I know that headers aren't available for the 3rd generation TLs.
...I was hoping someone could essentially explain why not? From what I can understand, it has something to do with the fact that...something's welded on to the block, as apposed to being bolted on?
Is there some sort of replacement for headers? I'm not talking exhaust, or any other sort of mods, but something that we could use to REPLACE the uh...inability to have headers? Get my question?
Thanks,
Eric
Thanks,
Eric
08 TL-S NBP
NO replacement or anything, the best you can do is precat deletes.
The headers for forged into the engine block, so its all one piece. There won't even be a way to change just the headers, it sucks but we have to live with it.
CTS-V Import Slayer
RV6 Precat delete pipes for the win.
Yes...the exhaust manifolds on this model car are cast right into the heads and catalytic converters are bolted directly to these ports...therefore they cant be removed to install the traditional "header pipes" - so necessity invented replacement pipes to delete the cats out of the system partially or entirely....depending on your taste.
2009 g37s 6mt
Rv6 pcd ftw, 2 bad we dont have headers, but are close to it thanks to richie....
94 DC4 RS LSV/Turbo
richie might make a pair of hiflowing cats
and he's been talking about a race header for a real long time
which would consist of 2 full pieces very much like the prototype piece on the thunderhill tl
front 4 bolt flange down all the way to the collector no seperation, and rear being the same precat... essentially eliminating 1 flange at the front cat and 2 flanges at the 3rd cat
Hi,
don't know much about it but anyone has the link or pix for those RV6? I thought about removing all 3 cats cause i have the engine lights on and it's annoying. + perhaps can gain a bit of Horse power.
thanks
thanks
Green Machine
Quote:
Still got mine...not giving them up any time soon.Originally Posted by mrlunecy
procats still around or are they now collector's items?
pohljm
close
- Join DateSep 2006
- LocationSan Diego, CA
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:596 Times in 459 Posts
Quote:
still running mine 30K with no problems at allOriginally Posted by mrlunecy
CTS-V Import Slayer
Huh...I will have to video my ProCats....they are briquettes at this point. You guys DO know they are not ULEV rated cats dont you so they will not last the duration....especially if supercharged. You will likely never know they are baked until you remove them BTW.....
Former Sponsor
Quote:
I thought you were running precat deletes? Any chance I could borrow and see how they get around the intermediate shaft. Originally Posted by MichaelBenz
Former Sponsor
thanks
They come with mechanical O2 simulators so you are all set.Originally Posted by kaolombo
Hi,don't know much about it but anyone has the link or pix for those RV6? I thought about removing all 3 cats cause i have the engine lights on and it's annoying. + perhaps can gain a bit of Horse power.
thanks
zaino'd
Quote:
Quote:
Take them out and look inside Originally Posted by pohljm
CTS-V Import Slayer
Quote:
I am running the precat deletes now. The ProCats are sitting on my garage floor right now. They rattle inside....like whats in em is one solid mass now! Kinda like a briquette! Its funny....I was suprised when I took em off that they didnt cause me issues before then!Originally Posted by Richie v6
As for borrowing them....dude.....you know you can stop by anytime. I will let you borrow em for a while....no prob! Its all good here! Just give me a rip when you are in town and you can come by or we can meet somewhere. I should be hosting some local meets soon for a local forum in Indy...so maybe you would want to hit that up in case I am an axe murderer or just plain fucking strange!
Then you could easily escape! lol Seriously...its cool...no prob! Just hit me up.v 4910shp/19,600ft-lb v
Quote:
Got'em too! Still going strong (knock on wood), I visually checked them when I replaced my OEM A-pipe with an ATLP one. It's been about 20,000 miles since installing them.Originally Posted by t0talacuratl
I still maintain that either CAIs or excessive time past VTEC is burning them up...
