Best muffler options?
Old Jul 11, 2012 | 02:54 AM
TheBumbino's Avatar
I have been searching awhile but have still be unable to find anything good on the topic.
I am looking into exhaust modifications particularly mid-muffler and replacing stock resonator along with mufflers (I already will be getting a J-Pipe.)
I really want to replace the stock mufflers but my main issue lies with the appearance. I want to maintain a stock appearance I do NOT want a fart can style with huge round tips such as the greddy exhaust's. The only thing I have seen seen that would fit this is the ATLP exhaust which is expensive but would eliminate the need to remove my resonator and mid muffler correct? It has a nice rounded appearance that is similar to the stock but if possible I want the stock square tips. From what I can see my only option is to have a shop cut off the stock tips and re-weld them. I do not have the tools for that myself.
I also have a base with a-spec rear so s-type quads are out of the question.
I'm looking most of all for a bit for aggressive sound will maintaining stock appearance. I know that a catback will not produce much gains that's what the j-pipe is for.
Any suggestions?
Old Jul 11, 2012 | 09:52 AM
bouncer07's Avatar
So your saying you want to stay stock pipings but remove stock resonator, mid muffler, and mufflers. You can custom it all to your likings.
Or Depends if you're looking to put $1,000+ for the exhaust. There's a few vendors here that can give you your answer. Interact with them, Phone them, Email them, etc.
Old Jul 11, 2012 | 10:07 AM
EvilVirus's Avatar
OP just save up and get the whole system you wont regret it
Old Jul 11, 2012 | 07:16 PM
TheBumbino's Avatar
I think that would be the best idea and will be alot less work in the end.
Old Jul 11, 2012 | 08:44 PM
Xiomaro's Avatar
1st 3g Turbo TL-S
nah, go custom. u can get a nice setup made in the 800$ range if you find a decent shop
Old Jul 12, 2012 | 10:02 AM
EvilVirus's Avatar
Damn for that much you might as well buy a use bolt on exhaust
Old Jul 13, 2012 | 12:43 AM
TheBumbino's Avatar
I wonder if you could get a true dual exhaust made for that much.
I know the ATLP exhaust is not a true dual setup.
Old Jul 13, 2012 | 09:51 AM
McCollins23's Avatar
Chapter Leader (Midwest Region)
You should be able to go true duals for that price.
Old Jul 18, 2012 | 03:31 AM
DomGSR-T's Avatar
I have a custom real true dual on my TL-S and it took around 5 hours to create it. So i'd say with cheap piping it's possible to get a real true dual for 800$ but with high quality 304 sanitair stainless it won't be possible...
Old Jul 23, 2012 | 10:50 PM
TheBumbino's Avatar
I figured as much. I asked a guy at a local shop and he said my best option is to just get an aftermarket catback. My only option is stainless steel due to living in PA. The salt in the winter can be brutal on a car.
Old Jul 24, 2012 | 09:21 AM
breck569's Avatar
i did stage 3 with dynomax resonator. good sound. no rasp.
Old Jul 25, 2012 | 05:57 AM
DANELSON's Avatar
i have just put on my j pipe and deleted my mid muffler..its sounds good at low rpms. going to put a magnaflow resonator to cut out the rasp
Old Jul 25, 2012 | 07:57 PM
TrustinHFDJ's Avatar
Series Motor's
It all really depends what you are going for, there is no exact answer; since everyone has there individual and ideal driving conditions, and the fact that any modification plays a roll in the whole set up.
However, I would have to say with everyone else as well, the custom would be the best. If you cannot install it yourself, I would suggest just purchasing what you think is best; rather than an option given to you by the business's retailer which is a lot more restrictive.
Old Jul 25, 2012 | 09:10 PM
nbp06aspec's Avatar
Go with ATLP, one of the best exhaust, you will not regret it, but then again I may be biased.
Old Jul 25, 2012 | 10:26 PM
Bruce Banner's Avatar
I'm about to put on a jpipe with my mid muffled delete.
How bad is the rasp?
Old Jul 25, 2012 | 10:59 PM
DANELSON's Avatar
On the accelration not bad but you hear it more around 3500 rpms 2000 rpms as you slow down.
CL-S progression 01
Jan 26, 2016 04:15 PM
DerrickW
Nov 15, 2015 05:52 PM
merc009
Sep 29, 2015 03:06 PM
johnpancakes014
Sep 27, 2015 12:58 PM
