5AT shift faster
Old Jun 22, 2014 | 11:17 PM
vinny g's Avatar
8th Gear
5AT shift faster
I've been looking around and can't seem to find anything. The 5AT transmission has paddles as we all know, but they aren't immediate shifts, there is a delay. Is there any way to get a quicker response in the shift? I mean less delay. Many other cars shift on the click of the paddles (I'm aware there are dual clutch transmission like in the GTR's). Can we tune our transmissions, tune the car, anything to make it more of an immediate shift? Thank you in advance.
Old Jun 22, 2014 | 11:33 PM
1black_seven's Avatar
Slot Machine Lubricator
You can try the Redline Type-F/D4 mixture.
Old Jun 22, 2014 | 11:52 PM
atornillele's Avatar
5th Gear
Yeah, find a 6 speed manual
Old Jun 22, 2014 | 11:59 PM
anx1300c's Avatar
Unfortunately, Honda's older 5 spd automatics are not very performance oriented. I think their new 6AT is a little more efficient.
Old Jun 23, 2014 | 03:27 AM
paperboy42190's Avatar
I think you guys are missing the OP's point. He's not complaining about the actual shift time, he's complaining about the shift DELAY, which is the time from when you press the paddle shifter to when the shift begins. I have noticed the delay is slightly less when going WOT. Although even so it's still considered a bit laggy compared to some other cars.
The 2-3 shift during normal driving seems to be the laggiest.
Although after driving the car for awhile, you do get used to it. I have learned to anticipate the lag and press the throttle accordingly.
For example, when slowing down to and downshifting to 1st gear, always wait until the shift is complete before pressing the throttle otherwise it'll cause an uncomfortable jerk.
Old Jun 23, 2014 | 12:55 PM
vinny g's Avatar
8th Gear
Thank you paperboy. I love driving 6 speed manual, but hour+ commutes each way to work everyday made me get the auto. I'm getting used to having a slower car and I guess the whole auto thing is messing with me from "banging gears."
Old Jun 23, 2014 | 09:29 PM
rubenders's Avatar
performace tl-s
If you get use to your transmission you will make the delay less noticeable On my some people think I have a 6 speed but I don't redline is at 7k rpm and I shift at 6500 by the time it get to 68,6900 rpm it go to the next gear.
Old Jun 23, 2014 | 09:52 PM
rubenders's Avatar
performace tl-s
Little video low quality http://youtu.be/MHYFnI75Qzo
Old Jun 24, 2014 | 02:25 PM
Corey_Straker's Avatar
The delay is in the system and computing. As another member said, the 5at in any of these are not very performance oriented. If you check out my notes on the TLX from training in TX you'll note that this was a focus point on the design team and they improved it by 30%. Different fluid should help, other than that... You are literally SOL. Deal with or 6mt swap.
Old Jun 24, 2014 | 02:30 PM
holy crap was that video taken with a potato?
Old Jun 24, 2014 | 02:31 PM
More like a stick.
Old Jun 24, 2014 | 03:05 PM
bakers13's Avatar
is there a way to get two step in the 5at trans ?
Old Jun 24, 2014 | 03:09 PM
maybe with hondata but Im not sure
Old Jun 24, 2014 | 03:10 PM
^no.
Old Jun 24, 2014 | 11:26 PM
^I stand corrected. I just assumed it did because on the 8th gen civic SI's, hondata gives that feature
Old Jun 25, 2014 | 07:00 AM
2 step on a 5at...? Get a manual for that, everyone knows the 5at isn't performance. Plus how would that work? You can already torque hold it but you'll go through a tq converter, axles, and motor mounts like it's your job.
Old Jun 27, 2014 | 11:33 AM
vinny g's Avatar
8th Gear
The only way to achieve any type of "2 step" on an automatic is by either putting in a higher stall converter, or a trans brake. Thats the only way autos can do that stuff. Or you buy an automatic supercar like an Aventador or something.
Old Jun 27, 2014 | 11:38 AM
vinny g's Avatar
8th Gear
Anyone know what kind of power the 5AT can hold stock?
Old Jun 27, 2014 | 01:47 PM
pohljm's Avatar
350
Old Jun 28, 2014 | 04:29 PM
spade0698's Avatar
Originally Posted by pohljm
350
403....been there done that.
Old Jun 28, 2014 | 05:15 PM
Slpr04UA6's Avatar
-------Tim-------
^what's up man? Anything new going on with your car?
OP-Sorry off topic
Old Jun 29, 2014 | 01:02 PM
Scottwax's Avatar
Mr. Detail
Probably take valve body modifications to get around whatever delay the computer is set up for. When I had my 5AT rebuilt, they did go through the valve body to get around the sloppy stock shift parameters. So far, so good, shifts are quicker, firmer and consistent from gear to gear, 2-3 upshift is vastly improved. Haven't manually shifted it yet though, figured I'd wait until I have more than 500 miles on it before doing so.
Old Jun 29, 2014 | 05:07 PM
pohljm's Avatar
ok 402
Old Jun 30, 2014 | 08:34 AM
flexer's Avatar
So they actually modified something with the stock valve body? Do you know what they did?
IHC, what would you do to a valve body to get it to shift faster?
Old Jul 3, 2014 | 03:09 PM
Scottwax's Avatar
Mr. Detail
Don't know exactly what they did, probably similar to what a shift kit does in a domestic transmission. I put a couple shift kits in, one in my Chevelle, the other in my Cutlass. It changes the way the ATF flows through the valve body, the kit changed the separator plate, gasket, drilled one hole larger (dual purpose kit) and removed 3 of the 4 check balls. I think it changed a couple springs too. Shifts were much faster and harder, half throttle 1-2 up shifts would chirp the tires.
What was done to mine isn't that extreme but the goal is to reduce overlap on shifts and increase line pressure. Shifts quick and firm, but not tire chirping bang shifts-not really something you want in a FWD car anyway, would end up eating up transmission mounts.
Old Jul 17, 2014 | 05:11 PM
vinny g's Avatar
8th Gear
I guess I will learn to live with it. Time to go low and give up on making this car "fast"
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
Popee
Dec 20, 2015 12:08 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
