Boosted S
Not your moms TL.
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
OK With all the info on Hondata coming out with the reflashes for the S/C's...I still have the question of will the CT S/C fit the type-s? Most of the other bolt ons fit...and Lookinco has the 3.5 block out of the RL, S/C'd...as far as I can gather the 3.5 is just the 3.2 with a lil increase in stroke and some internal work...so whats to say it wont fit? has anyone tried? With the Hondata development, I am seriosly considering the S/c.....any input?
i can check for you if the motor measurements on my 3.2 TL and you can post yours and that can help. Also I will post the instructions on the installation, check to see if the bracket that the SC uses is still in the correct place. I hope this can help.
Not your moms TL.
im down like 4 flat tires...just lemme know what measurements youre taking and ill get mine....i heard that our intake mani's are diff too...i think that might have some fitment issues there...
http://www.comptechusa.com/store/med...-SCKit2005.pdf
BUT YOU WILL NEED THE CAR TO BE TUNED PROFESSIONALY BECAUSE THE COMPTECH ACM IS NOT CONFIGURED FOR THE 3.5 MOTOR NEEDS!!!!!!! RUNNING WITHOUT A TUNE CAN DAMAGE THE ENGINE SEVERELY.
Not your moms TL.
no, from what I understand, the intake mainfold after the Throttle body is supposedly wider, covering more engine, thus fitment issues....
OMGWTF4THGENTL
Originally Posted by Kennedy
What's different about the manual? I though all they changes was they installed a restrictor in the clutch slave to keep you from coming out of the clutch too fast and breaking gear teeth.
Not your moms TL.
Kennedy: i was talking about the type-s intake manifold supposedly being wider and going further side to side than the 3.2...but that might not have anything to do with how the S/C mounts, I havent looked too far into it...
OMGWTF4THGENTL
BoricuaTL
04-08-2016 01:08 PM
NBP_BALLER
09-23-2015 08:18 PM
09-14-2015 10:48 AM
