07' TL Type-S Chip Mods - Need Help
Hi there,
I purchased an 07 TL Type S about 6 months ago want to do some mods to make it faster and more bad-ass. Someone told me there are some simple mods to take the HP +115. Is this correct? Any input would be greatly appreciated.
Thanks! Scott
Thanks! Scott
FizzyStatus!
Cold Air Intake
Supercharger
UR Underdrive Pulley
P2R Throttle Body
Outlaw Thermal Body(or whatever theyre called)
Custom Exhaust/Greddy+Comptech Catback
EShift Procats
To name a few...
But I think it's pretty hard to get the TL-S up 115hp. SC'd guys are making around 302whp-320whp.
Supercharger
P2R Throttle Body
EShift Procats
To name a few...
Simple math: TLS + Cold Air Intake + Supercharger + UR Underdrive Pulley + P2R Throttle Body + Outlaw Thermal Body + Custom Exhaust/Greddy + Comptech Catback + EShift Procats = 335i. That’s just money wise. Other wise it’s less than that.
94 DC4 RS LSV/Turbo
^ you can't add partner
to get the tl-s 115+ at this very moment is not possible... the highest dyno'd TL-S was at 261hp to the wheels...
PS. TLS + No mods (not =) 335i
What I call a BMW - Brim Whim Wack-a-Wack
347hp/300tq @ 4psi
Originally Posted by hobiescotty
Hi there,
Thanks! Scott
Thanks! Scott
first, go to the person who told you that simple mods will get you 115+ and smack him/her firmly across the forehead.
next, press the little box that says 'search' and that will give you plenty of info on what mods are available for your type-s.
lastly, prey that comptech releases a SC kit for your car, or be the first to adapt a 04-06 kit to a type-s with no major snags and your set.
AZ Community Team
Received 7,771 Likes
Regardless, 115+ HP? No way. Well, maybe on the PlaySkool Dyno.
pro cats $1200 + 10hp
ur pulley $200 + 0hp
exhaust $900 + 5hp
thermo/manifold stuff $120 + 0hp
intake $200 + 2hp
so $2600ish for 17ish hp
It doesn’t add like that but with some luck it would be somewhere there.
AZ Community Team
Only 100 WHP to go.
Only 100 WHP to go.
Trucki!!
Originally Posted by mishar
Exactly that. When you wake up it comes to:
exhaust $900 + 5hp
intake $200 + 2hp
exhaust $900 + 5hp
intake $200 + 2hp
I would love to see some sources that negate hundreds of dyno's over the years
Originally Posted by lembowski
my dreams......what are you talking about exactly?
FIXED
pro cats $1200 + 25whp
ur pulley $200 + 0hp (weight loss+ better reaction time for motor)
exhaust $900 + 8 whp (comptech)
thermo/manifold stuff $120 + 0whp (better cooling to avoid heatsoak
intake $200 + 10whp
first of all, this is WHP on a dyno, not crank HP. These are actually numbers from dynos. There is some other stuff that i can't think of now, but it is possible to get about 60 WHP from some bolt on's besides NOS and a charger/turbo
2620 for 43 WHP
FIXED
intake $200 + 10whp
2620 for 43 WHP
Originally Posted by KN_TL
I'd like to see those graphs.
BASELINE:
AFTER MODS:
refer to this thread for the e-shift Pro Cat's
https://acurazine.com/forums/showthr...5&page=1&pp=25
94 DC4 RS LSV/Turbo
There aren't any boltons for the type s that can generate more than 15hp tops
Ps. The procats won't do jack for the type s... the type s cats are already highflow
Trucki!!
thanks for the clarification csmeance, on the ur pulley & manifold I was referring to the hp that is freed up by the product......not actually making hp but better utilizing the current hp (which in my opinion is the same thing). And the exhaust was for the greddy numbers of 8 to 10 hp gain.
-E-K-S-O-
just add stickers... everywhere!
you'll get your 100HP easily... just ask some of the fast and furious guys in their civics with shopping cart wings... all they did was add a coffee can in the back of their muffler and tons of stickers... bam!... 100 HP... IT'S THAT EASY!...
