Best TL Performance is...?
Old May 15, 2005 | 01:15 PM
Minidisc's Avatar
zZzZzzZzz...
Question Best TL Performance is...?
Lets say hypothetically the TL had to race <insert car here> (doesn't matter which car because I know some cars perform better from 0-100km and some are better from a rolling start), I just want to know for the TL, will it give a better performance (acceleration,etc..) if it had a rolling start from 60km/hr? 100km/hr? or how about from rest?
I think I read somewhere that the TL has more high end torque as opposed to other cars who have low end torque, how does this factor into the performance? And does the V-Tech range start from approximately 5k RPM and would this mean that maybe it would be advatagous regardless of whether I start from rest or rolling start to rev the engine up to that range before letting the car go?
Sorry for all the questions...I guess they can basically be summed up with "What is the best way to win a short race against another car?"
P.S. I don't condone racing, I am just curious and would like to know the ability of my car and the way to get the best performance out of it. Thanks!
Old May 15, 2005 | 01:34 PM
Hokie D's Avatar
2002 TL Type S
Generally the car that makes the most power (if weight for each vehicle is appx. the same) will win from a roll. From a roll you would want to downshift to get your car in the powerband of your engine. Both cars can do this so a fatter HP/TQ curve, not necessarily peak will help you here.
From a dead stop the car who can put the most power to the pavement will win. Just ask anyone with gobs of torque how important launching at the correct engine speed, improving traction, and getting the proper gear is. Once you're out of the hole, the car making the most power will start pulling on the other guy. There are a lot of variables.
Old May 15, 2005 | 01:59 PM
Minidisc's Avatar
zZzZzzZzz...
Thanks, but how about for the TL specifically? What kind of a hp/torque curve does a TL have?
Old May 15, 2005 | 10:17 PM
Pro Stock John's Avatar
Car Addict
Climbs up and up... Peaky like you would expect from a 3.2 liter engine.
Racing from roll would be better than from a dead stop only because of the tire spin.
Old May 16, 2005 | 08:03 PM
NFLblitze1's Avatar
Youse Gots Sacked
the TL is slow off the starting line, because it lacks low end torque, but the TL is also very fast in higher RPM, if you u want low end torque you could modify your car and add the Comptech Exhaust, and an AEM Intake. this won't improve DRASTICALLY but it will give you a better feel with acceleration
Old May 17, 2005 | 08:07 AM
EpiK's Avatar
That's part of it, but our TLs are also comparitively slow off the line vs. comparible horsepower cars because of the FWD.
The easiest way to explain this is like this: Do you know how when you hit the gas hard, the car's nose seems to come up a bit and all your weight gets tossed to the back (and you feel pressed against the back of the seat?)
Well, that's GOOD for RWD cars because their power comes from the rear end of the car which currently has more downforce and limits spinning of the wheels - meaning better traction & better accelleration. In our TLs, when the car takes off hard, there is less downforce on the front wheels creating more spin/less traction and a loss of some accelleration.
Hope that makes sense. You are better off with a rolling start...
Remember to only race on a closed track.
Old May 18, 2005 | 02:11 PM
Minidisc's Avatar
zZzZzzZzz...
Oh okay, thanks.
Also, is it safe to rev the engine from a standstill to like a higher rpm before launching the car, if so, how do we approach it? What are the consequences of this, in terms of damage to the car.
Old May 18, 2005 | 02:40 PM
JOES05tl's Avatar
If your manual, then just FRY up your clutch and rev the rpm's to as high as they can go, and move the car with the clutch. P.S.- Dont do this often. I don't recommend being too hard on the stock clutch. I'm in the process of fixing mine now! Benefit: good solid launches. Consequence: FRIED CLUTCH
Old May 20, 2005 | 03:14 AM
spdntckt's Avatar
actually.. an exhaust and intake wont do anything for low end torque.. many times it makes it worse... intake exhaust help at the top end.. check any dyno chart..
