4TH Gen SH-AWD Intake Manifold & Throttle Body on 3RD Gen
94 DC4 RS LSV/Turbo
NOTE: This is for 07-08 Only
This is for all of you who wanted a ported intake mani, it is not required...
INTAKE MANIFOLD UPGRADE
Werd on the streets is the 4th gen TL Intake Mani (Part #17160-RK2-A00) Flows better than the 3rd gen
best part is the intake manifold cover which is the most expensive part does not need to be purchased... What I mean is you just need to purchase the manifold alone which is at a total of $269.04 (list price pretty sure its cheaper), the 07-08 cover is fine .... as some of you know the cover has a sensor on it, this damn sensor is $500 on the 07-08...
I would discuss the throttle body but no need since it is $500 ... and these are upgrades on a budget
ps. This is for you guys with ported intake runners and big bore throttle bodies
lastly yes these factory budget upgrades will continue as this is what I've been doing with my free time (kinda makes you wonder what the hell am I doing)
First off, don't jump the gun yet, this is not complete bolt-on. I will give you more info later.
Second, not sure where you get your prices from but they are absurdly expensive. I paid $201 for the 4G TL intake manifold and less than $500 for the TB. Run your part numbers through these guys, they don't have 09s listed yet, but they can get you the part #s, I've dealt with them a lot and they are awesome: http://oemacuraparts.com/
94 DC4 RS LSV/Turbo
I'm aware... P2R can make the adapter for $70... Infact they already have one for the 2nd gen tl guys, since that is the motor I'll be swapping into my teg
Its not a big modification at all
Not at all... just making sure people were aware they would need an adapter. This manifold has a lot of benefits...
-Inlet is enormous, I had my throttle body bored and it was still undersized compared to the opening
-Lower ports are gasket matched, no extra material
-Inside looks very smooth, little to no castings
-Magnesium alloy material makes it very light
For under $200 I would think this is a better upgrade than sending out your stock manifold to get ported. I'm not sure if you answered this, but you are sure the 3G plenum cover will bolt to this?
94 DC4 RS LSV/Turbo
the reason I saw the manifold lid bolts up is because the gaskets are the same... which means the bolts are in the same location
besides it appears the 07/08 is different from the 09 so I don't think it will bolt up
so for the 07/08 guys they should just use it...
I must give credit to cleancl... his thread on the 4g section gave me the idea
CL-SEXY SIX (=
4 Gen TL INTAKE manifold onto a 3rd GEN?
http://images.google.com/imgres?imgu...a%3DG%26um%3D1
I wonder what the gains would be; if any?? None of the acura deals online are stocking these yet i guess; but looks like a cool/great mod.
I have car ADD
The bore is larger on the 09 TL SH-AWD manifold, as is the Throttle body..... if you got the intake manifold and TB, you would probably get some intereting gains.. i would imagine close to 10whp
i believe the TB on the 3G is 64mm, where as the TB on the 4G-AWD is 69mm ...
You're right, looks like the 07-08 TL models used the magnesium composite, both type s and base.
04-06 makes no mention of magnesium.
Looks to me like the 4G AWD throttle body will not work. First picture is my throttle body, second picture is 3G TL TB.
The manifold would bolt to the runners no problem, but there are 2 questions:
-Does the top plate bolt up?
-Can P2R make a throttle body adapter for the 3G TL like they did for the 2G CL/TL?
It could fit, the additional jack you see on the new throttle body is probably the sensor that is on the top of the plastic on the 3G, coolant lines are still there (though we disconnect them with CAI install) and there's a 6 pin plug for the body itself. The TB should be able to bolt on properly, if it doesn't we can always have P2R make an adapter.
94 DC4 RS LSV/Turbo
Fyi. I already made this very topic, search next time
Furthermore, see the 2nd gen tl side for a pleasant surprise, they've really got this manifold up and running hard
I think that the gains would come from bolting the t/b and the plenum on together. Inlet bore will be almost 76mm. I am trying this today so Ill let you know what happens. Test subject is my 2008 Type S and the "donor" is a 2009 Shawd Tl.
94 DC4 RS LSV/Turbo
OK so saturday I was over by RacingHart03 and we got to talking about this very mod... there is another thread on here about this very mod... I am going to pm one of the mods to have them joined together
sooo don't know if some of you have seen cleancl's bored 4th gen tb...
Now... racinghart03 confirms that the 4th gen sh-awd intake mani fits the 3rd gen tl... but he has also taken it further by also confirming that the 4th gen sh-awd throttle sensor is a plug and play with the third gen... here are some of his pictures...
SH-AWD Stock Size
TL-S Stock Size
Side By Side
SH-AWD Stock Size
TL-S Stock Size
Side By Side
There is a pretty dramatic taper inside the bore so its hard to measure but the side by side says it all. This thing is HUGE lol. I am curious to see if I throw any codes for map issues or tp issues. I havent thus far with the big bore but this is a whole diff. story. I am gonna drive with the set up for a few days and see what happens. Its not gonna be a cheap mod as the required parts are about 700 bucks!
I can only verify that the DBW connector is the same on 08 Type S. I havent gone that far into yet. All the signal and control wiring is the same. Only diff. I found so far is that the 09 uses the PCM to control the T/B and the 08 uses a independent control unit. In a few hours I will have this whole thing answered!
Ryan Christopher
08 type-s
04-06 3.2L
I am really wanting to try this mod as well. I cost it out to be about $700 for an 04-06 TL. Still not 100% if it will work. This is not counting the Throttle body. I was hoping P2R would make an adapter like they did for the 2nd gens.
09 SH AWD
I agree. For me with a 08 type S its still gonna cost ME about 6ish. I am just curious to see how my car feels once I put the stuff on. If it doesnt blow my mind.. I am just gonna put my big bore back on and call it a day.