I have car ADD
^ the charger does burn them up... but i was N/A on my blackura, and 2 out of 3 of mine kept having problems.... the only one that was fine was the 3rd pro-cat
2009 g37s 6mt
Quote:
i had my cats on the charger for 5k, they look fine, but im glad i swapped em because my car hauls ass even more now....Originally Posted by blackura_ny
^ the charger does burn them up... But i was n/a on my blackura, and 2 out of 3 of mine kept having problems.... The only one that was fine was the 3rd pro-cat
I hate cars
close
- Join DateMar 2006
- LocationBakersfield
Liked:1,818 Times in 1,287 Posts
It's the ULEV status that burns them up. During warmup, the computer dumps extra fuel, retards timing, and commands intentional misfires to fire off the cats quicker. A normal cat like the Procats will not hold up to this extra heat. You're making more heat during the warm up cycle than you're making with the blower. Only difference is they get an extra pounding after the warm up cycle with the blower.Originally Posted by kjelly
Got'em too! Still going strong (knock on wood), I visually checked them when I replaced my OEM A-pipe with an ATLP one. It's been about 20,000 miles since installing them.I still maintain that either CAIs or excessive time past VTEC is burning them up...
94 DC4 RS LSV/Turbo
you guys think magnaflow spun cats can holdup?
I have car ADD
Quote:
they were hi-flowing cats made by a company called e-shift... they were pricey (i believe i paid about $1100 for them) and a lot of them failedOriginally Posted by TL|GTX
What are pro-cats? Are they like pre-cats?
I have car ADD
Quote:
couldnt have said it better myself... the substrates in the pro-cats werent designed to be that close to the engine block.. when the car first fires up, its in "closed loop?" i believe, which dumps an abnormal amount of fuel in.... thats why, us folks who are catless (full or partially) can REALLY smell the fumes when the car is warming up... i know my car smells like a 70 chevelle LS6 454 engine when i turn it onOriginally Posted by I hate cars
312 HP 271 TQ Dynapack
Quote:
YUP! When I pulled the third cat to install the race pipe, I found little fragments of metal from the precats...not a whole lot, though. jusr enough to make me go Originally Posted by MichaelBenz
. Third cat looks great though. This was after approx 15k mile with the blower. Quote:
Half way through reading this, I was thinking, "Man...this guy knows his shit." ...he sounds like...I Hate Cars...Originally Posted by I hate cars
Always on top of it!Quote:
I know what you mean, Allon. Smells beautiful don't it?...better than coffee. and I still got my precats in!Originally Posted by BLACKURA_NY
Quote:
small clarification:Originally Posted by BLACKURA_NY
Open loop - the ecu IS NOT taking into account the information from oxygen sensors and other sources of feedback. The ecu is instead using a fixed (programmed) set of tables to determine air/fuel ratios. This is what you were referring to. The ecu is most commonly in open loop for warm up and at WOT.
Closed loop - the ecu IS taking into account the information from oxygen and other sensors to change the air/fuel ratios to improve efficiency and decrease emmisions. The ecu is most commonly in closed loop during normal driving after the engine has warmed up.
Former Sponsor
LOL I can't believe I didn't see this post. I was going to stop by the last time I was in Indy but ran out of time. I dont know now............... Originally Posted by MichaelBenz
I am running the precat deletes now. The ProCats are sitting on my garage floor right now. They rattle inside....like whats in em is one solid mass now! Kinda like a briquette! Its funny....I was suprised when I took em off that they didnt cause me issues before then!As for borrowing them....dude.....you know you can stop by anytime. I will let you borrow em for a while....no prob! Its all good here! Just give me a rip when you are in town and you can come by or we can meet somewhere. I should be hosting some local meets soon for a local forum in Indy...so maybe you would want to hit that up in case I am an axe murderer or just plain fucking strange!
CTS-V Import Slayer
Quote:
I was wondering what happened to you! Originally Posted by Richie v6
Quote:
ugh...so THAT's why it smells worse on intial start ups. The system's dumping fuel in eh? Is that why we have that "grinding" noise on initial start ups to? It's faint, but definitely there...only noticed it after the precats were installed.Originally Posted by BLACKURA_NY
That da*# smell's nauseating...
is that partially why it takes so long for the system to recognize that the cats are missing? my cel code read - cats under threshold?Originally Posted by chase p
small clarification:Open loop - the ecu IS NOT taking into account the information from oxygen sensors and other sources of feedback. The ecu is instead using a fixed (programmed) set of tables to determine air/fuel ratios. This is what you were referring to. The ecu is most commonly in open loop for warm up and at WOT.
Quote:
Yes. The ecu runs in open loop mode while the catalytic converters and engine heat up. Once the engine reaches a certain temperature, the ecu will start checking Oxygen sensors and if a catalytic converter is not functioning properly (or has been removed), the ecu will then display a code. It should then switch back to closed loop mode.Originally Posted by erick3
