BOV on CT supercharger?
2005 Acura TL w/ Navi
i really dont know much about superchargers/turbos except that they increase airflow and boost power to 40+ HP at the wheels (ive never installed one or driven a car that had boost) , butt is it possible to add a blow off valve onto a comptech supercharger?
superchargers dont use a blow off valves only turbos because the turbine on the turbo keeps spining even when your not on the gas and to get the right amount of boost without blowing a motor you need the valve. where as the super charger is driven by the crank as well superhcargers dont produce nearly as much psi as a turbo can
jus curious because i did research on it and some people said its possible ..wasnt sure how true it was and jus confused me..
http://wiki.answers.com/Q/Does_a_BOV...a_supercharger
http://www.youtube.com/watch?v=ZZXdxxRmYhA
http://www.answerbag.com/q_view/83499
http://toyotaownersclub.com/forums/i...howtopic=77739
http://www.theminiforum.co.uk/forums...hp?t69099.html
i didnt think you could but im second guessing it
OMGWTF4THGENTL
If you guys really want to install a BOV on a supercharger for no other reason than "the noise", just buy this.
http://www.takakaira.co.jp/accessori...ightpager.html
Seriously...
Go trade your TL in for 1.8T Jetta if that's what you want.
![](http://www.takakaira.co.jp/accessories/nightpager/na_blowoff.jpg)
Seriously...
OMGWTF4THGENTL
No...
It'll likely never happen.
J32/J35 engine is highly tuned as is, and has a weak bottom end. Comptech SC only pushes 4psi of boost for a reason. You want a turbo pushing 18 lbs boost throught he motor will send a rod throgh the oil pan. To do a turbo right on the L virtually requires a new engine. Lower compression pistons, stronger rods, stronger main shaft, bolts, etc...
Supercharger has something a turbo don't... whine.
The grass is always greener eh?
yeah i would think the whine from the supercharger would get your jollies off enough, check out some youtube vids of tls with the SC the sound is pretty sweet, BOV's sound annoying, supercharger whines sound mean, if i had a turbo car i would be sure to have a quite BOV
347hp/300tq @ 4psi
Originally Posted by PeteThaPitbull
even tho they dont require them can you add one just for sound?
WHY?? im so tired of hearing that stupid whistle sound too. if i owned a turbo, id put in a recirculating BOV.
for every 20 cars i hear with a BOV, i hear 1 with a roots charger whine and its usually a svt cobra..
Originally Posted by evanj5
check out some youtube vids of the SC. the sound is pretty sweet,
![Naughty](https://acurazine.com/forums/images/smilies/naughty.gif)
http://www.youtube.com/watch?v=6LcQBhLAL5k
94 DC4 RS LSV/Turbo
Pete I think your broken hand has spread to your brain... First flame throwing exhaust... Now bov on s/c... What's next... Neon lights
Just busting your balls... But honestly some things should be done to provide a performance gain... Bov on s/c yields no gains... Cancelling its function...
AZ Community Team
Received 7,771 Likes
lmao..eva mendez is so sexy tho ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
BoricuaTL
04-08-2016 01:08 PM
Joe Avesyan
09-29-2015 03:57 PM
