Accidentally made my car better with zipties!
#41
the holy shift kit on your sti feels good.
i had a rotate full on build 05 sti and it shifted good.
i have to say my 05 evo mr shifts felt the best out of all the cars i've had (too many).
i test drove a tl and really was unhappy with the feeling of the manual, so i bought an auto. i bought an acura knowing i wouldn't get the mod bug.. so far i haven't -- so that's good. i sank a lot of money in my past evo and blown cobra![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
with an sti, i'm sure you know what i'm talking about -- i went through two motors!
#44
Former Sponsor
I guess I am failing to see where there is so much play in the system. Guess I need to try it.
But personally I like to stay just to one side of making my Acura like an STi or S2000. It is a NICE car. Making a shifter that feels like it should be in a racecar does not represent a big improvement for me. This is one of those things that could have annoying side effects in my experience.
#47
Full of water...
#48
Not to hijack the thread, but just a quick question..
Whats the benefit of a weighted shift knob??
Now, back on topic:
I have a CT short throw and hafta say, it doesn't feel all that bad...
Now, back on topic:
#50
Former Sponsor
A weighted knob provides more momentum through the shift throw. This makes the shift feel easier and smoother. Until, easy and smooth was regarded as a beneficial trail to have in a shifter. Apparently now a stiffer, more difficult throw is better. I am still trying to wrap my head around the benefit of this mod.
#53
The only annoying side effect one could maybe complain about is the clunking when you shift into gear, but its not very loud and I like it. Keep in mind I'm 23, and my favorite mod on my STi was the holy shift kit that made it feel like a rock, and as a side effect amplified the sound of first and second gears somewhat straight cut teeth lmao. Seriously try it. Worst case you don't like it then just cut the zip tie and go on your way. I'll right up a better DIY soon since the TL is getting garaged for the winter and I'm going to be doing some work on it.
#54
#56
OP, do you happen to know approximately what size washers you used for the shifter box bushings?
I don't feel like ordering the $25 RSX bushings from Corsport when I could just pick up a few washers at the hardware store. However I would like to have the washers in hand before I start disassembling my center console.
#57
#61
Former Sponsor
Newsflash....
I just swapped out my Corsport shifter bushings with new Hybrid Racing ones and WOAH what a difference. The shifter is tight, solid, and EASY to move. Pops into gear with the flick of the wrist with much less free play than with the corsport bushings. Yes, there is supposed to be SOME play in the system.
Putting tension on the shifter cables is NOT a good idea. The cables slide inside the sheath and tugging on them causes increased pressure resulting in friction and eventually wear.
#62
Former Sponsor
Check this out:
The Hybrid Racing parts we tested worked amazingly.
New Shifter Cable Bushings…Out With Solid Aluminum, In With Hybrid Racing! HeelToeAuto.com's Pit Board
Again, I would strongly recommend against putting any kind of load on shifter cables at all.
#63
Check this out:
That spherical bushing is a pretty neat idea I must say...kind of tempted to try it out, but I'm pretty happy with the way mine work so I might just skip this.
#64
#68
I'm planning on taking out the center console sometime this week for the mandatory shifter upgrades for a 6MT
![Bite Lip](https://acurazine.com/forums/images/smilies/bitelip.gif)
