100 Octane Fuel
Old Jun 1, 2009 | 01:46 PM
tldrummer89's Avatar
100 Octane Fuel
I was wondering if filling up my Acura TL with 100 octane for the weekend would damage the motor or cause any unbalances in it? Just a thought
Old Jun 1, 2009 | 02:01 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Where do you get 100 octanE? At the airport?
Old Jun 1, 2009 | 02:07 PM
Trew's Avatar
Race fuel...
Improved combustion efficiency aka more power at higher RPM bands.
Old Jun 1, 2009 | 02:19 PM
TL|GTX's Avatar
A Black TL
it might do something to ur cats?
Old Jun 1, 2009 | 02:23 PM
ssmtl2nv's Avatar
2009 g37s 6mt
probably bake them.....
Old Jun 1, 2009 | 02:24 PM
Sal's Type S's Avatar
As long that it is UNLEADED. They sell leaded and unleaded race fuels.
Old Jun 1, 2009 | 02:48 PM
Majofo's Avatar
I wish I could get me some 100 Octane! I'd live in 1st & 2nd Gear.. lol.. probably run FI too!
you'll be fine.. keep your nose alert for your cat's..
Old Jun 1, 2009 | 02:49 PM
blkaspec's Avatar
Full of water...
The Sunoco near my place sells turbo blue race fuel, or something like that...
Old Jun 1, 2009 | 03:31 PM
Trew's Avatar
+1
If it's unleaded race fuel it will cause NO damage to the cats and O2 sensors.
Old Jun 1, 2009 | 03:52 PM
There's a local gas station in South Cali that offers 100 Octane Fuel for 8.99 a gallon the price is the only down side
Old Jun 1, 2009 | 03:53 PM
Originally Posted by Trew
Race fuel...
More power is always a plus
Old Jun 1, 2009 | 03:59 PM
Good tip, thanks. That's something ill look up today
I bet haha
Alright thanks!
+1
If it was leaded, how would that damage the cats? Is it because of the fumes it will emit?
Old Jun 1, 2009 | 04:05 PM
SatinSilverAV6's Avatar
2003 Accord Coupe V6
Here in tucson we have a sunoco station that sells 100 octane unleaded gas for 6.99 per gallon. Used to be 4.99 a gallon about a year ago! I fill up with a few gallons of 100 octane every once in a while to clean out my fuel system! Works like a champ. Just do it when your tank is close to empty so it takes full effect. I would see no need to waste your money on filling up your tank full with it. You can always mix 91 octane with it to average out your octane.
Old Jun 1, 2009 | 04:12 PM
If only we had those Sunoco gas stations here. I forgot the name of this one but 6.99 sounds awesome! compared too 8.99 a gallon. I had heard of this and that's why i became interested in it too I was just going too get about 3 gallons too see the difference and i guess clean out the fuel system a bit!
Old Jun 1, 2009 | 04:14 PM
I also read that you can make it 100+ octane by mixing it with methane that would be pushing it though haha
Old Jun 1, 2009 | 04:22 PM
Lazer187's Avatar
so 100 unleaded octane has no negetive effect on the car? Just the wallet? Cuz i have a gas station by me that has race full but i would have to check if its unleaded or leaded.
Old Jun 1, 2009 | 04:30 PM
sixsixfour's Avatar
I put 100 octane unleaded once in a while. has no adverse effects whatsoever other than more pain at the wallet.
Old Jun 1, 2009 | 04:52 PM
by the responses i've been receiving...yes
Old Jun 1, 2009 | 05:35 PM
Trew's Avatar
Leaded fuel will clog the monoliths inside the cat causing a restriction in flow and everything that comes with that.
Old Jun 1, 2009 | 05:40 PM
Tumbleweed13's Avatar
The only effect that you will notice is the lighter wallet. It does no good to get it. Don't waste the money.
Old Jun 1, 2009 | 06:34 PM
TL|GTX's Avatar
A Black TL
Yes it does, my cuzin noticed a faster 0-60 on his turbo ecplise when he put 100.
Old Jun 1, 2009 | 06:37 PM
Johnny_b's Avatar
I find it hard to believe that they would allow the sale of leaded fuel to the public, or anyone for that matter.
Old Jun 1, 2009 | 07:01 PM
NAiL05's Avatar
They have leaded fuel for sale at the track and you can buy them from distributors. But make sure its not leaded. It will clog of cats as mentionend and eat o2 sensors for breakfast.
