aem bypass valve
Old Sep 4, 2005 | 10:58 AM
BlackTLaspec's Avatar
aem bypass valve
Will the bypass valve fit on the cai for a 2005 6mt TL? It wasn't listed on AEM's site as being avail for the 04-05 so I was just wondering if there would be fitment issues.
Old Sep 4, 2005 | 11:14 AM
NFLblitze1's Avatar
Youse Gots Sacked
im pretty sure that it will fit, the AEM Bypass valve dosn't neccesarilly pertain to your car specs, it pertains to specs of the intake tubing, you have to cut the AEM tubing in half and attach the bypass valve inbetween the tubing so it prevents water from getting sucked up into the engine. ive seen pictures on here of peoples work with the bypass valve so im pretty sure your fine. if the bypass valve has the same diameter of the AEM tubing then it will fit
Old Sep 5, 2005 | 09:40 AM
damn you have to cut it in half? is that always the case or is it because the tube is usually 2 pieces and on the 04-05 model its 1?
Old Sep 13, 2005 | 09:36 PM
Rick-H's Avatar
Yes-- it ONE piece-- and believe you will have to cut it into 3 pieces -- and remove a small section that will be replaced by the by pass valve-- unless you wanted to put the by-pass valve very near the filter or the throttle body.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
kingbharj
Sep 25, 2015 07:25 PM
