Blown Engine - Another HBP Victim
CTS-V Import Slayer
As most of you know....I sold my 2005 TL as is (meaning I didnt remove anything or part it out at all) to a guy down the street from me and got a 2005 CTS-V to play in.
I should note here...it was supercharged...evo2 system...all richie parts beforehand exhaust wise...high boost pulley...CAI.....ect.
Well...as most of you also know...I kind of had it set up so I could run it this way with no issues. Whats the first thing he does? Swaps the EVO2 catback system back to OEM and continues to drive it. (of course...raising backpressure on the motor, raising IATS, and raising boost level a bit due to not being as efficient) As he is a friend, I kind of mentioned in passing to him that this might not be the best scenario - but that it was his car.
He then drives the car from Indiana to Florida and back. Soon after returning from Florida....the engine began to smoke wildly out of the catch can breather system that is installed on the car.
So....car ends up at a friends shop here in Indy to have a look and see what the deal is. Brian finds stock OEM spark plugs installed in the car (somewhere along the line after buying the car...the owner took it to the dealer for a service as called for on the dash A3-B1---whatever it was) I am assuming the dealer changed the plugs back to stock OEM plugs? Not good....and further led to the engines demise IMO. And I note...the owner DROVE the car into the shop. Before it was over...engine was TOAST! Brian tried to start it again the next morning and said it was hydrolocked at that point. lol
So....end of story...the guy I sold the car to had another engine installed...swapped out the HBP for a normal boost pulley (I told him to do that a LONG time ago and even gave him the pulley) and retained the supercharger setup. I guess the Innovative Motor Mounts were a little toast too....Brian said the torque side mounts had a LOT of play in them and had actually rounded/elongated out the hole in the bushing. He had a sleeve that would fit it and take up the slack...so fixed the issue I guess and make the mount even more solid in the end? Dunno.
I kept trying to talk the guy into removing everything and making the new motor completely OEM as thats probably better for him and daily use given he has limited to no knowledge of cars....but he decided to go supercharged still.
Moral of the story.....dont buy a car setup to race if you dont know anything about working on cars or how they work. And if you do...for gods sake...dont go changing the perameters of the setup that was given to you that worked.
CTS-V Import Slayer
Here was the setup he bought from me....
Description:
2005 WDP Acura TL, A-Spec
Engine/Drivetrain Modifications:
Unorthodox Racing Light Weight Crank Pulley
Indy Carbon Fiber Custom CF Engine Shroud
Comptech Supercharger
Comptech Polished Oil Cap
Custom Saldana Racing Aluminum Radiator and HP Fans
Custom Fabricated CAI Unit
Greddy EVO2 Stainless Steel Catback Exhaust
Outlaw Engineering Thermoblok Spacers
Richie J-Pipe
Richie Third Cat Delete
Richie Precat Delete Pipes
E-Shift Performance Hi-Flo Cats (removed/baked)
Custom Catch Can/Breather System
Optima Yellow Top Battery (removed)
Suspension Modifications:
Comptech Rear Sway Bar
A-Spec Shocks
A-Spec Springs
Wheels/Tires Modifications:
A-Spec Chrome Looks Rims 18x8 (8 each)
Kumho V-710 Slicks (Racing Tires)
Yokohama ASV100 (Summer Tires)
Michelin Alpin Sport (Snow Tires)
Blue Annodized Valve Stem Caps
Gorilla Annodized Aluminum Lugs
Interior/Exterior Modifications:
A-Spec Steering Wheel
Ultimate Aluminum Racing Pedals
Carbon Fiber Gauge Mounting Cups (2 each)
Exact Mats
Hurst Old School Shifter Knob
Shortened Door Lock Botton Mod
Switchblade Key System (2)
TL-S Headrests
A-Spec Body Kit
OEM WDP Wing Spoiler
Black Chrome Emblems
Chrome "Blown" Emblem
Shaved Doorlock Keyhole Mod
OEM Smoked Door/Window Visors
TL-S Sidemarkers (2007)
TL-S Tail Light Housings (2007)
Versus Motorsports Double Sided Carbon Fiber Hood
AEM Uego Wideband AFR Gauge
Autometer SuperSportII Manual Boost Gauge
Description:
Richie J-Pipe
A-Spec Shocks
A-Spec Springs
Exact Mats
TL-S Headrests
A-Spec Body Kit
Damn, sad to hear. Your car was always one of the best...very well put together/planned out. Definitely not the kind of thing you mess with unless you know what you're doing.
Because of that, I think the thread title is a little strong. The HBP was not the cause of the blown engine, at least not until the supporting set up was changed, rendering it to be too much.
