05TL cat back in 3inch/magna flow
i found a place to make a cat back system,
he told me he would make it out of 3in mandrel bent tubing
with bigger them stock resnator and larger then stock 3in magna flow stainless steel xl mufflers and modding stock tips ,my request
he said the 3in will work perfect with larger resnator and mufflers to keep it very stock sound with a little deeper growl and more power all the way around
i trust him cause he did the system by hand for my saleen due to how low it is,
very good work
he wants 690.00 installed, i think that sounds good
what do you guys think????
please only real coments,thanks
very good work
Honestly I think you are going to lose a lot on teh bottom end for a small gain on the top end. The engine size just isn't big enough to require 3" piping. I personally would stick with 2.5-2.75" max.
very good work
very good work
i forgot to say,its three inch to the y pipe,then its 2.25 inch,
this is how i look at it,my mustang can with stock true dual system and its same hp as my tl before i supercharged it,mustang that is.
i sure the car can help from it,
and the bigger piping will work better with over sized resnator and mufflers
i wouldnt go 3" before the split...you're just spending more money on the parts. i dont think you are going to get the gains you are looking for...i kept the oem pipes because they seemed big enough and just swapped the mufflers to the magnaflows because they are less restrictive. the comptech is too much money for something you can do for a lot less.
Something that Acura did with the TL was to reduce pipe size in steps from engine to tailpipe. I believe this is done to maintain exhaust velocity as the exhaust cools. Following this strategy in a custom system seems like a logical approach to reducing restriction while attempting to retain efficiency. The smaller pipe and muffler sizes would also reduce cost and weight. Use whatever size tip is preferred for aesthetics, but no need to run larger pipes than needed.
my saleen is a mustang conv 2001 and they scrape every where,
i understand what my guy means,the three inch is to make up for how large the resnator is and the extra back pressure and same with the larger mufflers,
i want it that way cause i want no sound louder then stock,not by much,,
i know comptech system drones under load,i dont want that,i have a loud ass car,dont need two.please under stand i want it very quiet and any mufflers that are free flowing are louder.i hate rasp from small motors too.
this with my k&n will help to be more free flowing.
also think of this,how many cars do you know of making 270= hp that have stock 2.25 system under it ,not many,
cars in this hp range use true dual systems
or high hp 4 cyl use 3 in too,
3 in is not to big when used right,its only going to be from the thrid cat to the y pipe,then 2.25 to mufflers,
you know something about exhausts??the idea is to keep the gases as hot as possible until they exit the mufflers.
a good 2.25" system is good for about 400hp on a normally aspirated motor, after that the pipes become restrictive so 2.5" would then be used.
Originally Posted by blufox
by the way can u change anythin b4 the third cat and if u can by changing it would there be any gains
k6biv
Sep 10, 2015 06:37 PM
