Community Team
Why? If they are not warped, they have even wear/runout/parallelism and you're staying with the same pad compound, what's the point?
Turning rotors for no reason just removes material --> heat builds faster --> rotors warp sooner.
Old 11-15-2008 | 12:27 AM
paliknight's Avatar
every how many miles should you change the brakes?
wait is there a DIY on changing brake pads? *expects stillhere153 to offer his free (cough) service*
Old 11-15-2008 | 12:53 AM
Bearcat94's Avatar
AZ Community Team
Change when the pads get to ~1.6mm or when they hit the metal squealer tabs.
Look here for DIY info/links:
https://acurazine.com/forums/3g-tl-problems-fixes-114/assistance-brakes-asap-696604/
Old 11-15-2008 | 12:57 AM
paliknight's Avatar
^^^thanks a lot man.
mada51589
05-03-2022 09:54 PM
HOWELLiNC
09-10-2015 02:39 PM
gqdabien
09-09-2015 12:41 AM
asahrts
09-04-2015 06:55 PM
nishant11
09-02-2015 11:34 AM
Quick Reply: Brake Replacement for 07 TL-S AT5??
