2 Piston Caliper Rear Brakes
looked all around the posts and could not find anything related to this topic.
I have a 04 Manual with the Brembo brakes and a curious idea flitted across my mind
When I was changing my pads I was thinking what if we had a 2 Piston Caliper brake in the rear?
As a preliminary thought I was thinking take the normal Auto TL front brake set and put it in the back
I googled the 2 piston idea and really did not find anything but I have to imagine someone has done it or at least thought about it.
I have a feeling it would not really be helpful for a daily driver but it sounds like a cool idea.
My concerns are:
Would it just screw up braking in general?
Would it cause the car to fish tail or possibly hop?
Looking for a challenge but don’t want to waste my time if it truly is worthless
I have a 04 Manual with no modifications.
My concerns are:
I've had the thought long time ago, but invested my money on going fast, rather than rear brakes... Honesly, our front brakes do about 70% of breaking...especially being that its front heavy, it wouldn't screw anything up.. But I would say that on a very stiff suspension and lowered TL where weight shift and nose diving when breaking are reduced by a lot..having better rear brakes wouldn't hurt...however in my experience..I've been slammed for a long time..ever since tein ss coilovers were made, in almost 6 years, I've changed my rear pads only 1 time.. I do however love the cool look of big brakes..but I didn't wanna spend $$$ just so it looks cool...
For some reason I think the Evo rear calipers would fit...(Its a brembo 2 piston caliper) They have the same front brembo caliper as the TL.. So that's something to consider.
I personally hate the cast brake calipers..they look crappy, cheap, and just simply suck.
Our cars have electronic brake distribution force, at least the 6 speed manual, pretty much each wheel gets as much clamping pressure as it needs regulated electronically.. If if one wheel starts slipping due to lock up, or for instance braking on a turn, the inside wheel has the least amount of grip as the weight shifts to the outside wheel..so that would lock up first, so the EBDF would ease the pressure on that caliper..
If uve ever noticed...when ur breaking at low speeds coming to a stop and at the same time you downshift..the assistance from engine braking sets off the system resulting in released pressure to front calipers or whichever wheel has the best grip, and you feel ur brake pedal being pushed back (that's not abs, abs pulsates)
Track cars have more direct braking... Some even disable ABS!
Track cars have more direct braking... Some even disable ABS! Can't compare our cars with track cars
The Cast brake calipers do look pretty bland
I was actually going to paint my Acura Brembo front bracket to Red with (hopefully) gold Acura letters like the regular Brembo color schemes... want to do that just to change it up from other Acura Brembo setups
I was going to then paint my current rear calipers red as well so would also do that if I went with the 2 piston caliper
The more I think about the more it sounds nice but you are right in that it will not really help for street driving.. that and the $$$ will go up because I think I would have to get new rotors as well along with other small pieces that tally up into an acid reflux
oh well... I hope to change my rotors to either Rotora slotted or Brembo and then do the paint change as well... hopefully that will keep me happy for awhile
Good info on the electronic brake force distribution. I would always leave it on for real life street conditions where one wheel may have much more or less traction than the others. I guess this outweights the fact that the car won't stop as fast in perfect contitions with ABS.
I have car ADD
^ yea, bigger brakes dont neccesarily "mess" up your distribution.... there is a hydraulic system that keeps everything in check, and the EBD keeps everything stable
I am no auto-mechanic expert.... but TRUST me... everybody on this forum who's been around for a few years, knows that I KNOW about big brake kits, and the 3G TL ...... just search my first 3G (Blackura)
So I can mix Rotora and the Brembos? And it would be fine? I was looking for a replacement for the rear for a while. It just looks funny, especially if you decide to paint them later on.
You can't just mix and match brake parts. The EBD is only for panic at the limit stops. Anything less that that like normal daily driving, you have the possiblility of over working, overheating, and prematurely wearing out a set on brake pads on one axle.
This is one area I don't recommend the do it yourself way.
In a nutshell, if you want all 4 big brakes, get the Rotora kit. If you're only looking for the fronts, Brembo, Wilwood, or Rotora will work fine. This was one thing that I had to figure out before I ordered the Wilwoods. Is it worth the savings to never be able to add a BBK in the rear unless Wilwood comes out with them.
different calipers will work differently from one another......just cause its a 4 piston caliper doesnt mean much...brembo is one thing, and rotora is another... u shouldn't mix them....yes if u have brembos in the front...leave the rear alone.....ur mainly gonna spend the money on appearance.... TL with front brembos stoped from 60-0 in 120 ft...thats great for a fwd front heavy 3500 lbs sedan.... if u think ur gonna get a big noticable improvement from that by adding big calipers to the rear...u better think about some Wide tires, stiff suspension to prevent nose dive, while slammed to the ground...then youll gain about 5 ft stopping distance
but then, i could do that downshifting while breaking
