2010 Acura TL throttle body!!
Guys did anyone do this mod? Is ot worth it? Also when i put this on the p2r adaptor must be put on as well of im not mistaken? Do i need anything else with that done?
If you're talking about the 3.7 TB, then yes, it has been done, but you need to either port your stock manifold/runners or better yet, port your runners and also install the 3.7 manifold. Just adding the larger TB on its own won't do anything substantial.
Yes.
All motor
Comparison between stock PORTED manifold and 3.7 manifold/TB/polished runners. This is on a 3.0 Accord 6MT. 3.2 TL 6MTs should gain more.
![](http://i32.photobucket.com/albums/d45/Sonnick/270whpDynoshrunk.jpg)
If you're gonna take the plunge for the throttle body, get the manifold. You'll gain a couple horses, but no where near what you will with the manifold as well. Another option below (take out the red X's)
http://www.vx6xperformance.net/forums/7g-performance-discussion/215853-dual-throttle-bodies-dbw.html#post2007912
hondazex (08-20-2012)
All motor
^ If you want the throttle body, PM me for a better price.
Once my mounts are installed and it gets cooler I will be hitting the track. Most likely Oct/Nov. I'm gonna try to go a few times before they close.
All motor
^ Would love some slicks and 16" wheels, but it's a lot to spend for ~10 passes a year.
The 3.7 manifold WILL fit the 3.2, yes. It fight my 3.0 as a direct bolt on, and I mean direct. The only thing that is different is the map sensor connector, and the fact that you need to relocate your IAT sensor. Otherwise everything bolts up and it's a very worthwhile swap. I gained 10-15whp from 6K to redline and I'm still on a small intake. I'm assuming another 5whp gain from a 3.5" CAI.
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