Old Jun 1, 2009 | 07:15 PM
Bearcat94's Avatar
AZ Community Team
Higher Octane offers no performance benfit unless you have enough compression to need it. No extra HP. No extra mileage. Lots of extra money.
The only reason to use 100 Octane is if you have or suspect you have some knocking/pinging and are worried about the damage such a thing may cause if you run your car hard. In that case 1/2 91/93 Octane and 1/2 100 Octane will raise your tank to ~96 Octane which will combat or reduce pinging/knocking.
Octane is a measure of the resistance to ignite under pressure. Higher Octane = more resistant to ignition from compression (i.e. detonation).
Wiki/Google Octane.
Old Jun 1, 2009 | 07:21 PM
TLAdvanced's Avatar
The Kinetics of Bleu
Well, look into it then because they do. They have it at all race tracks and some gas stations.
Old Jun 1, 2009 | 07:42 PM
05BlkTL's Avatar
Yes, you can use Tuolene which is paint thinner and the main ingredient in octane boosters. You can buy it at any hardware store. Of course you have to get the right mixture. I saw this from a post made by 'I hate Cars' and he has the correct mixture i think, also this may be cheaper than 100 octane.
Old Jun 1, 2009 | 08:17 PM
Bearcat94's Avatar
AZ Community Team
I thought I Hate Cars used Xylene? Regardless, if you don't know what you're doing, adding hazardous chemicals to your fuel probably isn't the best idea.
Old Jun 1, 2009 | 08:41 PM
beachexotic03's Avatar
You will be fine! 100 is really good for cleaning extra carbon off the valves and piston tops. I see maybe a shorter plug life, because of heat range the sparkplugs has isn't made for 100 . But you will be fine.
Old Jun 1, 2009 | 08:57 PM
blkaspec's Avatar
Full of water...
i just checked and its leaded...so no go there
Old Jun 1, 2009 | 09:25 PM
NAiL05's Avatar
There are a few "ingredients" to making your brew. If you get it incorrect you can screw yourself over. I remember a pdf a while I saved back explaining what all the ingredients are and the ratios for like 116 or something I need to check.
Old Jun 1, 2009 | 10:07 PM
thcmagik's Avatar
ya there is a shell gas station on the berlin turnpike that sells 100 octane for 8.99 a gallon, never put in the tl but did put a couple of gallons in my bike
Old Jun 1, 2009 | 11:29 PM
05BlkTL's Avatar
You may be right, I thought it was tuolene but couldn't dig up the thread. anyway if the OP is truly interested maybe shoot him (I hate Cars) a PM about it.
Old Jun 2, 2009 | 12:17 AM
I hate cars's Avatar
Tolulene is an ingredient in fuel system cleaners and octane boosters. It runs about 118 octane. You don't want to mix it in more than a 20% mixture.
100 unleaded won't hurt a thing on your car. It may not give you any extra power either. The TL is an octane hungry car and mine pings on 91. You will pick up some power until you get past the pinging threshold and anything higher than that is a waste. For me it was around 96 octane.
Anything leaded will kill an 02 sensor in about one tankful and it will kill all 3 cats even quicker.
Old Jun 2, 2009 | 12:42 AM
greco9885's Avatar
we got about 15 gallons of 116 at my shop
Old Jun 2, 2009 | 08:50 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
I'm confused why, in our cars, we need higher Octane fuel anyways?
Originally Posted by carbib
Octane and power
It's a common misconception amongst car enthusiasts that higher octane = more power. This is simply not true. The myth arose because of sportier vehicles requiring higher octane fuels. Without understanding why, a certain section of the car subculture decided that this was because higher octane petrol meant higher power.
The reality of the situation is a little different. Power is limited by the maximum amount of fuel-air mixture that can be jammed into the combustion chamber. Because high performance engines operate with high compression ratios they are more likely to suffer from detonation and so to compensate, they need a higher octane fuel to control the burn. So yes, sports cars do need high octane fuel, but it's not because the octane rating is somehow giving more power. It's because it's required because the engine develops more power because of its design.
There is a direct correlation between the compression ratio of an engine and its fuel octane requirements. The following table is a rough guide to octane values per engine compression ratio for a carburettor engine without engine management. For modern fuel-injected cars with advanced engine management systems, these values are lowered by about 5 to 7 points.