Old May 20, 2005 | 07:35 AM
GoBig's Avatar
Sorry, I have to respectfully disagree. I have an AEM CAI and a custom exhaust with Comptech Mufflers and I actually noticed an improvement in both low-end (and high-end) torque. Also, check out last month's Honda Tunning Magazine (http://hondatuningmagazine.com/tech/0505ht_tl/) where they featured a TL w/ an Injen CAI and a Comptech Exhaust and the car gained torque (and horsepower) accross the board. See
Old May 20, 2005 | 09:56 AM
Car Addict
Nice dyno sheet, that's a great gain.
Old May 22, 2005 | 03:21 PM
BigB2k5's Avatar
The only thing is, if you go to injens site the intake for TL shows loss in TQ in low end but good gains up high if you just do intake alone...
The funny part is I then look at AEM, and both car's base lines are SOO far off its not even funny... and AEM shows no loss but thats some fake looking dyno... I want to see a real dyno sheet of before and after with aem...
Old May 22, 2005 | 06:52 PM
Car Addict
I would not try to launch our cars too high you will spin your ass off. If you slip the clutch out at high rpms you will eventually glaze the clutch disc, and the clutch will slip.
On the street I tach it up to 1500 and roll out fast, if I am racing somebody else.
Old May 22, 2005 | 07:09 PM
GoBig's Avatar
The basline dyno looks accurate because it practically matches mine...both were dyno'd on a dynapack. The increase in power from the cai however obviously needs to be confirmed.
Old May 23, 2005 | 11:11 AM
Minidisc's Avatar
zZzZzzZzz...
Since I have a 5AT, I do not have a clutch, is there another way to rev it up for a 5AT?
Old May 23, 2005 | 05:34 PM
Car Addict
You can brake torque the engine, give it gas while also holding down the brake. I would not go over like 1200-1500.
Old May 23, 2005 | 05:49 PM
TL Tita's Avatar
what custom exhuast do u have? A magnaflow?
Old May 23, 2005 | 08:43 PM
GoBig's Avatar
I"m assuming you're asking me. I had it custom built by a shop in so. cal. It's all stainless steel w/ mandrel bent fittings. The resonator is Magnaflow and the mufflers are Comptech.
Old May 23, 2005 | 09:07 PM
TL Tita's Avatar
wow. thats awesome. HOw much did it cost? im interested if purchasing is possible. NO way in hell am i gonna spend a grand on the comptechs
Old May 23, 2005 | 09:08 PM
TL Tita's Avatar
put it in neutral. rev it up to the redline and put it in drive. LOL u will spin ur ass off but its still fun (but bad). Or the ebrake trick will work. Autos are not meant to be raced
Get a manual, its more fun
Old May 23, 2005 | 09:13 PM
GoBig's Avatar
$45 each for the Mufflers
$30 each for the 4" tips
$90 for the Magnaflow Resonator
$400 for the SS exhaust and installation for all
Total = $565
Old May 23, 2005 | 11:22 PM
TL Tita's Avatar
wow. that may be worth it...any clips?
Old May 25, 2005 | 07:25 AM
GoBig's Avatar
Not yet...I'll see what I can do. I just need a place to host.
Old May 25, 2005 | 07:53 AM
iTISTIC's Avatar
I'll put it up on my server if you want. Let me know.
Old May 25, 2005 | 10:55 AM
ASPEC05's Avatar
Tifa's Fiancé
yeah thatd be cool
Old May 25, 2005 | 08:43 PM
jchcmax's Avatar
Registered VTEC junkie
Thumbs up
Nice article, those are some convincing gains! I had my Integra dyno'ed at MD automotive, used to be "Jackson Racing". Mark Dibella at MD Automotive installed my supercharger on my Integra long ago.
Old May 25, 2005 | 09:48 PM
GoBig's Avatar
I tried to email it to you, but at 14.4MB it was too much for your email system.
Anyone else want to host?
Old May 25, 2005 | 11:21 PM
Sagaboy's Avatar
My First Post
Hi go big ill host.......
www.sagaboy.com
http://www.sagaboy.com/GoBig/
user could be GoBig@sagaboy.com and pass is GoBig
Old May 26, 2005 | 07:52 PM
GoBig's Avatar
www.sagaboy.com
Thanks for offering! I PMed you.
Old May 26, 2005 | 11:43 PM
GoBig's Avatar
Thanks to Sagaboy, I now have a hosted clip of my exhaust. See Exhaust Clip
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
