6 speed calipers
6 speed calipers
ok does anyone know if the 05 tl 6 speed calipers will fit a 05 tl auto will it bolt up to the stock mounting im thinking of doing that but dont want to buy them if they wont fit let me know if anyone has info thanks
Don't have the answer you are looking for, but you could see if the disk is the same diameter for both types. Also, since you are adding more pistons, I would imagine that the master cylinder is bigger for the Brembos. A call to the parts dept to check the part numbers for both will answer that. Everything else being equal, you will still need to get the caliper bracket as well, which attaches to the spindle.
For the money, you would do better getting an aftermarket performance brake kit with cross drilled rotors. That would even be a step up from the Brembos.
Specs right from the Acura website
http://www.acura.com/models/model_sp....asp?module=tl
Front Discs
Automatic: Ventilated, 11.8 in. (300 mm) diameter; 1.1 in. (28 mm) rotor thickness
Manual: Brembo® ventilated, 12.2 in. (310 mm) diameter, 0.98 in. (25 mm) rotor thickness
Front Discs
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
Sep 25, 2015 06:14 PM
