another clutch thread
#42
So what if you already have a light crank pulley?
Is there any advantages of the stock FW over a aftermarket lightened FW?
I kept the stock crank pulley so I could go the other way if there are distinct advantages of heavy crank pulley/light FW vs light crank pulley/stock FW.
advantages...well it depends on what you're looking for...the stock FW is a dual mass...thats to smoothen out the shifts.
if youve ever seen one, its made outta 2 pieces, with springs in between..to absorb drivetrain shock, which also initially delays direct power delivery to the wheels...that, coupled with the DBW throttle, and slave cylinder check valve, create a delay in shifts, but also take away a lot of drivetrain shock, and harsh engagements, which of course, its something average drivers will complain about.
but if ur looking for pure performance...DBW isn't the way to go, neither is a dual mass FW, and neither is a check valve inside the slave cylinder, or a self adjusting PP
remember, this car was designed as a regular car with a taste of sportiness..and not a straight up sports car with street driveablility.
again...the best way to go about this is...stock crank pulley, and light weight FW. Look, im all for performance, so if im gonna set anything up, its going to be strictly towards that.
and to answer your question from the last post...i dont know where these threads are, but as ive said before...our crank pulley is a harmonic balancer!
#44
yes im talking about the throttle control...my setup is currently stock...ive thought about setting smth up to have it completely cabled for a long time, but i never got to it. focus has been on other things, and aside from accomplishing new things...tackling problems has always been a big part of the journey lol.
#47
Green Machine
if you order from them direct they will send out the correct flywheel with updated pp and bearing. if you order from a 3 person you will get the bullshit kit and it will fail. thats what happen to me the first time.. just call them and talk to jose and tell him you got a tl and you want the kit with the right ring gear and you will hook you up..i think they still have free shipping if you buy the whole kit from them too...
#48
I want to get the stage 3 with alum FW. I called CM yesterday to ask if I have to send my FW in. The saleman said since I have an 04 TL, that they have the correct set-up. He also said that 05 and up are the ones that have to send in their FW. If this is true, this is going to be my next mod!
Since the ring gear is the only problem then the starters should have a different part number as well. Checked that and they're the same too.
#49
1st 3g Turbo TL-S
my clutch is in as of today. I'm not sure if it was a CM error or just my mechanic being the dumbass he really is, but he was having quite a few issues getting the clutch to disengage. The clutch pedal has to be on the floor to be disengaged and even then it feels like it's just barely making it. I think i need a stronger master cylinder. he said something about the adjuster rod under the dash at the pedal. i drove it around a bit... damn. The PP on my setup is strong! and there is NO give, all go, but after a while it was tough to get in gear. Opel i could really use your imput on this one.
#51
347hp/300tq @ 4psi
^^ did you adjust it?? if not, thats your problem. the height of the diaphram is completely different than the stock unit, so its a must and needs to be adjusted out (to where your pedal goes higher. its really simple to do and all you need is a 12mm wrench
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
give it a shot and let me know how it goes.
#52
if bleeding has been done correctly...you can try the rod under the dash, by screwing it out to create some more push on the master cylinder...i honestly dont like this idea, as in most cases, it creates pressure on the PP and can cause clutch slippage especially on stock clutches...so be careful, and do it very little at a time
im just not too sure if ur mechanic did this correctly.
#55
1st 3g Turbo TL-S
another thing is he was worried that since the rod is all the way out that it might bend while i'm shifting? i was also talking with a friend who said i might need to have the master cylinder replaced? I have a feeling that this retard didn't bleed and refill the clutch right, i'm going to take it to a tranny shop and see what they say too.
Yes i had the FW sent in and remade. no ring gear issue, thank god!
#59
under constant pressure...but id be more worried about the clutch when there's constant pressure on the MC...best way to do this is, while you adjust the MC rod, have someone keep an eye on the slave cylinder so you can adjust it untill the pp arm starts moving, and keep it at its minimal...this way you gain max pedal travel going towards the disengagement
#60
#62
I (don't) whine.
Xiomaro, I would DEFINITELY start by bleeding the clutch again..you can mess with the slave cylinder and pedal height but having that too far off can cause your disk to crack over time. I had the EXACT same problem when I first installed the kit as well. Bleed and re-bleed and you might not have to mess with anything else.
#70
its a little expensive but it works 100%
i bought a omni clutch master cylinder for a rsx type s which has the same oem part number as our cars ...then a ss line straight from that to an oem rsx type s slave cylinder it "dosent have the check valve like our cars" ...i paid almost 350 for every thing but its worth every penny...clutch engagement is instant with solid pedal pressure...
#71
there is no problems with "our master cylinder"
Not having the checkvalve doesnt justify $350 when u can remove it from our slave cylinder for FREE
any clutch will engage instantly with a "Solid PP", ...
once ur foot is off the pedal, the pressure on the fluid is removed, and it will all instantly flow back depending on how heavy the PP is.
You replaced a stock HARD line with a SS one! that's fine and dandy, but I don't really get it. there's just a 12" hose connecting the 2 hard lines our clutch system has and that small hose is available from Mr.heeltoe.
not attacking u or anything...i just would really like to know what the problem is, that you say you have a fix for...i just dont even know of a problem
#74
04Accord has reported such problem, as blowing the MC, and it was caused by the PP being with flat diaphram...
maybe he will chime in.
Btw, sorry i didnt even realize you're the OP lol..
I didnt even have a clue you had an aftermarket clutch, that's why i expressed the surprise at you changing your whole system.
#75
Damn, I didn't realize this either, sorry about that. Getting all these threads all blended together.
So many things to keep in mind when upgrading.
When the dealer changed your master cylinder twice, did they know you were running an aftermarket clutch? Was it under warranty or did you pay for it?
#77
do these "techs" at the dealers ever know anything? Especially the service advisors, that each time i ever went to the dealer (stopped going 4 years ago) never knew wtf i was talking about
same clutch as him...yes i can understand that, same stage 3 kit...but smth can be diff and u wouldn't notice, such as what i mentioned about the PP..thats why i asked!
#80
1st 3g Turbo TL-S
i know i've got a flat top pp in mine. And i did get everything adjusted correctly. bled the system added the SS line and refilled... so much air in the line btw. so i'm gona roll on what i've got setup now and if my master cylinder goes i'll swap straight to the upgraded. For now i've got great grab and smooth pressure. I will never go back to that F@#%Tard that did my clutch job. I'm still finding stuff to fix from this guy. not to mention a nice big dent on one of my fenders...