Anyway, good to see you. I should call or e-mail, but I'm really bad about those sorts of things. Pop into Car Talk sometime with an update on the V (what you've done to it, how last season went, etc.).
CTS-V Import Slayer
Dunno. I know he is trying to sell the Rotora BBK off the car as he also changed that back to OEM brakes. Dont ask. Dunno why? lol
Ancient chinese secret! Ole blue.
I have another local guy asking the same. He reinstalled it on the new setup (well...Brian did it for him) with the normal boost pulley on just a more or less...basic install with just the front side exhaust mods still on the car....all the Richie stuff he left on...no cats, ect. But switched it to a normal boost and got a safe plug at the same time.
Agreed. It was HIM that blew it more or less. lol
Brian sent it back to the yard as a core more or less. I think he got an engine out of a TL with 30,000 mile it and began swapping parts. I think he was out the door for around $3000 when it was over. Brian is a friend of mine and gave him a good deal.
It was over at Performance Driven LLC if you know where thats at. Near the airport.
http://www.performancedrivenllc.com/
Brian owns the shop....very good guy and highly recommend. Very knowledgeable and very fair and about the most honest guy I know.
Oh...Brian also mentioned that the plugs showed signs of HUGE detonation events. Imagine that? lol
CTS-V Import Slayer
Oh...and as for what has been done to the CTS-V as of yet.
Right now its just a cold air car with a catback system. Till I upgrade the axles I dont feel real comfortable tossing much more power at it.
Here is what I am looking at...gotta eliminate that wheel hop for a good launch. Drive Shaft Shop....
1000HP Level 5 Rear axles RA5264L5 / RA5265L5
Description:The Level 5 CTS-V axles are designed to handle up to 1000HP. Using our chromoly center bars, 108mm Porsche-style CV's and bolt-on chromoly inner and outer stubs, these are a direct bolt-on that fit the stock hubs and come complete with all the necessary hardware. Not only will these axles handle the horsepower, we have used different diameter bars on each side which will eliminate wheelhop! The CTS-V is notorious for wheelhop at launch which can be extremely damaging to the drivetrain and makes getting traction very difficult. By allowing the axle bars to torsionally twist at different rates the result is traction, not wheelhop. These axles are priced as a set and have a 1-year warranty.
Product Category:2004-2006 6-Speed Manual
Price:$1699.99
At that point...its going into Mike Norris for a Maggie Supercharger setup among other things. Mike just moved from Florida to Indiana a number of months ago and is a world class LSx tuner.
http://www.mikenorrismotorsports.com/Home_Page.html
Whole thing when done should have another $10,000 tossed into it after supercharger, setup, and tune. Should put me right around $35,000 - $36,000 invested total....WAY less than what I had in the Acura and WAY faster. But I gotta admit....its not an Acura. lol I miss the Acura still.
Price:$1699.99
CTS-V Import Slayer
I will ask him. I know he was PMing me about selling it for him. I will tell you up front...you are going to have to buy ONE front rotor for it. He cracked one...and rather than buy a new rotor...he bought the OEM setup from me and replaced it ALL. So there is a good BBK with one bad rotor just sitting in boxes now.
I will find out what he wants for it and let you know or list it here in the classifieds as it should be.
It's unfortunate that he blew the engine. I know he changed the plugs and exhaust but IMO, you were playing with fire the whole time. Auto-x with short bursts is perfectly fine. Where the trouble happens is running it hard in the upper gears where load is the highest and detonation is most likely. If he only would've had a methanol kit it would have lived even with the OEM exhaust and plugs.
About the BBK, are these the 2pc 13" Rotoras? What about the rears?
You think so? I'd think the 3.6L would have better power under the curve. NA with the 3.6 he probably could've made 320-330whp and 300wtq. With the higher displacement I'd think he'd have more torque in the lower RPMs, hell, all over the RPM band.
But you have to think of boost as the equivilent of a larger engine. You're flowing 20-50% more air through the engine at every rpm. At 7.5psi the 3.2L is acting as if it were a 4.8L. At 14.7psi it's acting as if it were a 6.4L.
He will definately gain hp everywhere with the larger engine and I prefer this route to crazy cams and super flowing heads..
Too much backpressure in the exhaust leaves more cylinder pressure after the exhaust event. The intake valve opens to a higher cylinder pressure on the intake stroke, increasing "restriction" and increasing boost. It sounds crazy but it's true.
SidhuSaaB
05-30-2020 12:40 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
joflewbyu2
10-08-2015 11:16 AM
k6biv
09-10-2015 06:37 PM
