Add resonator or replace stock resonator?
TL Luver (06-14-2011)
#42
2006 6spd
thanks for answering my questions i know i may seem impatient and should just wait to install my own...just kinda dont want to order the second resonator just yet untill i install the pcd's...
#43
Former Sponsor
Looks like the Magnaflow #10426 is a winner. I plan on stocking up and selling them with the PCDs.
Before with Rasp no Resonators
Outside car: Idle and revs.
YouTube - ‪V3 PCDs aftermath with Straight Piped Greddy EVO2 Exhaust on 07 Accord V6‬‏
Inside car: Low rpm drive
YouTube - ‪In Car V3 PCDs Aftermath with GReddy EVO2 on Accord V6 low rpm drive‬‏
Inside car: Full Throttle drive
YouTube - ‪V3 PCDs Aftermath with GReddy EVO2 Exhaust in an Accord V6 Full throttle in car‬‏
These videos reflect the sound of having V3 PCDs with the V1 Jpipe and Straight piped 2.5 Inch mid pipe to Greddy EVO2 Exhaust. I do plan on getting a magnaflow resonator #10426 installed. So stay tuned til it come in the mail and I have it install with videos to come.
After with PCDs, Jpipe, Magnaflow Resonator #10426, and GReddy EVO2 Exhaust = problem solved, little to no rasp at all.
Outside Car Idle, revs, and Rev Limiter:
http://www.youtube.com/watch?v=eQ7_Y1WKWfg
Edit/Update June 8th 2011
Accord V6 vs. Civic Si Four Door
We both have Injen CAI, Header me(PCDS, P2R TB Spacer, Pulleys, and Greddy Exhaust.
http://www.youtube.com/watch?v=rnjZ7o4fjxg
Best I can do for outside driveby. lol
C&Cs welcomed...
Enjoy! -D.Ho
C&Cs welcomed...
Enjoy! -D.Ho
justnspace (06-15-2011)
#45
BANNED
didn't someone recommend the magnaflow#10426 about 42336438 times earlier?
hopefully these guys will listen to the man himself. thx for setting all of this straight richie.
#46
Just got my 18" magnaflow resonator installed today and i am EXTREMELY disappointed..although i took it to a local muffler shop and install was only 20$ it made no difference at all in any sound and was a complete waste of 100$ total that was spent i will post a video ASAP at this point im not quite sure what to do and am just looking to get rid of the rasp that occurs around 4,5k..
#47
2007 TL Type-S NBP
On a serious note, what is your exact exhaust configuration? I highly recommend adding all your mods to your signature so that people can give more accurate advice when you need it, or so that when people see what you've got on your car they can ask you questions. I've got the RV6 V3 PCD's and j-pipe on my 2007 Type-S with a completely stock exhaust and only have some rasp in the 3-4k rpm range. I was going to go to the exhaust shop today for the exact same 18" Magnaflow but I may hold off until I hear more from you.
#48
My bad im not too familar with this site and still dont even know how to make a signature but as for my mods i have Rv6 Jpipe, Rv6 Pre cat deletes and just a short ram intake...also when it was installed the stock resonater was removed and replaced with the magnaflow..so was i supposed to add the magnaflow in with the stock one im confused?
#49
its always been a trial and error process.
as both of you found out, no one has the exact setup. This is why its so hard to recommend exhaust over the internet. Both of you had questions that only the individual can answer, as each person has different levels of liking.
Tmarks: you were not supposed to remove the mid-muffler. I stressed this in the beginning. DO NOT REMOVE THE MID-MUFFLER.
Now, since you only have one resonator installed...you have two choices: A) put the mid muffler back on and have the magnaflow resonator right after.
B) buy another 18 inch magnaflow and install that. so now you would have 2.
#50
You must be confused, NOOB. You've installed an 18" Magnaflow, which more senior acurazine members have laughed you to scorn for even questioning its effectiveness. Hence, your rasp is gone, you're just hearing things. This is why it annoys me when people are so quick to start bashing new people for asking a question about a specific configuration. What works with one setup may fall flat on a different one.
He did it wrong. I did stress not to remove the Mid-muffler. which he did.
My next advice asked him to add two 18inch resonators.
he didnt follow the advice and the results showed.
#52
UA6mt NBP
yea he did stress not to remove the mid muffler but since you mad that mistake which i did as well i now have a 14'' magnaflow res and the stock one ran right after it with no mid muffler and it sounds a little better than stock with absolutely no rasp which you are looking for so take his advice again and add another res and you will be fine
#53
Is there any other options? ya i screwed up and it really is getting to me cuz my car just sounds like crap and i put 100 into it..so at this point can i just add the stock one in after the magnaflow?
#59
UA6mt NBP
ok look the mid-muffler......KEEP IT OFF, just go back to the muffler shop and say hey i want to keep the magnaflow resonator on but can you put my stock resonator back on but right behind the magnaflow one, i have too much rasp and want to quiet it down. this will take care of your problem....again i just did this and it works so now you do the same and it will work
#60
2007 TL Type-S NBP
Just to make sure you have all your terms right, after the 3rd cat there is an 18" long by 4" diameter round "resonator" which then leads to a small "mid-muffler" right after the pipe bends roughly 45 degrees towards the passenger side. After the mid-muffler the pipe splits and goes to the two main mufflers. You'll definitely want to have your original resonator AND your Magnaflow both installed, the order doesn't matter. Also, to add things to your signature, just click "Settings" near the top left of your screen and then click "edit signature" on the left column.
#61
Just got back from the muffler shop and they installed the stock resonater just after the magnaflow one and it sounds great, zero rasp..Thanks for the help guys, now im just looking to make my car a little louder just cuz its more quieter now but it sounds deep which is what i wanted
#65
2006 6spd
was driving around for about 30mn then cel turned on but was driving kinda wild think if i reset it it will come back?... & do you think it was from crazy driving because if it was a messed up 02 sensor it sould of happened when i first started my car right? can anyone help ... thanks for everyones help
__________________
__________________
Joseph Stansbury
34
12-04-2015 01:57 PM
IIDXholic
10-08-2015 07:53 AM
Skirmich
09-15-2015 06:41 PM
