Acura TL 2004 MT dyno result.
Hi, my mods:
- Full exhaust
- Custom J pipe
- PCD
- No third cat
- AEM CAI
Did 236 whp / 215 wftlb SAE at 88 °F and 5100 ft of elevation, the car has 82 000 miles, was a dynojet. I don't know if this number is good, I was expecting 250 but I'm pleased with the result. Now my plan is to get the intake manifold/runners/TB ported and polished, maybe the lightweight pulleys and that's it, the ECU and the tune are way expensive and I doubt it worth the expense...
I forgot to add, the other time I went to another shop, they have a Dynocom and my car with the exact same mods did 217 wph, it was depressing, but after reading a lot of threads it seems that Dynojet is one of the best options, only a few people had used Dynocom. Also some people say that the shop I went, tune the dyno to give lower numbers so they can tune the cars and adjust the dyno to get more impressive results on the after run, I don't know what to believe on that regard.
yep, I have three pedals in my TL. 2006 6MT!!!!
thats the funny thing with dyno results. you're not supposed to put weight on the numbers, rather it's a tool to help you see if your incremental mods helped or not. BECAUSE!!! they can be manipulated as there are TONS of different variables that come into play.
the proper way to figure out how fast you are is to run the quarter mile. Trap speed indicates how fast you are.
The issue with 1/4 mile here is the elevation, we are at 5200 ft and my best time was 15.3 which is a very high time, I have seen here low 14s or even 13s high with slicks. And the track doesn't grab the trap speed, only ET and reaction time. I need to wait to go to the track at sea level to know how fast can go. What is your 1/4 mile time and trap speed? since we are relatively close on whp the numbers must be close as well.
lol i never been to the track with my TL.
the ONE time I DID GO, I couldnt participate because I was wearing shorts....stupid track rules...
but my car isnt set up for the track any more.... I havent bought summer tires in a long time, and I slip and slide with these stupid all seasons I have now...
So, I guess my priorities have changed since I bought the car.
in 2010-2014, I was ALL ABOUT the go fast!
but i guess money got in the way, or the lack of money...lol and now I just want the car to be maintained and thats it. I havent modded it in a long long long time!
I see!, if you go to the track post the times, would be a good reference ; I'll go next week to see how it does, I did 15.3 with the clutch also slipping in high gears/revs and I didn't have any mods, so.. I hop to get in the 14s.
I bought the Luk Excedy clutch and it is really good, I felt immediately how it pull harder on high gears. Didn't know that XLR8 also have a street clutch! I gues we reach a point where the mods gets very expensive and we can be happy with our cars, there are not FAST but somewhat quick and fun to drive. My goal is to get a 370z next year!
here's a 06 6MT who broke the 104MPH trap speed "barrier"
https://acurazine.com/forums/racing-...arrier-944686/
Barrier in quotes because we couldnt ever go past 103-104
Wow! a TL on the 13 consistently, very impressive! That motivates me to buy the type s ECU and buy the Hondata! shifting at 7300 does a very good change, also would like to play with the vtec engagement point, the type s does at 5000 right, ours at 4800, should make a difference or maybe engange it before, at 4000...
All the week I drive like an old man, easy with the shifts at 2500 most of the time, really relaxed, but the thing is, every Wednesday is track day... I understand, having a MT with ~2XX~ to the wheels is tempting! I would also like to do a compression test to see how I messed up with the wear after the abuse I have given to it
Those numbers aren't bad.
I made 230whp/215 torque in my av6 6 speed accord. This was all stock, hood closed and alot of variables against me.
With your mods, I would hope to be in the range of 245whp.
i think the goal of shifting vtec is to create a straight torque curve.
Acura did the type-s right with a vtec engagement of 5k as to straighten the torque curve as much as possible.
if you lower, i dont think you'll gain, you'll LOSE.
read up on the hondata threads
On the VTEC Engagement point I think you are right, a fried of mine used a button to force the VTEC to kick in when he press it, turns out that under 4500 rpm the engine was very sluggish with the VTEC, this was a F23 engine, but it must have the same behavior with ours. What I would like to do is play between 4500 and 5000 to find the best spot for the mods I have, I mean, this would be empiric doing test and fail over and over.
What was the temp when you dyno'd? The screen didn't show if that was SAE or STD. That can make a difference. The TL is VERY sensitive to heat and timing will be reduced. My 6MT dyno'd 240 whp stock, but it was good conditions, and I was able to ensure there was no knock or knock retard at all. If you don't have or get a Hondata, even a simple bluetooth datalogger can pick up knock and you'll know if you are pulling timing. Where are you located? I could tell the dyno wasn't in English so I wasn't sure if you are in the states or not. I was thinking Denver at first because of the elevation..
Hi! The temp of the air was between 88~90 °F and it was using SAE, I'm not in the US, I'm in Jalisco, Mexico. I'll try another pull in December when the weather is colder
What kind of fuel can you get there? 91 or 93?
DerrickW (10-24-2016)
We got cheap 88 and the "premium" 91, however our fuel doesn't meet the requirements of the US, when I was near the border with Calexico, the US Fuel was way better than ours, lasted longer and the engine felt stronger, it's a shame we have this bad fuel.
Torco - it's legit, not like most "octane boosters".
Torco Accelerator - It's not just an octane booster
It even gives a chart - to bump 10 gallons from 91 to 96 octane, you'd need 16 ounces. A 32 ounce bottle is 22.75 on Amazon, so .71 per ounce. A little over 11 bucks to get to 96 octane. What is our fuel tanks, 14 gallons? You could probably add 16 ounces to a tank and be close to 94 octane.
Not the cheapest, but if you're trying to win a race or get a good dyno...
maharajamd
10-20-2016 04:10 PM
Super_chris23
09-02-2016 12:37 AM
teejnut
01-19-2016 05:27 PM