2010TL, 07 600RR, 06 1KRR
Ryan Christopher
Trucki!!
Business of the century! Faulty dyno.
-E-K-S-O-
Originally Posted by Black_05_TL_6SP
Your right in the fact the Type-S cats are high flow, but not as high flow as the Procats. The gain would not be as great as what I saw putting them on my 05, but there would be some gain. The questions would be is it worth th 10-12hp gain to get the procats for the type-s.
is he right?... unfortunately he's a rookie... LOL
I've been doing some reading... without the pictures... and i think the Pro-cats are a good buy... but... according to some people here, the TL-S already has free flowing cats... though not as good as pro-cats... if that is the case... then the extra money you will spend on the pro-cats and install do not justify the extra power you get over stock... also, i highly doubt that everyone is getting 10-12 horses out of the pro-cats (for a TL-S)... somewhere between 6-10 sounds better... i could be wrong... IMO...
I know a smog tech in california... he says pro-cats will not pass inspection if done by a good professional... but he also stated that any rookie wouldn't even notice...
so you say all the products for our cars produce significantly less hp than the manufactures/independent dyno testers have tested at. do you have anything to show proof of your statements? Mostly the pro-cats and intake........
In the world where Acura, and most of the others, used unfair testing to misrepresent power of their engines, where even in the court of the law, under oath, you will get two different expert opinions, you are talking about independent testers and aftermarket manufacturers test results. Is it just another dream?
Originally Posted by csmeance
all you say by that is that everyones results will be different correct? well there have been numerous dynos by our own independent members at their own chosen facilities and also by the manufactures. the results of both are very well close to each other, and i doubt that our own members would misrepresent power generated by things that can end up costing a fortune, if anything, members here try to find the truth behind things to see if it's snake oil or not, to help save money and to help others.
No, that’s not all I say. All I say is that those dyno tests are totally unreliable, that you can go to 10 of them and get 10 different results without touching anything on your car and that everybody can get what he likes as a result. I am positive that when you pay couple of thousands for something you really like that it works and that dyno operators know that disappointing customers is not good way to keep them. You do the math.
-E-K-S-O-
well, if you look at the graphs I posted, the factors that could change the results were near each other, temperature, humidity, etc. A dyno isn't the best way to see how much exact power you have, but it can give a pretty close range on the power at where the car stands.
The numbers in magazines/documents/articals/tests (etc)
are usually just averages... IMO
Why didn't acura just do the 65hp worth of mods stated to the 3.2 and have a 325hp car. No replacement for displacement. That's why acura went to 3.5L The increase in size raises torque(and consequently hp), which makes a difference.
AEM cold air intake would cause legal liabilities with hydrolocking. E-Shift Pro cats would remove honda's ULEV emmisions rating. The exhaust was not done because this is supposed to be a luxury car, not more of a sporty car with a drone.
Good points, but I still don't think that for the money that the bolt on mods are worth it. That's just my opinion. It's not like a diesel truck where you change a few computer settings and bam your 100-200 hp more. These motors are already getting very healthy output for their design while still keeping them civil and driveable. Is there room for improvement? Of course, the factory is always restrained by emissions, sound, driveability, etc. The whole intake thing to me is funny. Is the stock system restrictive, probably, but how much HP is an aftermarket intake unlocking. 4-5 peak hp? Does that make a difference? Not really. Basically it makes it loud and that's what people equate to performance. I like the sound too, but I"m not spending $200 for a piece of pipe and filter.
Some of us also just like to tweak on things. I've done this to all my MX bikes, ATV's, mountain bikes, etc.
I am personally not looking at getting massive amounts of hp since it is a fwd car, but for me, it's a good combination of comfort, performance and fun. And something that can be driven year round up here in the northeast.
Some people will spend $100.00 on a steak dinner, some opt for McDonalds.......
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
DerrickW
11-15-2015 05:52 PM
InFaMouSLink
10-27-2015 06:52 PM