Compression ratioOctane 5:1 72 6:1 81 7:1 87 8:1 92 9:1 96 10:1 100 11:1 104 12:1 108
In some extreme cases, the highest octane fuel available might not solve a knocking or detonation problem. That's normally a symptom of a deeper problem in the engine involving carbon deposits on the cylinder heads, bad spark timing, faulty engine management systems or similar. In these cases, some people choose to add octane booster to their petrol. Basically you fill the tank as normal, then put in a measured amount of octane booster and it further raises the octane level in an attempt to stop the detonation. One of the downsides of this is that it can make the engine harder to start from cold, because the octane booster has made the fuel so much less volatile that it's hard to get it to ignite on the first couple of strokes. Products like Klotz and Redex octane boosters are readily available over the counter in most auto parts stores. Octane boosters are typically used by mis-educated motorcyclists who believe the myth (explained above) that high octane = more power.
Octane boosters tested by Fifth Gear. To try to lay the myth about octane boosters giving more power to bed for once and for all, in 2007 the UK TV show Fifth Gear picked four likely candidates and subjected them to rigorous testing. They picked Nitro Hot Shot, NOS Race Only Octane Booster, Wynn's Power Booster and STP Power Booster. All four products make the usual wild claims about increased gas mileage, more bhp and so on and so forth. They took the products to Oxford Brooks University's engine testing lab. The engine was static-mounted so measurements were made at the flywheel. The throttle was computer controlled so they could reproduce the same scenario over and over again. They first did a baseline test to find out peak bhp with regular unleaded petrol. This involved various constant-throttle settings as well as acceleration and deceleration testing, and a 1-hour constant-speed run to emulate driving on a motorway in clear traffic. Each product was tested using the identical setup, with a 15 minute 'pure' petrol flush being used in between each test to ensure there was no cross-contamination. The results were interesting. Nitrox Hot Shot, NOS Race Only Octane Booster and Wynn's Octane Booster all reduced the overall power by 2bhp. STP Power Booster reduced it by 6%. Now remember this was measured at the flywheel so by the time you induce all the drag of the gearbox and driveline into that equation, you'd likely be looking at a 5% to 10% drop at the wheels. Impressive results for products that claim to increase your engine's power.
In England, octane boosters are typically also sold as "lead replacements" or "4 star additive". A lot of European cars relied on the lead in 4-star petrol for the increased octane. Lower octane unleaded fuels caused a lot of problems when they first appeared, especially with cars that didn't have engine management systems. Knocking and detonation became evident in a lot of cars and for some reason French and German engines were more susceptible than most. Dumping a shot of octane booster in the tank when filling up solved the problem by raising the RON a few points to make it the equivalent of what old leaded petrol had been. Eventually, by the late 90s, most English and European petrol stations introduced LRP - lead replacement petrol, and the problem went away. Well. Sort of......
Old Jun 2, 2009 | 08:52 AM
Majofo's Avatar
to prevent detonation / knock. Our cars run a CR of 11:1..
Old Jun 2, 2009 | 08:53 AM
it doesn't sound like i want everything that "comes with that" so ill look out for it thanks!
yeah, the key is that it's a turbo so the compression is greater. I have read that it makes a significant difference between our naturally aspired TL's and any turbo charged car when you add 100 octane.
Wiki/Google Octane.
Googled it and i got the same definition. but rather save the time in mixing all of that and keep it 91 octane.
I have access too paint thinner at work but I'm not the best at these little chemical mixtures so ill stay away from it haha
wow! ...must of been awsome lol
Old Jun 2, 2009 | 08:55 AM
vrrooom!!!
Old Jun 2, 2009 | 08:59 AM
Great advice, but to get 96 i would have too make my own mixture. By any chance...would the exhaust sound change if running with a higher octane?
Old Jun 2, 2009 | 09:11 AM
Dave_B's Avatar
Octane is simply a fuel's resistance to burn. The higher the octane, the more resistant it is to burn and preignite (ie detonation). High compression motors create lots of heat, so typically they require the use of higher octane fuels to keep the fuel from detonating before a spark is applied. For street cars, "high" octane is typically considered 91 to 93 octane. Using too low an octane can cause preignition which is sensed by the knock sensor which in turn the ECU retards ignition and adds fuel to cool the combustion chamber. The end result is reduced power and fuel ecomony. Using too high an octane basically has the same ending result because the fuel is so resistant to burn. The key is to find that octane grade that works best for the car. For more late model high compression motors, you're looking at 92- to 95 octane. The only way to really know is put the car on the dyno or take it to the strip.
