Any ideas for first performance upgrade?
Old Aug 10, 2011 | 01:21 PM
  #41
oarichard's Avatar
Yea the PCDs definitely come with side effects but they give the most power for your car than any other bolt on. Then very similar in power but right behind PCDs is the J-Pipe. Then exhaust, and finally cai.
Old Aug 10, 2011 | 01:22 PM
  #42
oarichard's Avatar
koni yellow's paired with aspec springs.
Go for some coilovers instead of spring/shock combo!
I promise you, you won't regret it.
I never regretted my Tein SS, ever.
Old Aug 10, 2011 | 01:29 PM
  #43
Thanks, butt I've done my research and also purchased my suspension set up.
I wont EVER regret my set up, either.
As I'm looking for performance over looks and the aspec springs proved to shave off time on a track.
Old Aug 10, 2011 | 01:55 PM
  #44
maharajamd's Avatar
Stick to your guns man. I agree.
Old Aug 10, 2011 | 02:44 PM
  #45
oarichard's Avatar
Do they compare the spring/shock combo to any type of coilovers setup in regards to track time?
Anywho.. I'm definitely for performance also. Can't have all show but no go.
Old Aug 11, 2011 | 06:13 PM
  #46
eduardmc's Avatar
Acura TL 04, G37s 19"
how is the sound after j pipe mod. Those it sound deeper annoying louder or just a big louder?
Old Aug 11, 2011 | 06:38 PM
  #47
vietxquangstah's Avatar
VERY LITTLE to NO difference in the sound at all.
the j-pipe mod isn't a mod you do for "sound" it's a mod you do to let your engine breath a bit easier, in doing so you gain some low end tq. i noticed more tq in the 2-3k rpm range after installling my XLR8 j-pipe.
like i said, i noticed very little sound difference at all. i would say there is no sound difference, but i'm sure someone out there will say it has a very very slight deeper growl...
if you want sound, exhaust is the way to go. but than you would be bottle necking your exhaust system so you might as well do j-pipe and your cat / precats..
Old Aug 11, 2011 | 06:58 PM
  #48
^correct.
its deeper but not louder
http://www.youtube.com/watch?v=eTifsJrqcaE
Old Aug 14, 2011 | 07:13 PM
  #49
Nuhbe3zy's Avatar
im new xD
i have a noob question.. i just bought a pre owned tl type s 2007 and i am veryy amazed on how much shit im seeing here.. well my first question is for the j pipe.. will i have to buy another cat converter??
Old Aug 14, 2011 | 07:53 PM
  #50
maharajamd's Avatar
no
Old Aug 14, 2011 | 09:51 PM
  #51
Old Aug 14, 2011 | 10:53 PM
  #52
UA6's Avatar
UA6
I'd just get the exhaust first. A little bit better performance plus the car will look and sound better.
Old Aug 15, 2011 | 03:32 PM
  #53
thrasher865's Avatar
Hmm. Depends on your definition of performance.
For best in-cabin heat performance, I would suggest a good window tinting.
For best poser-formance, I would suggest a TL-S badge.
For best fuel economy performance, eBay sells this thing you put in your intake, and it will create a vortex with your incoming air. The flow pattern of this thing is so much more efficient that more air can make it through the throttle body, and it's essentially a low powered turbo-charger. You might have to upgrade your injectors, though.
Old Aug 15, 2011 | 06:27 PM
  #54
k1x's Avatar
k1x
rocking my vs-sexx!!!
^ lol
Old Aug 16, 2011 | 10:06 AM
  #55
9632tl's Avatar
Radical Member
Did anyone notice an mpg increase/decrease with the j pipe?
Old Aug 16, 2011 | 10:11 AM
  #56
technically, freeing up exhaust flow can increase MPG, but the power and sound always negates that as the driver will always want to push the skinny pedal
Old Aug 16, 2011 | 10:31 AM
  #57
9632tl's Avatar
Radical Member
Im looking at heeltoe now, and they have the RV6, and the XLR8. What's the difference between the two? The site isn't very descriptive. Does the RV6 delete the cat?
Old Aug 16, 2011 | 10:38 AM
  #58
^yes. the rv6 is the latest and the greatest. debuting in 2010, whereas the others were introduced in 2008.
the rv6 is the 3rd version, which came improvements.
by elongating the primaries, which delete the 3rd cat, the jpipe proves to make more horses than the competitors.
also it has stock like clearance attributes, so it doesnt hang low to the ground
Old Aug 16, 2011 | 10:51 AM
  #59
9632tl's Avatar
Radical Member
But will that not throw a CEL? And how low are we talking here?
I don't wanna spend 400$ and let it drag on the ground...
Old Aug 16, 2011 | 10:54 AM
  #60
^no, the rv6 v3 has the same clearance as stock. it wont touch the ground. it fits nice and stock. STOCK STOCK STOCK STOCK CLEARANCE!
you will not get a CEL because there are no sensors on the 3rd cat.
Old Aug 16, 2011 | 10:59 AM
  #61
9632tl's Avatar
Radical Member
I was talking about clearance on the xlr8. I didn't realize that there wasn't an o2 sensor back there.
thank you fir your help!
Are there any other recommendations as to where to purchase one?
Old Aug 16, 2011 | 11:00 AM
  #62
i dont know because i dont own a xlr8.
you could probably purchase it from XLR8 at excelerate performance.com
butt, xlr8 is coming out with a new version that mimics rv6 v3. so your best bet would be to purchase the rv6 v3 or wait for the new version of xlr8.
just a heads up.
Old Aug 16, 2011 | 11:04 AM
  #63
SharksBreath's Avatar
BANNED
so doez the rv6 v3 have a same clearance as the stock or doez it hang lowar?
Old Aug 16, 2011 | 11:10 AM
  #64
dont you own the rv6 V3?
cant you simply look underneath your vehicle and see if its touching the ground?
Old Aug 16, 2011 | 12:03 PM
  #65
9632tl's Avatar
Radical Member
One more annoying question
In your opinion, Was it worth the price??
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 17, 2015 10:16 AM
